Question about Philips dvp-3960 region code free dvd player
Need drive belt for disc tray for Philips 3960 dvd player
Need drive belt
drlalitv
  • 488 Answers
SOURCE: dvd player gives unknown disc
thats because its region locked..do the following:
start the player without any DVD in it.
open the lid.
while the lid is open press 9,9,9,9,0
you should see region 0 displayed.
close the lid.
Your DVD player is now region free.
note:
replace 0 with 1 to 6 at to set the wanted region number if needed.
do let me know if it worked.
Posted on Oct 29, 2008
SOURCE: please enter password PHILIPS DVP 3960
enter the default password "136900"
Posted on Apr 22, 2009
  • 6 Answers
SOURCE: DVD PLAYER DISC TRAY DOES NOT OPEN
tap it gently from the side while pressing the button......or with a knife try to open it gently...while pressing the button....after it,s open..clean the side n the belt..
Posted on Jun 26, 2009
  • 1348 Answers
SOURCE: my dvd palyer shows NO DISC for any disc i want to play.
the laser is probably no good or the tiny motor that spins the disc is no good.there is a clamper assembly that goes in the hole in the disc.turn it and see if it spins freely.there is a bronze bushing on the top of the motor driving it ,and a small drop of light oil on the bearing will make it work again if it is gummed up..if the motor does not get the disc speed from 250 to 600rpm,fast,the laser does generate the proper info and the computer says error.yes the motors can be replaced,but the cost is as much as a new one
Posted on Jul 03, 2009
  • 5 Answers
SOURCE: Philips PET710 DVD player shows 'no disc' when disc inserted
The safest way , this may sound really stupid but has always worked for me is give it a slightly rough slam on its bottom and it will work , dont judge this badly for it actually wotrks
Posted on Feb 16, 2010
Dvd is saying disc lock on my philips 3960/37 dvp
Does it do this on all the disks you try and play?
Aug 19, 2016 | Philips Televison & Video
CAN'T OPEN DRAWER
Hello
There is a motor along with belt to control the disc tray for every DVD player. If this belt or motor [loading motor] has trouble, the tray won't come out or get into. Check these for perfectness.
Dec 12, 2011 | Philips DVP642 DVD Player
My dvd player is not recognizing copied discs or original dvds, it keeps saying no disc. It's a Phillips dvp 3960
If someone answer you, or if you found the solution, please, let me know. I have the same trouble.
I need a fast solution-
renquintanilla@gmail.com
Nicaragua
Jan 11, 2011 | Philips DVP3960
I'm tryna program my toshiba sd 3960 but I can't find the manufactures code... can any one help I would extremely appreciate it thank you...
Here is a possible hack for TOSHIBA SD 3960.
Press 'hold' for a few seconds.
Release.
Pres 7,8,9,OK,0. (or possible ENTER button)
In the left corner you should see a 0.
That is it
OR the following steps
1. Press the Open button on your remote control to open the drive tray
2. Press the 2 button on your remote control
3. Press the 4 button on your remote control
4. Press the 0 button on your remote control
5. Press the 3 button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 0 button on your remote control
9. Press the Enter button on your remote control to change the region to 1 for region 1, 2 for region 2, and so on, or 9 for multi-region playback
10. Press the Open button on your remote control to close the drive tray
11. Power off the DVD player
12. Power on the DVD player
Nov 13, 2010 | Toshiba SD-3960 DVD Player
Disk not ejekt - Philips DVD 5990
Disc Tray Won't Open on Philips DVD Player Model DVP5990/37: The first thing to try is unplugging and turning the unit upside down and finding the slot near the tray port location. Inside the slot you'll see a white plastic piece with a small tab. Use a small knife or ice pick, etc. to slide the tab toward the far side of the unit. This unlocks the tray and should pop it open about 1/4". Place the unit back right side up and plug back in. Hit the open button and it should either close or open depending on it's current cycle, but it should work unless the drive belt is snapped, for which you'll need to remove the outer cover and fix or replace. I'm told there are no factory replacement belts available yet for these machines, however I've used large O-ring seals in place of belts to fix other models of machines. As far as Philips support for this unit, it stinks. Their live and web help features are now useless because all of these models are now "out of warranty" and they remove detailed support postings from their website and from live help stations as soon as they are out of warranty - just when you need such help. I would not recommend any Philips product, as this is my second Philips unit I've purchased new which had serious problems just after a few uses.
Apr 29, 2010 | Philips DVP5990 DVD Player
Philips HTS3400 door won't open and shut. Says NO DISC
open up the unit and replace the broken drive belt for the dvd tray. us an O ring that you can get at any auto parts store. i replaced mine and it works fine now.
Oct 06, 2009 | Philips HTS3400/37B System
Jun 26, 2009 | Philips DVP3146K DVD Player
DVD VIDEO DISC MECHANISM WILL NOT FUNCTION
broken tray belt or belt is off. usually a small motor up front exposing belt to be knocked off.
Dec 08, 2008 | Philips Televison & Video
Phillips pet 706/05 dvd player wont dvd-r-rw
  • Disc not loaded. Load a disc into the player, close the door and press PLAY.
  • The disc used may be defective. The disc used may be defective, try another disc.
  • The disc is placed improperly in the tray. Make sure the disc is properly placed and centered in the tray and if the disc has a label on one side, make sure the label is facing up.
  • The disc is dirty. Use a soft cloth to clean the disc by wiping in a straight line from the center of the disc to the outside edge.
  • Use of DualDisc or Flip Disc which does not meet the Compact Disc Digital Audio Standard. Some music labels have recently introduced the DualDisc for pre-recorded audio and video content. The DualDisc bonds DVD content on one side 'back-to-back' with digital audio content on the other side. However, the digital audio side does not meet the technical specifications specified in the Compact Disc Digital Audio Standard. For this Reason, DualDisc is not permitted to carry the CD logo. Philips DVD and CD players and disc drives fully comply with the CD specifications and therefore may not recognize the DualDisc. Attempting to use DualDisc may lead to playback problems or jamming in the slot loader or drive.
    The DVD video content on the DVD side of the DualDisc should play on Philips DVD players and DVD drives. However, Philips DVD players and drives do not support DVD Audio, and will not play any DVD Audio content present on the DVD side of a DualDisc. Philips will further investigate DualDisc and update this notice accordingly.
Jul 18, 2008 | Philips Televison & Video
Philips dvp-3960 region code free dvd player Logo
51 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
