Question about Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM PUMP BY
Plastic nut stripped on impeller. How to get it off>
  • 634 Answers
If you go to auto parts store or tool store they make a socket with reverse threads inside that will remove the nut.
Posted on Jul 17, 2009
Remove stripped screw head
TAP AND DRILL IT OUT.
Feb 24, 2013 | Cars & Trucks
Impeller dropped off. Replaced the hub but did it again.
maybe you should be using a washer and a nut to securely fix the plastic hub in place
Jul 13, 2017 | Garden
Impeller spins when i'm holding the shaft. what would cause this problem or is it? i have no pressure.
Late answer but might help someone else out.
There is a nut molded into the impeller. If the threads are stripped or damaged the motor shaft will spin and not move the impeller. You'll have to take the pump apart to diagnose.
Apr 30, 2012 | Polaris Pb4 - 60 Booster Pump
How to remove stripped stud and nut
Use a chisel use caution not t o hit the rim split the nut .
Mar 20, 2012 | 2007 Ford Mustang GT California Special...
Opened up my blower .the motor looks ok.the only thing i find strange is when th emotor is running i can hold the impeller with ease while motor continues ,should this be happening
Stating the obvious no, the impeller should be tight on the end of the crank, you need to remove the impeller and see why it is loose, it may be a key sheared, or just the fixing nut is loose, if the impeller is plastic it may have turned the centre out.
Aug 24, 2011 | Garden
String stuck in fan
Remove the string.... split the plastic shroud in half by removing all the screws ( allen ) once the impeller is uncovered remove the center nut with a 3/8 drive air ratchet and remove the impeller then you will be free to remove the string. While you have the impeller off double check the four motor mount screws and make sure they are tight. reassemble.
Nov 22, 2009 | Poulan Garden
How to change impeller on flymo hover mower L38The plastic type
the small blades are just held on by push fit,,
grab hold of plastic blad and push it inwards to unclip them
fitting new ones pull them out before starting mower up
the inpeller is bolted to the motor shaft with a left hand thred on a kye way undo nut and just pull impeller off shaft,,, (there normaly stuck on tight with dirt or rust? a good drop of WD40 will help get the impeller to move down the shaft
Oct 30, 2009 | Garden
Kitchenaid dishwasher making funny noises while running
HI. this sounds like a busted impeller in the pump housing. there are two impellers. one for the wash and one for the drain. the drive shaft will strip the impeller center nut, causing this noise. I would inspect the pump housing for lose impeller action. replace the faulty impeller if found to be damaged.
Jun 11, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
I disassembled the pump but I can't get the impeller off. It's stripped and needs replacing. I don't want to force it and break something else. What is the best way to remove the impeller? It's the No
I broke the outer circle of the impeller off with a screw driver and then used a Dremel tool to cut the plastic down to the shaft so I could break if off the threaded shaft.
May 25, 2009 | Hayward Northstar 2 - Hp In Ground Pool...
LD code appears after a few minute of starting the washer
Check the pump impeller for debris. Coins, socks, draw strings - etc. - can get sucked in and jam or slow down the pump. To check this you have to go into the washer from beneath (unplugged, and manually drained or wet/dry vaccuumed out). Remove the clamps which hold the water tubes onto the pump motor, taking care not to spew water into the motor windings (they're open). May have to put a finger or probe into the plastic pump tubes to see if there is something in there. If no debris, could be a bad or failing pump. The new design is a single piece of pump/impeller, and you cannot disconnect the pieces without a special tool. The old style pump/impeller can be separated and is a metal serrated shaft into a plastic impeller hole that can strip out when debris jams the impeller.
Feb 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM PUMP BY Logo
244 people viewed this question
Top Jacuzzi Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Jacuzzi Garden Expert? Answer questions, earn points and help others
