Question about Keurig B100 Coffee Maker
No longer pumps water
Will not pump water out
    Problem Solver:
  • 13 Answers
I have fixed a couple of them by applying a thin layer of keg lube to the silicone flange underneath the water tank. Remove the bottom cover of the brewer and take out the two screws that hold the flange in place. This is where the pump draws water from the tank. Air can get in at that seal and it won't pump water if that happens. Keg lube will make it seal better. I got mine at Annapolis Home Brew dot com. Hope that helps!
Posted on Apr 05, 2010
C48k2n143b1
possible leak from pump motor and pump housing its losing prime in basket less hassle to replace whole pump if leaking its ruining bearings in motor
Feb 15, 2018 | Pool & Spa
Antifreeze leak behind timing cover
Try replacing water pump gasket and or you might have a cracked water pump try replacing the water pump itself
Dec 11, 2012 | Cars & Trucks
What are the signs of a water pump problem
A water pump problem will begin with a small quantity of leaking water from the top or bottom of the pump from a small depression called a weep hole. This lets you know the pump will fail soon and the "seal" inside where the blades turn is "rocking back and forth" and is no longer solid. The water pump will cause you to have low coolant and your fans may kick on while you are driving rather than when you are stopped in traffic. Then the pump will begin to make a grinding noise as it fails worse and the vehicle may overheat due to low circulation. To test the pump, remove the drive belt and turn the pulley for the water pump by hand. If it is NOT SMOOTH it is time to replace it.
Sep 14, 2010 | 2000 Ford Windstar
Slow Leak in Water Pump-1999 Plymouth Voyager
What's probably happening is the weep hole on the water pump is leaking water. The weep hole is a warning sign that the water pump needs replaced. You don't have any heat because the impeller in the water pump is no longer circulating water.
Apr 23, 2010 | 1999 Plymouth Voyager
I have a portable room cooler and while the fan still works the water no longer gets drawn up for the cooling effect.
First start with a good cleaning, it sounds like the pump is either plugged or burnt out. Make sure the water pan is clean, pump screen and the base of the pump, use something and reach in and spin the pump wheel, allot of the time the pump will hang up, from sitting. But of a longer term solution, problably the pump will need replacing.
Apr 01, 2010 | Mastercool 67680 Evaporative Cooler Air...
Whirlpool lsr 8233eqo runs over every time any help out there
The main things that will affect time on any programme are the flow rate of water coming in, flow rate of water being pumped out and the temperature of the water coming in and the amount of heating required to be able to run the chosen programme. If the water is colder coming in then it takes longer to heat up and hence the programme takes longer than expected. If there is any blockage in the outlet pipe or blockage in the filter or pump it takes longer to pump out the water at each cycle and therefore the programme takes longer.
Nov 17, 2009 | Whirlpool Washing Machines
Well Water Issues
This could be a number of issues:
Your wells water level may have dropped off to a pont where the pump is no longer in the ground water
If in fact power is getting to the pump the motor may have failed
The pump may have broken off of its drop-pipe, this I see oftenwith pumps with plastic heads.
The control box (if one) may have a failed component.
You may have a sever leak within the well as water is just recirculating with in the well.
A check valve may be stuck
I'd call a water professional on this one, until then shut the ubit down so possible dry running of the pump and mortro does not occur.
I hope this may have assisted you,
Tom
Oct 02, 2009 | Plumbing
I need to know where the water pump is located?Is it on the side where the pulleys are and above the oil pan?
Removal & Installation
To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Drain cooling system. NOTE: The water pump is driven by the timing belt.
  3. Remove or disconnect the following:
    • Engine timing belt
    • Water pump mounting bolts and note position of longer bolt
    • Water pump body from engine
To Install:
NOTE: It is normal for the water pump to leak a small amount of coolant from the weep hole. Do not replace the water pump if this condition exists.
  1. Clean O-ring surfaces on pump and cover.
  2. Apply Mopar Dielectric Grease or the equivalent silicone grease to the O-ring.
  3. Install or connect the following:
    • New O-ring on water pump
    • Water pump to engine.
    • Mounting bolts
      1. Torque to 105 inch lbs. (12 Nm)
    • Timing belt
  4. Fill cooling system.
Jun 23, 2009 | 2005 Chrysler Pacifica
Keurig B100 Coffee Maker Logo
727 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
