Question about LG M2362D 23 in. LCD TV
What is wrong with mt lg m2362d television displaying v3.02.0?
Problem V3.17.0 appears on my LG TV model No.M2362D. What is this?
Sounds like it is displaying the firmware version because it is being started from applying power rather than pressing the On/Off button.
Sep 06, 2014 | LG M2362D 23 in. LCD TV
Picture works for about 15 seconds then goes off leaving sound only. Appreciate any help
two possibilities
1.Power supply unit problem
2. lcd -lamp problem either ways for this model advanced help is needed
Jul 02, 2014 | LG M2362D 23 in. LCD TV
Why my lg flatron m2362d doesn't working?
Sounds like the main system control IC fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 26, 2014 | Televison & Video
Flickering screen on lg m2362d
If you can hear sound, then screen is gone.
I'll bet you don't.
If you see an image, hear sound, just won't hold.
I'd bet on the T-Con board.
Not knowing what is really happening here..
If willing to dive into electronic's.
Open her up and start testing power side, starting with capacitors.
Feb 03, 2013 | LG M2362D 23 in. LCD TV
M2362D
try to replace sound board or sound IC
Jun 14, 2012 | LG M2362D 23 in. LCD TV
Hi I just bought a LG M2362D tv monitor and somehow the backlight level (feels like the backlight) will change to very dark automatically every 5 or 10 minutes then back on bright again in 1 minute does...
The tv have a long board that called the tv LCD inverter board,this tv LCD inverter board only job are to control and help the all the amount of the tv LCD screen panel backlight brightness for the tv LCD screen panel for light.This long LCD inverter is the causes and the problems.New tv exchange it for another one,not so new take ur tv warrenty repair qickly the tv long LCD inverter board it is the causes an the problems must have to be change.
Sep 13, 2011 | LG M2362D 23 in. LCD TV
Hi..i have LG FLATRON TV.model m2362d.the problem is the remote and the bottons are not working.and also showing a firware v3.13.0..pls can you help.
I got the same problem and i raged a lot ! But now it's better, so you should take your telecomand ant try all buttons and it will turn on again ( sorry for my bad english i'm french and i'm 14 ) yours faithfuly ;)
Apr 16, 2011 | LG M2362D 23 in. LCD TV
My LG M2362D keeps turning off automatically while I'm on the computer and then comes back on again within 10secs. Why does this happen intermittently?
Check the monitor cord to the PC, tighten them as also check the mother board for any loose connections. If possible try with an another monitor to confirm that the fault is with the monitor or not. If so open the monitor after disconnection of mains and solder all the suspected joints , seen to look dry. Check for loose components, capacitors, IC or resistor that detach the soldering connection when it is hot.
Jan 21, 2011 | LG M2362D 23 in. LCD TV
LG M2362D 23 in. LCD TV Logo
43 people viewed this question
Computer Repairing
Computer Repairing
