Question about Imicro KB-US819EB Basic USB English Keyboard Black - RETAIL
IMicro KB-US819EB Basic USB English Keyboard shuts down if not used for several minutes
Why is my laptop not recognizing imicro IM25COM-BK?
imicro IM25COM-BK is an external Hard Drive for USB 2.0. 1. Did you install the Driver which came with your Drive? 2. Are you sure it is connected to an USB 2.0 port? Some computers come with USB 1.1 !
May 17, 2014 | Imicro 2.5 SATA/IDE ENCLOSURE BLACK...
Won't read keyboard
usb or ps2 keyboard ? might need to be enabled in BIOS
If you want to use a USB keyboard to access Windows command prompt options, make changes in the BIOS (Basic Input/Output System), or to operate legacy operating systems, you must enable support for the device inside the BIOS.
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Turn on the computer and press the "Delete" key several times as soon as you see the initial boot or company logo screen. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Feb 15, 2013 | Dell OptiPlex GX110 PC Desktop
Chicony Keyboard KB-0108 combined Russian/English Keyboard will not install in my new Windows 7 desktop. Have installed updated driver from website but this still does not allow it to be recognised when I...
Seems your keyboard is disconnected from computer. Please try use the adapter on desktop round connector just ti see how your keyboard woks. Change your adapter if malfunction
Jan 09, 2011 | Chicony KB-2961 Keyboard
Brought a CS62US and Mircosoft KB with mouse. When USB combo plugged on the left USB, only KB is worked together with switching function. When USB combo plugged on the rigth USB, both KB & Mouse worked...
Unfortunately, this switch has a dedicated port for keyboard that listens for the keyboard keystroke. You MUST plug the keyboard into the dedicated keyboard port on the KVM switch for the hotkeys to work. I recommend putting the mouse that comes with your keyboard to the side, and using another mouse, plugged into the dedicated mouse USB port on the switch. Not the prettiest solution, but some of those mouse/keyboard combos have some funky hardware!
Feb 17, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
Cannot connect my keyboard to my all-in-one IBM desktop. Does it need a specific type of keyboard? The all-in-one was given to me by a friend without the keyboard. I notice the portal where the keyboard is...
It uses a USB Keyboard or a Standard PS2... if you have a USB KB try a different USB Port, shouldnt matter which one. Also PS2 KB ports can go bad. Test with a different KB if you can. The PS2 (purple KB Port) is located on the right side front.
Dec 30, 2009 | IBM Computers & Internet
Dell wireless mouse and keyboard-no instructions
Most Bluetooth keyboards and mice are just Plug-n-Play and does not require any driver installation. You need to isolate the problem, please follow the steps below:
1. Make sure that the wireless adapter of your wireless KB and mouse is properly connected to the USB port of the computer.
2. Make sure that the USB ports of your computer are working.
3. Use fresh batteries for the KB and mouse.
4. After connecting the wireless dongle to the computer, turn on your KB and mouse (there should be an ON/OFF switch underneath).
5. Briefly press the connect button on the wireless dongle and then hold down the connect button underneath the mouse for five seconds and then release it.
6. Do the same steps for the KB.
Have a good day!
Jun 27, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Mouse Freezes
I have the same problem in Vista, I found a true and working solution apart of droping the mouse to the trash, ok, go to... http://www.a4tech.com/ go to the english version if you dont speak chinese, then find the driver for the mouse model ***-49Z, and there is the solution, GE isnt the builder of this mouse.
Take Care.
HMMxD
Greetings from Mexico.
Jan 12, 2009 | GE HO97769 Deluxe Optical Mouse
USB Devices not recognized
Go into bios by pressing F2 on boot and make sure that usb support is enabled. If it is then boot and go to device manager and uninstall the usb devices, then try to reinstall. Instead of just updating the drivers.
Nov 29, 2008 | Foxconn 6150BK8MC-KRSH Motherboard
Imicro KB-US819EB Basic USB English Keyboard Black - RETAIL Logo
67 people viewed this question
Top Imicro Computers & Internet Experts
David Payne
David Payne
Are you an Imicro Computer and Internet Expert? Answer questions, earn points and help others
