Question about Samsung Heating & Cooling
Where is filter reset button on the remote of samsung window air conditioner
Sign of ch sign is coming on the display and control panel is not working
chillmaster
  • 104 Answers
SOURCE: Fedders window model A6Y12F2B "New Unit",,only
Take it back to the store. Manufacture defect if it died after only 10 days. Attempting repair or disassembly will probably void warranty.
Posted on Jun 23, 2008
SOURCE: " CH"
if ch error is displayed on your samsung ac . press and hold the up and down arrow mark(in the ac control pannel and not in remote ) simultaneously for few sec untill u get a beep sound from it ... this is a default seting to remind u to clean the air filter
Posted on Mar 18, 2009
SOURCE: samsung bio-sleep air conditioner. 1 ton capacity. the display is keep showing me 'ch'. How to remove that
press the temparature up and down key simulteneiusly for 5 seconds on the unit when it is on.It is CHOKE indicator stating that it is time to clear your a/c filter.It happens after ever335 hrs of use
Posted on Jul 06, 2009
  • 1250 Answers
SOURCE: reset air conditioner samsung aqv12msan
http://nodevice.com/user_manual/samsung/other4/aqv12msan.html
Go to this web site. It has a copy of a user manual. May get the answer to your question as to how to reset.
Hope this does it for you.
Posted on Dec 03, 2009
  • 8 Answers
SOURCE: GE room air conditioner control panel stopped
check that your dip swtches are set right
Posted on Apr 08, 2011
How to make at sign work on asus laptop?
If your @ sign is not working it is probably a regional setting in your control panel. Your Keyboard is probably set to the the wrong layout
This will be slightly different for Windows 7 vs Windows 8 so check the control panel for Regional settings, input, keyboard settings. you will need to change your keyboard layout. If the @ sign is ontop of the number "2" then select US otherwise select UK. That should help.
Aug 31, 2014 | ASUS Eee Computers & Internet
My Acer key board can not display the at sign above TWO key shows inverted commas instead and the hash sign above THREE shows a Pound sign? Please assist
Hold down the ALT(ernate) GR(aphic) key -- to the right of the SPACE BAR on your keyboard.
Press the '2' key.
Release the '2' key.
Release the ALT GR key.
Does an '@' display?
Check that you are using the "American English" keyboard mapping.
Control Panel -> Regional options.
Mar 06, 2011 | Acer NSK8458AN Keyboard
How do i change language on hp 3050 printer
Changing the all-in-one control-panel display language
Use this procedure to print reports or to show messages on the all-in-one control-panel display in a
language other than the default for your country/region.
To change the all-in-one control-panel display language
1. Press Menu.
2. Use the button to select System setup, and then press (tick sign)
3. Use the button to select Language, and then press (tick sign)
4. Use the button to select the language that you want (tick sign)
5. Press (tick sign) to save your selection.
The all-in-one automatically restarts
Jan 29, 2011 | Office Equipment & Supplies
My machine is sharp AR-163 and is showing developer sign and ch sign
developer probably needs changed. CH means you have a cover open
Dec 08, 2009 | Sharp AR 163 Copier
I'm trying to program my ''Comcast'' cable box remote control to operate my byd:sign model d:5032M plasma TV. Comcast does not have a standard 4 digit TV code to use. How can I get the code as there is no...
If your brand of TV does not respond to the remote control after trying all of the codes listed, or if your brand is not listed at all, try searching for your code.
1. Turn on your TV.
2. Press and hold SETuntil the Red Light blinks twice, then release SET.
3. Enter in 9 - 9 - 1. The Red Light will blink twice.
4. While pointing the remote control at the TV and press and release the CH + key until the TV turns off. (Note: You may need to press [CH+] numerous times).
NOTE: In the search mode, the remote control will send IR codes from its library to the TV.
5. Press SETonce to lock in the code. The Red Light will blink twice.
Sep 19, 2009 | byD sign d:5032 50 in. HD-Ready Plasma...
"Ch" is displayed on the display
just press the arrow keys up down and hold it for few sec till beep comes..(on ac scree not on remote)... this indicates cleaning of air filters..
If problem still persists, let me know.
Thanks.
Jun 19, 2009 | Samsung AW1203B Air Conditioner
Control panel not working and no lights
Hi. you will need to replace this non functioning Control Panel asap and, test the light pressure switch for it's operational value. If the switch is OK, simply replace the bulbs.
May 24, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
F-9 code with lock sign coming on
Check for obstruction in door lock mechanism. The celenoid is behind the back panel of the stove.
Nov 20, 2008 | Kitchen Ranges
My ch-dvd 300
ok, the T stands for Title, the C for chapters, look on your remote for a button that says DISPLAY (or possibly RECALL) and press it until the display disappears. you may have to press it a few times. this may not work, but give it a go
Jul 02, 2008 | Cyberhome CH-DVD 300 DVD Player
Heating & Cooling Logo
35 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
