Question about Kodak EasyShare DX7630 Digital Camera
Give the solution for this erreo
#E21 error
Error code e21: Bushes replaced by engineer but unable to reset machine. E21 still shows. Bosch totally unhelpful.
the electronics lock out during power surges like you would get from brush failure giving e 21 error. you have to access service test prog to reset this, and it is not in public domain.
i do know how to reset it though but difficult to explain on this forum you may find a you tube video if you search online.
Sep 24, 2016 | Bosch Washing Machines
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Sep 13, 2014 | Electrolux Washing Machines
What does error code mean e21
Manual says E21 is 'Off Line'. Not much to go on there but I am guessing that is probably referring to something that is plugged into the serial ports on the side - perhaps it is looking for an external kitchen printer of something along those lines.
Jul 09, 2014 | Samsung Sam4s ER-5200M Cash Register WITH...
Front load washer e21
Good Morning Friend,
I see that you are receiving an E21 on your Frigidaire washer, model# ATF6000ES. The E21 error code states that water is not pumping out fast enough. Here are a couple of suggestions that you can try.
    1)Check the drain hose for any kinks or clogs. Also, make sure that the drain hose is only 6-8 inches down in the drain pipe. If the drain hose gets backed up with water this error can occur.
    2)Make sure that the actual drain pipe, where the drain hose goes into, is only a maximum height of 8 feet. If it is longer than 8 feet, you will need to cut some of the pipe off.
    3)Make sure that your homes drain pipes are not clogged. If they are, you will need to unclog them. Call a plumber if necessary.
    After checking the above suggestions, reset your washer by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. If you are still receiving an E21 error code, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why you are receiving an E21 on your appliance. Hope this is helpful.
    -Best regards-
    WP
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
Treadmill not working. Troubleshooting: Receiving E21 message. What does E21 indicate?
The E21 error code indicates that the console is not receiving a signal from the sensor that controls the speed on the treadmill. This means there could be a problem with the speed sensor. You may need to have a technician check the voltages on the power board and controller.
Nov 27, 2010 | HEALTHRIDER Exercise & Fitness
Canon DR5020 E21 error
Canon Scanners are reliable. Canon has chosen error codes logically, 'P' os Paper related, 'C' os cover related, 'E' is Engineering Support related.
E21 is Document Motor Trouble. E2 is Separation Motor Trouble. Check of connection and load or you may to replace motor. Try connecting the motor to a different location and if the error is same, probably there is no motor fault, if it changes then it definitely motor fault. As a last thing you may need to change the PCB on the side.
S. Mohan, Chennai, India
Jul 03, 2009 | Canon DR-5020 Path-Through Scanner
Error code E4 54040990, and E21
use dvd-r they are not as tempermental. plus they are more universal if giving the media to somebody that may be older.
Jun 02, 2009 | Radio Shack Accurian ADR-0106
Canon DR-5020 Error Code E21
Just saw your problem! 'E21' refers to Document Board Motor Problem' Check if there is any loose contact and if required replace motor.
Jan 08, 2009 | Office Equipment & Supplies
Memory card erreo message
when i try to make any action with my nokia N73 512MB micro memory card or format it it doesnot responde and i recive a message the disk i wreite protected
Aug 26, 2008 | Cameras
Kodak EasyShare DX7630 Digital Camera Logo
22 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
