Question about Frigidaire Microwave Ovens
FrFMB136G1Bigidair model numbers - Frigidaire Microwave Ovens
  • Official Brand Answer
  • 2,267 Answers
Hi Friend, thank you for your post!
I see that you have a Frigidaire microwave, FRFMB136G1; however, it appears that your model number is invalid. You can typically locate the serial tag (which lists your model number) on the front of the oven, in the lower left corner as you open the door. Are you seeking an Owner's Guide or is your microwave experiencing an issue? Please describe what your appliance is doing so that I can assist you better in pinpointing the problem. Thank you! - Z
Posted on May 20, 2014
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
Screw size
316545301 is the part number of a door handle.
That handle fits more than one model, and the in manual I looked at that had that handle, the dimensions of the screws were not described.
So you would have to look up the screws by part number in the appropriate exploded view for your specific model.
Replace the XXX in the URL below with your full model number from the tag in
or on your unit, or simply click the link and enter your full model number on
the resulting page.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KHMS155LSS3&siteCd=WHRCOM&userType=Consumer
You can order parts from the Pros here.
Apr 25, 2013 | Frigidaire Microwave Ovens
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
I purchased a house w/ a Jenn-air elect. drop-in range. The Model # is 87946 or 87847. I believe the range was originally purchased in 1975. I am in need of an instruction manual .
Neither of these are a typical Jenn-Air model number. http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US suggests that the model number is on the back wall under the burner on the right side of a drop-in cooktop. For a range the model number is often on the frame inside the oven door, below the vent or on the back of the top of the range.
87946 or 87847 are the part numbers for the cartridges (the elements or the surrounding housing).
Look at the model number locations at the "Help me find my model number" link and try to locate a model number on your range. Then enter that model into the search box. The manual is probably available with the correct part number. Most Jenn-air electric cooktops start with JEC in their model number.
I hope this helps you locate the manual.
(I did try JEC87847 just in case you left off the leading alphabetical characters.)
May 08, 2011 | Jenn-Air Microwave Ovens
The turntable support, brown plastic with 3 arms is broken. Where do I get one.??
Your model number is not complete. On the end there should be two more letters (color code), and another number. The number is changed when something on that unit is changed. I tried a few different model numbers and they all came back with the part number 8172018. The price is about $40.00, so you should get the complete model number. It's the number on the unit itself, not the one on the book . If you're a gambler, any appliance store can order one, or you can enter the number on a search, but look at the addresses of your search results to see that it is an appliance related business.
Hope that helped you.
fil
Mar 01, 2011 | KitchenAid KCMS185J Microwave Oven
I bought a microwave oven and it only shows "SHARP CAROUSEL". Where would I find the model number? Thank you.
the model number is located at the back of the microwave in the middle, you will see the nameplate that shows the model number and the serial number.
Feb 06, 2011 | Microwave Ovens
I have been given a Sanyo Fan Assisted Oven 1200w / microwave 900w but no instruction manual. Can you help?
We can most likely help you but need and exact model number so we can help you try and find you the correct manual.
I am going to post 2 links that you can use your model number to try and download a manual. In the case of these manuals if you have a model number that is close to your model number it will work for you.
http://us.sanyo.com/Customer-Support-Owner-Manuals-Locator
You will need your model number.
Also try here:
http://kitchen.manualsonline.com/manuals/mfg/sanyo/emc6786v.html
If you are in the UK you will need to use this link:
http://uk.sanyo.com/support/Instruction-Manuals/
Thanks for choosing FixYa.
Kelly
Aug 27, 2010 | Microwave Ovens
I am also not able to locate the 0M75P(31) magnatron. I found a 0M75S. Is this compatable?
what is your full model number,, disregard any numbers on the part itself as most are not part numbers, and official ge part number would start with a W an example would be wb26x10023... i just made that up ...
to get your part number get the full model number on sticker inside, then u could go to sears.com to thier parts and service section, lokk up model number and get part number for magnetron hope this helps
Feb 06, 2010 | GE JE1540 Microwave Oven
The glass plate in my microwave broke.The model#mv1515B THE SERIAL#202kmo1221
Searspartsdirect.com has the tray for $36.99. Just type in your model number in the "Search By Model Number" block and look for item number 501 under the "Interior Parts 1" heading. (Part number 1B71961F). I hope this helps you.
May 05, 2008 | Microwave Ovens
Kenmore spacemaster microwave Auto recipe 300
If you didn't locate that model number yet, the number should be 5648698510. I have the same unit and just had Sears do a minor repair on it. Luckily, some but not all parts are still available, so check the Sears Parts site to see if what you need is available.
Mar 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
