Question about Garden
Troy-bilt pressure washer shoots water out the side of pump and seems to have low pressure
Why does my Troy-bilt 2700 pressure washer spray water out of 2 small hoes on side of pump housing and seems to have low spray pressure
How do i prime the pump on the soaper or chemical dispenser on my troy built 2550 psi pressure washer?
There is no need to prime. But you do need to use the black spray nozzle to get soap to siphon out.
if that doesn't solve the problem let me know
Oct 26, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Need instructions on the use of the soap dispenser on a 2700 psi B&S power sprayer
Dear Audience,
Please go to the link provided and view the on line PDF manual. On pages 16 and 17 you will find the directive to apply detergent into the system and maintaining successfully.
http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/020292%20man.pdf .
If you are having any difficulty , please check out this direct source Troy bilt Pressure Washer Support ManualsOnline com .
Fare. Well.
Sep 24, 2014 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
My troy-bilt 20486 pressure washer runs but does not spray water
OK just so we are on the same page.
You did turn on the water (right?)
Jun 12, 2014 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
Why the water is running from detergent siphoning tube?
The siphoning mechanism on almost all power washers use "The Venturi" effect to suck up the detergent. Basically, there's no pump...the force of the water passing the siphon hose causes a vacuum which draws the detergent up the tube. There's a small ball that is supposed to fall and block the tube when the trigger is released so it sounds like it got jammed up in there somehow. You could it apart and free it up but I would recommend just purchasing an external detergent dispenser. Home Depot carries them for about 15 bucks. They allow you to use soap with high pressure and bypass the always problematic siphon system.
Jun 08, 2014 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Jul 09, 2009 | Garden
Troy bilt pressure washer
You need to replace parts 37 thru 41 on the pump breakdown.
Click this link for the breakdown.
Mar 17, 2009 | Garden
Turn Black cone shaped valve clockwise to increase pressure there will be a small +/- plus will increase and give you pressure.
TK U
Mar 17, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
108 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
