Ntfs.sys. corrupt or missing
Help i planned on reinstalling windows. and Post installs fine, but after i restart. and the Xp load scren comes up. I instatly get a Blue screen, saying Ntfs.sys is corrupt or missing.. I've tried different HDDs, Pulling all added Hardware out, of the Pc, and Even bought a new Power supply. I still have the same problem.
Any help would be appreciated.
  • nadiasaku Jun 23, 2009
    I tried 4 different Hdds, and one was a brandnew sata, But i could look.
    Its a custom Pc, with a Pcchips. Aeegv. 1.0 and a Dual core athlonX2 4800+, with 1 gig of ram
    President:
  • 1,996 Answers
Use this excellent article to help troubleshoot the stop error codes. You may have a bad system partition. see here
Also good resources are links here, here, And another resource once you get window up again here.
If you can get it to run from a recovery cd, try to run chkdsk. Instructions here, here, and here. Instructions for recovery console here.
You may also search xp clean boot and partition or fdisk, or see here.
Also may want to check through the links at the end of this article, and here or here for additional info that will save you some time with the reinstall.(See slipstreamed sp3 install)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 23, 2009
    Scholar:
  • 124 Answers
This is a corrupt file; either your hard drive is failing or you've (perhaps) had a power failure lately.
You need to run some diagnostics over your hard drive to discern if it is failing or if you just corrupted a file or two ...
You don't mention your make or model of computer, so I cannot help you find the diagnostics for your drive ...
You may need some additional help from someone who can put their hands on your computer. They can see the make and model and pull up the appropriate diagnostics for it.
I cannot boot up my Microsoft Windows 7 due to a corrupt ntfs.sys file. I can access command prompt through computer or cd. Please help!
As you are able to access command prompt, you can run the "System File Checker" tool to repair/ replace the corrupted ntfs.sys file. To do this, follow the instructions below:
1.Restart your system and tap F8 key repeatedly until you see Advanced Boot Options menu on your screen. If you miss reaching the screen in the first attempt, repeat this step until you reach the screen.
2.On the Advanced Boot Options screen, select "Safe Mode with command prompt"
3.In the command prompt window, type "SFC /scannow" (without quotes).
Note: There is a space between C and / in the command above.
This will scan all your protected system files and replace the corrupted files with a cached copy stored in your system.
Important: Please do not close the command prompt window until the verification is 100% complete. After the process is completed, the scan results will be displayed on your screen.
To know more about System File Checker, you can refer to the following Microsoft support page:
http://support.microsoft.com/kb/929833
Hope this will help you.
GuruAid.com
Aug 17, 2014 | Computers & Internet
System32 drivers ntfs sys
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command):
  6. --->cd \windows\system32\drivers
    --->ren ntfs.sys ntfs.old
    Note This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  7. At the command prompt, type the following command, and then press ENTER:copy cd:\i386\ntfs.sys drive:\windows\system32\drivers
    Where cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  8. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  9. Restart the computer.
May 17, 2014 | eMachines Computers & Internet
My daughters Asus eee pc MK90H notebook says windows could not start because system 32 is missing or corrupt. It says to use the original CD Rom, which obviously we dont have. Help what do we do?
To restore a missing or corrupt ntfs.sys file you must have the Windows XP CD and follow the below steps.
Insert the Windows XP CD into the computer and restart the computer.
As the computer is starting make sure to press a key to boot from the CD.
In the Windows XP setup screen press the 'R' key to run the Windows Recovery Console.
If prompted enter the number of Windows installation you're repairing.
At the command prompt type the below command.
copy x:\i386\ntfs.sys c:\windows\system32\drivers
* In the above example you would replace x: with the letter of your CD-ROM drive. Many computers have the CD-ROM drive configured as the D: drive.
If ntfs.sys is still on the computer you'll be prompted if you wish to overwrite the file. If prompted, press the Y key for Yes to overwrite the file.
Once the file has been successfully copied remove the CD and reboot your computer.
Do NOT use an OEM "Recovery Disc". Only a valid Windows XP media will work or a disc from the OEM that says "Operating System" may sometimes work depending on how the manufacturer labeled the CD.
Hope this helps. Let me know if you need more information Thanks
May 11, 2011 | ASUS Eee PC 1000HE Netbook
Windows did not start ,drivers missing
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer
Mar 03, 2011 | Computers & Internet
I have a dell inspiron 8500. Occasionally it would go through post and come up with disk read error press ctrl alt del to restart then it came up with the ntfs.sys file was missing. I manually reinstalled...
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
Jan 12, 2011 | Dell Inspiron 8500 Notebook
Ntfs is missing
  1. Use the Windows Vista startup disks or the Windows Vista CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows Vista installation using Recovery Console, press R option.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows Vista CD, and drive is the drive where you installed Windows Vista .
  7. Remove the Windows Vista CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
  9. rate me 4 thumbs up please
Jan 10, 2011 | Microsoft Windows Vista Home Premium with...
Acer Desktop Veritron M460 will not load Windows XP or Vista!
This problem may occur if the Ntfs.sys file is missing or becomes corrupted when you convert your hard disk to NTFS To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, anddrive is the drive where you installed Windows XP.
  8. Restart the computer.I hope this helps.The other thing I can think of is maybe your harddrive needs a raid driver.If this is a sata drive and an old version of you os,the sata driver may not be already on the disk and you will have to insert one.Let me know if the first solution works,if not we can try the raid driver.
Apr 08, 2010 | Acer Veriton M460 Micro Tower Core 2 DUO...
Won't finish boot because bad or missing system32/drivers/ntfs.sys file
There's a few ways to fix this. Easiest way is to just reinstall your operating system. That will wipe out everything and i assume you have data that you don't want lost.
Here is an alternate route. That file is stored on the disk in the I386 folder. Below is a link with the directions.
http://support.microsoft.com/kb/822800
Be prepared, there is still a chance you could lose your data, but the above link gives you the best chance at fixing the problem.
Oct 26, 2009 | Microsoft Computers & Internet
I am having trouble running setup on my desktop
Aug 28, 2009 | Computers & Internet
System32.ntfs is missing and corrupt
Boot into recovery console, and at the c:\windows prompt type: cd system32 cd drivers ren ntfs.sys ntfs.old If the ntfs.sys file is there and corrupt this will rename it. If it is not there, then it was missing. At the prompt type: copy e:\i386\ntfs.sys c:\windows\system32\drivers\ntfs.sys good luck
Mar 19, 2006 | Apple Power Supply 344 Watt PowerMac G4...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
