Question about Ricoh Aficio 1085 Laser Printer
Clear memory ricoh aficio 1027 - Ricoh Aficio 1085 Laser Printer
Bubbabear64
  • 2794 Answers
SOURCE: Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Posted on Jun 19, 2008
NALDZ
  • 38 Answers
SOURCE: Ricoh Aficio 2016 memory is full - can't fax
try enter 5-810
Posted on May 13, 2009
SOURCE: How to set up my Ricoh Aficio 1027 to be a scanner?
NECESITO QUE POR ESPAñOL ME FACILITEN LAS INSTRUCCIONES DE COMO MANEJAR ESTA FOTOCOPIADORA
Posted on Jul 11, 2009
  • 22 Answers
SOURCE: Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Posted on Aug 09, 2009
  • 46 Answers
SOURCE: Ricoh Aficio SP C410DN toner error.
Did you follow the instuctions to shake gently then remove all tags prior to placing the toner? Is it a toner/drum unit. look underneath if theres a green drum. After market toner will not work.
Posted on Aug 28, 2009
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
How to reset the user code?
there is two ways to achieve this, either enter servisse mode using yellow 1 0 7 and stop (hold stop for a few seconds) go to copy sp the go to 5 mode and the scroll to 801 memory all clear... this will reset the machine completely... if you not feeling so brave inside 801 there is sub menus just stroll down to clear UCS
May 15, 2014 | Ricoh Aficio 1027 All-In-One Laser Printer
How do you clean/service a Ricoh Aficio 1027?
you had to have the ricoh 1027 manual & can be download from any technical ricoh forum esp from copytech.net if you lucky, you can download for free
Sep 12, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
Driver af1027 for scanner microsoft x764
Good afternoon from Chicago, shiva262,
I'm not sure from your post above, but it appears that you are looking for a driver for your Ricoh Aficio 1027 All-In-One Laser Printer. If that is in fact the case, try the following steps to resolve your problem:
1. If your Ricoh Aficio 1027 All-In-One Laser Printer is connected to a Windows-based PC, use Windows Update to try and locate, dwnload and install the correct driver software.
2. Navigate to the following links and follow the instructions:
http://www.ricoh-usa.com/downloads/local/manuals/multifunction_bw/aficio1027.pdf
http://www.ricoh-usa.com/downloads/popup/popup_manuals_drivers_download.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x1022_27/x1022_27en.htm
I hope these are helpful in solving your problem. Good luck!
Regards,
Enolram
Mar 01, 2011 | Ricoh Aficio 1027 All-In-One Laser Printer
I have a ricoh aficio 1027 with fax option and i want change the recieve function to auto answer with 5 rings
1. Download driver from http://support.ricoh.com/bb/pub_e/dr_ut_e/0001153/0001153018/V3100/r29694en.exe
2.If that doesn't fix the issue immediately try http://support.ricoh.com/bb/pub_e/dr_ut_e/0001154/0001154861/V861/r30275en.exe
Sep 11, 2010 | Ricoh Aficio 1027 All-In-One Laser Printer
How to convert ricoh aficio 1027 from german to english?
User manuals are available in pdf from ricoh-usa.com
Nov 25, 2009 | Ricoh Aficio 1035 Copier
SC543 ricoh Aficio 1027
• Fusing thermistor defective or out of position
• Fusing lamp open
• Fusing thermostat open
• Poor connection of the fusing unit
Inspect all the elements before mentioned, soon presses total clear (Yellow Key) 1 0 7 and Maintain pressed clear stop key (orange key) more tan 3 sec. Enter SP 5-810 (SC code reset),
select execute, select close. Exit SP mode, turn the main power
switch off then on.
If the problem continuous the problem can be in the Power supply board, can be defective.
Aug 10, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh 1027
There are two possible options:
Printer Module (B461)
This requires the 64MB memory option (G579).
Printer/Scanner module
This requires the 64MB memory option (G579) and the NIB (G574).
Good luck and please rate me, thanks.
Nov 04, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1085 Laser Printer Logo
21 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
