Question about Toto Home
How do I stop a washlet from leaking into bowl?
How do I stop a small slow leak into bowl of 1 pc Crane toilet?
The seat where the flap sits could have a nick in it. The flap might not be aligned properly. A temporary fix is to put a small amount of Vaseline on the seat and that should stop the water leak.
Aug 30, 2014 | Home
I have a tecumseh carburator .It is the type with the float in the bowl.My problem is I can not get the carb to stop leaking gas .The float and bowl have both been replaced.It still continues to leak.I am...
Does the bowl have a drain screw that could be leaking? There may be a gasket there.
If it is leaking from the top flange, it sounds like the float is not stopping the gas.
Try taking the bowl off and holding the float up; does that stop the gas?
Do you have to push the float up beyond horizontal before the fuel stops?
If so, the plunger may have to be adjusted higher to reach the seat.
Dec 09, 2010 | Craftsman Garden
The water does not squirt out of the bidet wand
My Toto Washlet has stopped squirting water. Any ideas for fixes?
Dec 02, 2010 | Toto Washlet S400 for Power Gravity...
Installing Washlet toilet seat on Toto toilet
The water supply line on your Aquia toilet was installed before the tank was mounted to the bowl and the tank must be removed to change it.
Jun 02, 2010 | Toto CST414M-51 Aquia Dual Flush Close...
Toto C100 Toilet Washlet Seat
There are two types of bowls as far as toilets are concerned...elongated and round front. The seats are interchangable as long as there isn't anything different in the way the seat is mounted to the toilet. As far as I know and my experiance with both brands, I can't see any reason why it would not work.
Apr 05, 2009 | Toto Elongated Washlet C100 Toilet Seat -...
TOTO WASHLET LEAKS!
from where?? If it is leaking on to the floor from the base of the toilet you need a new wax ring installed,,, if the water is comming out from where the tank bolts to the bowl you need to get the proper kit since it;s a toto they are one of a kind and don't have any universal kits that will work, call or e-mail toto tell them you need the tank to bowl kit, might as well tell them to send the flush valve also and just do the whole thing good luck
Feb 20, 2009 | Toto Elongated Washlet C100 Toilet Seat -...
Home Logo
41 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
