Question about Conair GS19 Deluxe Handheld Fabric Steamer
How do I get the steam to come out? Both the green and red light is on and it makes a noise when I press the steam switch
My Tefal pro express inon does not steam the generator not making noise and red light comes on
Maybe the steam switch if broken or not fitted correctly dso you can open and inspect it
Sep 11, 2014 | Irons
Steam Station FCL-SS167 Purchased today followed instructions for first time use when plugged in green indicator light does not light up and it does not steam unless surge button is pressed then it makes a...
NO IT NORMAL , THE WTAER HAS TO REACH 100,dec IE , BOILING POINT BEFORE IT CAN STEAM , NEXT TIME WAIT A BIT LONGER AND YOU SHOULD GET THE GREEN LIGHT .
Nov 05, 2009 | Irons
I have a Swan S15040 steam generator iron, the stand by light is permanently flashing, no matter what temperature setting i put the iron on. No steam is generated. I have tried holding the steam button...
I had same issue , now , once you turn the unit on , you should see displayed 3 steam jets and the flashing standby , turn the dial on the iron to max ,press the steam button on the machine to max steam , leave for a minute or so , now press the steam button on the iron , does it make a noise ? if it does , slightly raise the whole front end of the unit ( easier if you have the iron on the worktop and not on the unit !) for a minute then try and press the steam button on the iron again . I think there is a bit of an issue about the conection between the water tank and the filter . This solved my issues and i do hope it will help you .
Jul 18, 2009 | Black & Decker Steam Generator SG200 Iron
It gets hot but there is no steam or noise from it also the red standby button is flashing
i have a tesco steam generator iron, model no. sgc2 it has no steam or noise but red stand by light is flashing
Jul 11, 2009 | Irons
Need manual for swan steam generater iron model s15040
you have probably solved this by now but
I just got the same model new
switch on instructions as follows
press and HOLD the POWER button for 3 seconds to switch the unit on
once temperature has been reached, press and HOLD the steam button on top of the iron for up to 20 seconds
this will prime the steam pump and only has to be done once for each ironing session
the pump noise will stop once it has been primed with water
hope this helps if still needed
if you need the user guide, let me know, I'll scan it for you
Wendy
Jun 29, 2009 | Black & Decker Steam Generator SG200 Iron
GREEN LIGHT INDICATOR DOESN'T LIT WHEN PRESSING
Lost contact maybe you dropped it ,that's why the wiring inside are loosen.By the way before u make troubleshoot of your appliance try to cheeck if there is a warranty.Then if there's not that's the time you make your own troubleshoot.
May 18, 2009 | Irons
Russell Hobbs Steamglide 2200 - no steam
Same with mine! What you have to do is keep taking the water cannister off and pushing back on until its lined up correctley. Also have the whole unit at the same height as the ironing board, that should do it! Can you help with filters? I cant find them anywhere.
Mar 23, 2009 | Irons
Tefal express
The rumbling noise is the steam generator working - make sure the water reservoir is full and press the on button. Inside the machine will be doing its stuff and generating steam - this is the noise that you are hearing and when you press the release switch (normally under the handle of the iron) then the steam will be expelled. The noiose comes on and off as it is making more steam - this is normal. I use ordinary tap water but don't have hard water so have no problems - also make sure you empty out the base occassionally - should be a large pressure screw behind the cable holder - make sure iron is off and cold before doing this and then shake it out and residue bits will come out - then flush out with water. These are brilliant to use and you will wonder how you managed before having this - Happy ironing.
Aug 23, 2008 | Irons
Conair GS19 Deluxe Handheld Fabric Steamer Logo
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
