Question about Compaq Computers & Internet
Inow how to install a power supla for a compac cuputer
    Sergeant:
  • 240 Answers
>Unplug computer from wall outlet.
>Open side panel on case.
>Unplug all cables from your hard drive(s), DVD drive(s), and cooling fans. Also, the main motherboard power cable plugged into the motherboard; it's a wide plug with numerous cables coming out of it and will be a bit hard to unplug. Do not pull on the cables themselves, grasp the plastic plug and work it off the motherboard socket. There may also be a snap catch that you have to press while pulling.
>There are 4 screws on the rear of the computer that hold the power supply in place. back those out. Make sure the power supply doesn't just fall. Usually there is a small ledge that it rests on but no guarantee on that.
>Remove the PS. Usually they just slide out, but sometimes it is a bit tricky to free it from the case if the PS hits the rear of the DVD drive; you just have to work with it.
>Slide in the new PS, mount it with the screws and replug all the cables. If you arent't sure, label the cable plugs and where they go with bits of masking tape, it will help you remember which cable goes to which socket. Check on the rear of the new PS, there may be an on/off switch. If there is, turn it on. Do not get confused with the 120/240 USA/European converter switch! Leave it on 120v for American power.
More information:
http://www.suggest-a-fix.com/index.php?/topic/206-home-building-and-testing-techniques/
Posted on May 19, 2014
Nokia carl zeiss
macromaxQ75 bad contact of battery solution
Jan 18, 2014 | Cell Phones
My computer is set to turn on when power goes off but the power will go off and my computer would not turn on its own
Need to how to correct this probnlem . my cuputer is set to turn on when when the power goes off. but the power will go off and then turn back on and my will not go on with my help.
answer:
sir all you have to do is go to bios setup. change the settings in power management menu. to go there restart your pc and press F2 or delete key before or after the power on self test. look for the words "power on after power failure", the statement may vary depending on the type of motherboard.
hope this helps. email me at tennisyman@yahoo.com
Sep 27, 2012 | Computers & Internet
I have a Compac Presario, running VISTA. When
simply disable the automatic update service by following these steps.....
start | run | services.msc | automatic update
stop ...and disable it...click ok
and close the service manager....
then try to shutdown the machine ....
Dec 30, 2009 | Computers & Internet
Truck trys to stall after installing sound system what could it be
Your system is drawing to much power. Buy a new hi compacity amp alternator or an extra battery.
Dec 11, 2009 | Power Acoustik MOFO-12 Car Subwoofer
How can i download compac 510 web cam driver for vista
Connect to the Internet and get your download. Just
type at the search engine (download for Software driver
compac 510 webcam ) and click on it. Follow all the
instruction so you can get your download. Then, at your
PC, open the download, and have it installed. Then, test
your web cam.
Dec 09, 2009 | HP Compaq (319235-001) for Presario 5100 /...
Ive tried 3 diff hd's all say no os found when i inow there is a os there its a e-machine any suggestions
A hard drive is where your operating system is located, so did you install the operating system onto each of the three hard drives. And if they were already installed prior to you installing them into your system it still wont work, it will need to be configured for your hardware setup. Put in a hard-drive and install the os from scratch this will get you up and running.
Jul 14, 2009 | E-Machines Computers & Internet
The installation software will not start in my 8 yr old compac
Try copying it to the Pc, then run the setup.
Hope this helps
Richard.
Apr 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Battaryby
Hiiiiiiiiii all
my question I replaced the battery for my car Envoy 2005 by new one .Some one tell me If you replace any part in your car you should Reset the Cuputer in the car.
Is it right or no?
untell now I did not have any probelem with my car and I did not Reset the Cuputer.
thanks
Jul 19, 2008 | 2005 GMC Envoy Xl
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
