Question about Water Heaters
Superflue gas water heater
Why does my enery efficient water heater keeps going out
  • 252 Answers
SOURCE: water heater replacement
Direct vent water heater is your best option with gas - may be best to stay with electric - today's electrics are more efficient.
Posted on Mar 12, 2009
co7196
  • 3433 Answers
SOURCE: water wizard 10P pilot light keeps going out
If the thermocoupler is defective the gas to everything is shut off. The coupler is the bulb that sits ib the pilot flame If it doesn't heat up it will sense no pilot and shut the gas off. They don't cost much and are easy to change. Good Luck, Ned
Posted on Sep 24, 2009
heatman101
  • 43501 Answers
SOURCE: My Superflue water heater is flashing Eco failure.
The ECO is short for emergency cut off.
The ECO is either tripped or it went bad. You may be able to reset it or you will have to contact a rep the sells your heater to get a new part. Some are resetable and some are not... not sure which you may have. The reset ones will have a little red button to push in the center.
The next rpoblem is to figure why the ECO went or tripprd in the first place. There is probably a reason or a cause. When you refire it make surte you donot have flame roll out and proper venting. Also make sure the the thermostat works and is not letting it get too hot.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 08, 2009
  • 48 Answers
SOURCE: Loud blower on my new Rheem Power Vent 2 water heater
find out if it does the same noise with the venting disconnected
Posted on Jan 16, 2010
  • 351 Answers
SOURCE: no power at all to my superflue water heater
Hi, first check and try and reset the breaker feeding the water heater. That should be a two pole breaker. The next thing to check is the red safety button on the top thermostat control. It is under the top access panel of the heater, along with a good amount of insulation. Push the red button to reset the safety switch. If these do not remedy your situation, then you will need someone on site to check the water heater in more detail.
Posted on May 03, 2010
I have a GSW Superflue power vented electronic ignition. It lights and fires up for 15sec then goes out. Keeps doing this. When I open the two front covers the flame stays lit and strong. As close the...
definite air intake problem . check the filter at the bottom of the unit. and keep the area around the unit clear and clean to prevent recurrence
Jan 28, 2015 | Water Heaters
Propane hot water heater
Troubleshoot service manual by type of gas control valve
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Post question on following link:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment and say what you discover
Jun 28, 2013 | Water Heaters
Bosch 125fx heater barely heats water
1) Recommend replacing tankless with ordinary tank-type gas water heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://hometips.me/Mar/Which-is-best-gas-water-heater.pdf
2) Tankless cannot be exposed to more than 11 grains hardness in water or unit will fail within 2-5 years. Water softener is required.
http://hometips.me/Tls/Battelle_Water-softening-research.pdf
3) Descaling tankless water heater each year will not restore functionality, or restore efficiency of tankless, nor restore full efficiency to tank-type gas water heater.
4) Bradford White side-by-side testing research comparing their tankless with their tank-type shows that tankless will save $1-8 per month on energy bill vrs ordianry tank-type ....but conclude that tankless 'fall far short of payback' due to maintenance, repair, installation and replacement costs.
Study compared full cost, and not just monthly energy bill, since All costs are energy.
Feb 16, 2013 | Water Heaters
No power at all to my superflue water heater
Apr 05, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Superflue heater will not light
The self igniter, or thermal couple is bad.
Mar 27, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water heater replacement
Mar 10, 2009 | Water Heaters
Water heater with electonic igniter will not work in power outage
What type of heater is this? I need to know the model name and make and then we can go threw the process of how to do it. Most gas heaters do not have power to them and I only know of a few tankless heaters that do.
Feb 08, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
How to Replace Water Heater
Before you rush out to buy a new one, you'll want to find out which type of water heater is most efficient. Your decision will be heavily predicated upon whether your home is set up to run an electric or a gas water heater. One general piece of advice is valid regardless: Don't assume you need to buy the same size water heater as you currently own. It is possible that you can install a smaller water heater if, in recent years, you have replaced other household appliances, such as dishwashers and washing machines. Newer products often include power and water saving features, and thus, you might be able to buy a smaller water heater that will cost less money and use less energy. Whether your requirements dictate gas or electric, learning which models are most economical is fairly straightforward. Federal regulations require that water heaters display Energy Guide labels. These labels include the Energy Factor (EF) that measures the overall efficiency of a model; the higher the number, the more efficient it is. The labels also will have a First Hour Rating (FHR) that indicates how many gallons of water that model will produce during a peak usage hour. Additionally, you can get energy savings information and rankings on some of the most popular brands of water heaters through consumer organizations and reports. A word about on-demand water heaters: On-demand water heaters, also called tankless water heaters, or spontaneous water heaters, can be fueled by either gas or electricity. This design is much more efficient than standard models. An on-demand water heater is smaller and does not keep a reservoir of heated water on hand for anticipated use. Instead, as soon as you turn on the faucet, the fuel source fires up and the hot water is delivered. This type of water heater requires some refitting during installation in order to provide powered venting and possibly a larger gas line, so it is best to hire a professional to do the job. On-demand water heaters are especially practical for small apartments or single-person households. Larger households will require multiple units. Once you have installed your new, energy efficient water heater there are even more ways to increase its efficiency. Remember to purchase insulation blankets, lower your thermostat, add an overnight shutoff timer, install heat traps, insulate your pipes, and be diligent about regular maintenance. If you take these steps, you can rest assured that you will have the most efficient type of water heater available.
Aug 27, 2008 | Emerson InSinkErator W-152 Point-Of-Use...
Water Heaters Logo
20 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
