Question about Fisher and Paykel Washing Machines
MS511. 1 & 7 lights flahs, beeping. No agitate or spin
Have a fisher and paykel MW511. Is filling up in short bursts (instead of continuous flow) and won't agitate at all even though it sounds like it's trying too. Will drain no problem, but won't spin. Lights flash 1 and 7 and makes a beeping noise. Anyone know what it is?
  • 713 Answers
SOURCE: No spinning action on my MW511 Fisher and Paykell
Hi just read your posting.Now with the error code you have shown it tells me you have an out of balance fault.To find out if the fault is with the out of balance switch or the motor controller you will need an electrical test meter. the reason for this is to test the switch for conductivity,not to test for power or anything dangerous.Have you or can you borrow an electrical test meter to test the switch?please reply and I can guide you throe the repair of this fault.
Posted on Jun 15, 2010
  • 713 Answers
SOURCE: We have a Fisher and Paykel toploader, smart drive
Hi just read you posting.Could you please confirm the fault code for me.1st push and hold the WASH TEMPERATURE DOWN button then press the POWER button until the machine gives you 2 short beeps,then release both buttons.Now press the SPIN UP or DOWN button until the HOLD and SLOW SPIN LEDs are both on.Now the fault code will appear in the WASH PROGRESS lights.Please reply to confirm which lights are lit.Are they the same as your 1st posting?To get back to normal operation turn machine off at the power point.Looking forward to your reply.
Posted on Jul 05, 2010
sonicboomele
  • 1557 Answers
SOURCE: My Fisher and Paykel Smartdrive 7.5 kg fwon't agitate
when they beep the main p.c.b bord has detected an error on the f/p series the main fault we have found with this is the small icb sensor that runs along side the capstan drive drum try cleaning it if this does not work try replacing the head control p.c.b bord
good luck
Posted on Jul 06, 2010
  • 6277 Answers
SOURCE: Fisher and Paykel Pride MW511 does not spin. Three
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 19, 2011
  • 251 Answers
SOURCE: Hi. I need some info on the fisher and paykel
Hi - I will need the product number found on the sticker in the rear of the machine - the controls has been changed so it needs to be programmed to a 5Kg machine.
I cant help you without that information as there are about 6 methods of doing this, the product number will tell me which is the correct way.
Posted on Jun 27, 2011
Smart drive 051 error code 32
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | Fisher and Paykel Washing Machines
Fisher & Paykel MW511 error code lights 1 and 7 lighting up and beeping
Error code 130 is rotor position sensor faulty or wiring to it.
sensors sell for $25 to $50 on Ebay.
Jan 28, 2013 | Fisher and Paykel GWL11 Top Load Washer
MW511. 2 & 7 lights flash, beeping. No agitate or spin?
Fault code 66 is pressure sensor is faulty
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
Apr 20, 2012 | Fisher and Paykel Washing Machines
good luck
Jul 06, 2010 | Washing Machines
We have a Fisher and Paykel toploader, smart drive 603. After setting up a washing cycle and pushing the start button, the machine starts for a few seconds with the water filling in in short bursts (rather...
Jul 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
F&P Smartdrive 058 filling in short bursts then stopping.
I had the same problem today. shephonos 18 had the correct diagnosis. Out of balance micro switch seized. Situated under the main circuit board. Cherry electric Corp 0.1amp 125 volt sptd type switch. jaycar has them for under $4.
I un-seized it with some electrical cleaning spray, fixed itshort term, no worries.
Thanks Stephanos 18.
May 04, 2009 | Fisher and Paykel Fisher & Paykel Washer
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
11 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
