Question about Philips DECT 2252S Cordless Phone
En la pantalla avisa Warning en inhalámbrico Philips dect 122
Debes sacar las pilas, luego insertarlas y muy rápidamente entrar al menu, en ajustes avanzados debes reiniciar y pulsas ok, a mi me resultó con éxito.
dan231
  • 236 Answers
SOURCE: philips dect 122
During a call, press the top right button to turn mute off
Manual
Posted on Dec 05, 2008
SOURCE: philips Dect phone 122
It's a while since you posted, but find your exact model number (under the basestation) then go to:
http://www.support.philips.com/support/html/index_gb_en.html#../~scripts/xsltransformsearch.asp?url=http://www.sms.philips.com/catalogue/list?sid=SMS||type=CONSUMER||locale=gb_en||mode=prod_text||item=dect%20122||page=1||show=50&xsl=search_result.xsl
You'll find the English PDF file from the list!
Posted on May 26, 2008
  • 3 Answers
SOURCE: language
Please visit the Philips site to download the required manual.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=CORDLESS_PHONES_CA&sct=DIGITAL_CORDLESS_PHONES_SU&grp=PHONES_GR&ctn=DECT1224S/05&mid=Link_FAQs&session=20081124195941_213.94.135.206&hlt=Link_FAQs
Posted on Nov 25, 2008
richa33
  • 71 Answers
Normally , one base can register 4 hanset in EEPROM setting. The model, Maybe you can try press the "page" key, then plug the power cord , after 5 to 6 second , release "page" key. Try to register handset again.
Posted on Jan 21, 2009
  • 6 Answers
SOURCE: Warning sign on the display, what shall I do?
try take out batteries.when you put them back for a short period its flashing "anmelden" or "searching",in tnis short time you can accses the menu and try to reset the handset.
Posted on Sep 16, 2009
DRIVER POLAROID PDR 300
Hola a todos, el grabador tiene los controles en dos circulos debajo de la pantalla, en el de la izquierda, con el grabador ENCENDIDO, debes oprimir unos segundos el boton rojo del centro que dice ERASE, y aparecera la leyenda DELETE ALL titilando 3 veces, y luego dice FORMAT, tambien titilando. En este momento oprimimos nuevamente el boton ERASE y el grabador comienza a formatearse, en la pantalla aparece el mensaje WAIT, por lo que esperamos a que termine el proceso, y LISTO!!!, cuando lo vuelvas a conectar a la PC te reconocera las 4 carpetas. Tambien yo lo formatee con la PC y estuve varios dias con este problema. Pasa que luego de un tiempo de uso, y aunque vayas borrando las grabaciones que hagas, la memoria se ocupa totalmente y te pide el formateo. Espero que te haya servido. Saludos desde Buenos Aires
Sep 20, 2012 | Polaroid PDR302 Digital Voice Recorder
Mi control de dish no quiere hacer nada quien me ayuda
Hola mi nombre es Kimberly Escobar con DISH Network servicio al cliente. Lamento escuchar que este teniendo un problema con su control de DISH Network, seria un placer asistirle proveyendole informacion que le sea de uso para resulusionar el problema. Si el control no esta haciendo nada primeramente debe asegurarse de que el control este en el modo de SAT significando que cualquier boton que oprima el control el boton de SAT en la parte de arriba se debe encender en rojo. Si ningun boton se enciende en rojo puede intentar poner baterias nuevas en su control, si no funciona significa que el control no sirve necesitaria uno nuevo, si el boton de SAT se prende en rojo puede intentar reprogramar el control a su recibidor. Para hacer esto tiene que accesar la pantalla de System Info en su televisor, puede hacer esto oprimiendo el boton de Sys Info enfrente del recibidor. Despues en el control va a oprimir el boton de SAT hasta que los demas se enciendan rojos cuando vea que se encienden rojos ingrese un numero entre 1-15 seguido por el signo de numero (#) y el boton de record una vez. Trate el control deberis funcionar. Tambien puede entrar a nuestra pagina web http://www.dishnetwork.com/SupportSection/remote-control aqui encuentra ayuda en como arreglar el control y el procedimiento. Si necesita mas ayuda por favor contactenos directamente al 1800-333-DISH gracias espero esto le ayude.
Feb 09, 2011 | DISH Network IR Remote Control
Teclas 2,w,s n funcionam
Podrias tener un problema en el conector del board donde enchufa el "flex" que sale del teclado. Primero debes sacar el teclado, desconectarlo y volverlo a conectar, OJO que estos conectores tienen un sistema de traba muy delicado que tenes que liberar antes de sacar la cinta y volver a trabar cuando la repones. presiona sobre diferentes lados del mencionado conector mientras pulsas las teclas, a veces solo son falsos contactos por suciedad, o en el peor de los casos, alguna soldadura mal, por lo que habr?a que resoldarlo, lo cual es muy delicado y requiere de herramientas y habilidad especiales.
Para la limpieza, te recomiendo una mezcla de alcohol con agua al 50% y pasarlo sin mojar mucho la zona con un cepillo de dientes, luego pasas un hisopo o algun pedacito de trapo para secar bien y lo dejas que evapore, por las dudas unos 20 minutos, podr?a ser mejor mandarle aire caliente de un secador de pelo por un rato.
Dec 09, 2010 | Toshiba Satellite A200-0ET00X Notebook
TENGO UNA COPIADORA XEROX 1012, CUANDO TRATO DE SACAR UNA COPIA TARDA EN CALENTARSE Y NO HACE LA IMPRESION Y ASI UNA SEGUNDA OCACION, HASTA LA TERCERA VEZ QUE TRATO DE SACAR LA COPIA SALE, CUANDO INTENTO...
Esta maquina es viejo, pero si la quiere usar, buenos.
Hay algunos alambres en centro de abajo, limpa los. Tiene cuidado porque los alambres se cebran faci.
Otra cosa es la tinta. La tinta tiene una cosa que media la tinta en el roldono palo. Si esta cabado, no va poner tinta muy bien. Se puede acer copias malas.
Otra cosa tambien es si el papel se tora.
Las jantas pueden ser mal. O otra cosa es si la maquina esta cebrara. Cuando abre la machina, mira adetro donde los dos partes se pegan. Si estran cebranan, el cloche en la atras puede pegra la ariba del metale de ariba de la machina. Usa unas pinsa a planar el metala de el clotche.
Buen suerte! Ojala que entiende esta mensaje.
Aug 12, 2010 | Xerox FaxCentre 1012 Plain Paper Laser
The playback voice is giving eco effect?
Tu problema es el conector de audifonos de tu mp3 sony nwz b142f , lo que tienes que hacer es abrirlo y apretar un poco las placas doradas del conector yo lo hice y ahora me funciona perfecto...
Este mp3 tiene tres tornillos, dos a la vista al sacar la tapa protectora y el otro bajo el plástico de la pantalla donde dice sony con letras grandes tienes que despegarlo con cuidado para no quebrarlo , despues de sacar los tornillos habre cuidadosamente la carcasa para no romper la trabas plásticas.
Una vez abierto evita moverlo mucho para que los cables que van a la bateria no se desconecten.
Para localizar la falla, teniendo abierto el mp3, conecta los audifonos y enciendelo, luego con alguna varilla plastica o de madera delgada(brocheta) presiona las placas doradas del conector hasta suene correctamente, sabiendo la que esta suelta, desconecta los audifonos y presionala suavemente solo un poco, ahora conecta los audifonos, y comprueba que entre sin problema al conector y que se escuchen correctamente.
Para armarlo debes sacar los botones BACK y ZAP y ponerlos cuando tengas todo listo
IMPORTANTE: antes de manipularlo debes descargar la electricidad estática que tengas en tu cuerpo tocando algun metal desnudo que tenga contacto directo con la tierra por ejemplo alguna cañeria de cobre para el agua , para evitar dañar algún componente del mp3.
Por ningun motivo manipules tu mp3 abierto sobre alguna mesa metalica o con herramientas metalicas al tenerlo encendido, si lo haces puedes producir algún cortocircuito y dejar inutilizable el mp3.
suerte.
Atte Daniel Améstica
damesticaz@gmail.com
Apr 15, 2010 | Sony Walkman NWZ-B142 MP3 Player
Resseting
Jun 20, 2009 | Philips DECT 2252S Cordless Phone
Mi monitor se prende y luego se apaga
Mi monitor hp pavilion enciende pero luego sale monotor going to sleep y se apaga. Antes de apagarse se puede leer default en dvi cable. Que ocurre?
Mar 24, 2009 | Computers & Internet
EL VIDEO DE MI PC NO SE ME QUIERE ACTUALIZAR Y POR LO TANTO NO PUEDO VER LAS IMAGENES DE TAMA?O NORMAL. MI BOARD ES BIOSTAR P4M800. NECESITO SABER DONDE LO PUEDO DESCARGAR
esto es super facil
www.viaarena.com yo tube esa board y lo actualice por ahi,
creo que es unichrome pro, debes escoger muy bien las opciones, para que salga la que necesitas, mira las fechas y escoje la mas reciente, yo tenia el driver en mi pc pero hace poco lo borre, como ya no lo necesitaba.
ojo, le das a la opcion drivers, aparece arriba bien pequeño, luego te sale tipo de sistema operativo, escoges el tuyo, luego te sale otra pantalla, sigue los pasos, ve escogiendo tus opciones. es facil
Mar 14, 2009 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
Como cambiar la lampara
si ves la tv por el frente tienes que quitar el grill the las vocinas, es muy facil, agarra el grill y hala hacia afuera, solo tiene unos clips,luego mira hacia la parte central de la tv y veras unas letras negras y tiene la informacion de la lampara.hay 3 tornillos que tienes que quitar(desarmador philips) luego veras la lampara nesecitas un desarmador plano y son otros 3 tornillos.aflojalos y hala la lampara hacia afuera.luego installa la lampara nueva haciendo el proceso alreves. hacegurate de poner el covertor de la lampara antes de encender el televisor. y si te pregunta si cambiaste la lampara preciona enter(cuando enciende la tv en letras en la pantalla.. buena suerte .
hdtvman.
Jul 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Por favor nesecito su ayuda por favor PHILIPS GoGear SA6045
Yo tube el mismo problema y lo repare, ingresa a la pagina oficial de phillips y es acutalizar el DEVICE MANAGER ( http://www.support.philips.com/support/downloads.jsp?userLanguage=es&userCountry=ar ), luego ingresa en la pagina de INFORMACION DE CONTACTO Y ASISTENCIA, ingresa el modelo de tu equipo que en este caso seria SA6045/85 y luego en la siguiente opcion "como se reinicia el reproductor si se bloquea o se detiene", sigue bien las indicaciones y te resultara. yo lo hice de esta manera, abri el Divice manager actualizado, presione el signo + del reproductor y sin soltar lo conecte al pc y presione en el programa reparar. En este paso el reproductor no se enciende pero dejalo presionado como 5 minutos y el programa te indicara que esta listo. Luego desconectalo y trata de prenderlo, quesas no se prenda por falta de bateria a si que conectarlo al pc y veras. Ojala les resulte. (http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=CL&slg=ESP&cat=MP3_PLAYERS_CA&sct=SU00304_SU&grp=PORTABLE_ENTERTAINMENT_GR&ctn=SA6045/85&mid=Link_FAQs&session=20090825220818_200.111.181.38&hlt=Link_FAQs# )
Saludos
marcelo (barracuda)
chile
Apr 24, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips DECT 2252S Cordless Phone Logo
1,322 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
