My LG top load WF-F733PC start and after 7-8 seconds it stop and beep sound started non stop like hang there.. the LED shows Wash & Spin. Please help.
2 Suggested Answers
  • 4 Answers
SOURCE: I'm using LG Fuzzy logic 6.5kg WF-S6607TC.
Check the lid cover. At the edge, there is a plastic housing some sort of a magnet. This is the magnetic sensor for lid cover open protection.
If the magnet is not there, place a magnet at the position on the washer where the housing will come in contact with the washer when lid is close.
Posted on Sep 09, 2009
I have an LG Fuzzy Logic 4.5kg WF-452C Top loader. Put one load on and it worked fine. Went to put the second load on, and the water level lights are flashing and beeping, and the load won't start.
Take all the clothes outside put empty spin program if it finish without problem ur machine has no problem aftem u jusy check the inlet water filter and clean the filter every15 days,,
Apr 01, 2015 | LG Washing Machines
Problem with my LG washing machine WF-S7012DN model - 7 yrs old. Since yesterday, the wash/m starts to wash takes a turn or two and them stops with alarms on and flashing, (first time problem with my...
there is a magnet controlled switch in the top cover lid and the probable cause the magnet is missing.
The best alternative is just keep a good magnet on the top of lid & slowly move the magnet horizontally.At one point the BEEP stops & machine starts to function.
Jun 03, 2010 | LG WFT1071TP Top Load Washer
LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Apr 16, 2010 | Washing Machines
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
LG Washing Machine won't spin, signals that load isn't balanced
Check the drain clean out at the drain pump. If is cloggedm with debris, it will not spin and go off a a long drain error code.
Feb 06, 2010 | Washing Machines
The machine will start a cycle normally, but after the timer reaches a certain point it stops counting down and the machine will continue to agitate until you force it to stop.
Thank you for verifying the model type so many folks post non FAV6800A/FAV9800A questions in this forum machine specific topic area.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
You will need the Service Manual for support. I’m an owner like you with a solid repair skills on the machine and will try to help you DIY the repair if we can ID the issue through troubleshooting.
Do you have this condition in all wash cycles? Will a Quick Wash cycle complete? Do you see the Cycle Status LED ever indicate the machine has moved to the Spin Cycle during the wash cycle? This could be a Control Board failure but we need to troubleshoot.
I want to make sure the Wash basket will spin up with a Spin Only cycle selection. Can you select a Spin Only cycle with a empty wash basket. I would release the washer top so you can observe this test. I want to rule out a broken Clutch large wrap spring.
Page 33 of the Service Manual will show you how to release the washer top from the base. In Spin Only cycle raise the top just enough to make sure the wash basket is rotating Counter Clock Wise – CCW with the Spin Only cycle selected and operated.
If the above test doesn’t indicate an issue I would like you to try the Quick Service Cycle test on page 15 of the Service Manual and see if your FAV6800A will pass that test with no clothes in the washer. When you put the machine in Service Mode press and hold simultaneously the Enviro Plus and Spin Only keys until the machine beeps and the LED display reads 00. Then press Wash/Rinse Temp to start Quick Service Cycle test. Did the test complete with a PA indication in the display? It will only display the PA code for a few seconds. End of cycle will beep washer will unlock and Cycle Status LED will indicate complete.
Waiting for your reply….Rich
Dec 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My model WF s7012dn is problem.... whenever we start the machine, it shows the water level, it also starts for 2 seconds and then give beep sounds with wash and spin light flashing......
Suggest you remove drain pump out and open it up to inspect for any items stuck in the pump. Try and check pump seperately as well if no obstruction found.
Sep 21, 2009 | Washing Machines
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
