Question about LG Computers & Internet
Why won't my lg tv turn on after I unplugged it and replugged it?
I unplugged my lg tv to switch out tv stands and then replugged everything back in. Now my tv won't turn on. I have checked the power supply several times and everything is plugged in correctly. Why won't my tv turn on?
SOURCE: won't turn on
Problem is caused by Diode Ref.#D620.
Sony Part#871907443.Cost $5.00
Posted on Oct 15, 2007
  • 157 Answers
SOURCE: Akai LCT3285TA Television won't turn on
the problem is in the power supply(they know about it good luck fighting them)but there is good news.you can remove the power supply and replace electrolytic caps,EC18,EC19,EC20 all of them are 1000mf at16 volt use 1000mf at25 volt.you can also go to shopjimmy.com enter model number you will see power supply part number MLT169B
it will be cheaper for you to replace the caps,the board cost about $80.00 from them
Posted on Sep 24, 2009
Testimonial: "Dale Hunter's response was completely accurate. I replaced the three capacitors that he identified. And it has been working fine since 2009. Now I have the black screen problem. Help me Dale."
SOURCE: LG 32LB75 TV stuck in stand by and won't switch on!!
TV currently on stand by and won't some back on. Only way to switch it if is by unplugging it, which I've tried, but goes straight back onto stand by.
Posted on Jun 19, 2010
  • 17 Answers
SOURCE: olevia 242fhd-t11 Has no power. Will not turn on
I am guessing that since you are checking other outlets that you are getting no STB light or anything. So you will want to start by looking at the SMPS on the unit and see if the 5A 250V fuse is blown or not. If it is blown then you can try replacing it but I would bet that it will just blow again. So you need to replace the SMPS
Posted on Sep 09, 2010
dbTVfixer
  • 79 Answers
SOURCE: LG 32LH2000 My TV was turned of last night in the
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
Posted on Apr 16, 2011
Lg tv does not turn on
The 55lh90 has a vacation switch on the bottom right corner. It's a toggle switch that interrupts power to the power supply. Should just need to toggle that switch to the "on" position, and everything should be back to normal.
Dec 12, 2011 | LG 55LH90 55 in. LCD HDTV
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
LG 32LD550 Tv will not turn on. Just purchased it a few weeks ago.
Check ur power source?Tries tv unplug,replug the tv back about an hour later.By letting tv resetting itself back to factory setting.Now the tv should be working again.If still have same problems,tv mostly have the power supply board problems.Take it back where u bought it exchange for another tv or call LG for a warrenty repair.
Jan 05, 2011 | LG 32LD550 32 in. LCD HDTV
I have a 50 inch LG plasma tv that is less than 2 years old. It use to turn on by itself throughout the night, and now it's completely not working???
Hi there
Try doing a system reset on the TV, by unplugging everything from it, then wait 3 minutes and plug the power lead in only. If it works, then plug everything back in one by one. If the problem persists it may be that the software has been corrupted in an update process, which can be performed at night via the aerial signal (this may be why it was turning on at night). In which case contact the TV manufacturer.
Hope this helps
TV_Doctor
Jan 03, 2011 | LG 50PX4D 50 in. Plasma Television
LG tv switched on and no colour everything else working ok just in black and white. Was ok when switched off last night
Tries unplug,replug both tv and cables or satalites boxes an hour later.Tv should reset it self back to factory,pay boxes upgrade it softwares.The tv should work,back to normal.Not, take another tv test that incomming brocasting signal cable.If the incomming brocasting signal is good.Than the tv Tuner board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Sep 30, 2010 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Hi, i just purchased two LG LCD TV's the 26LD350 and the 32LD350 I'm worried that it does not have an off switch and only goes on to standby mode. you here alot about tv"s catching on fire because of this....
I have never heard of any LG TVs having a fire issue.
LG added this switch to help save electricity. "Going Green".
You see, this On/Off switch was added to kill the power to the TV when not in use. This switch stops the TV from consuming power by not giving it power to be in a “Stand-By” mode.
If your TV does not have this switch, you could simply unplug your TV to give you the added satisfaction it won’t catch fire.
I hope this information has helped.
Good Luck.
May 23, 2010 | LG Televison & Video
An orange stand by light & tv not turning on ?
Try unplugging it, and then plug it back in, see if that resets the TV
May 06, 2009 | LG 52SX4D 52" HDTV
Mar 24, 2009 | Televison & Video
Computers & Internet Logo
27 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
