Question about Frigidaire 7 Cu. Ft. Stackable Electric Dryer Classic White FASE7074
Stackable frigidaire dryer
Would there be any resistance in dryer motor & if it's 0 is it dead?
    Scholar:
  • 177 Answers
The motor winding won't have a large resistance but should have some. Be sure and unhook wires and set your meter to the lowest setting and 0 it. Be sure you are checking the correct connections.
Posted on Jun 02, 2014
4 Suggested Answers
  • 686 Answers
SOURCE: irregular squeaking from stackable dryer
Post your make and model please. Sounds like the rear drum bearing is dried up
Posted on Mar 02, 2009
localwonder
  • 6784 Answers
SOURCE: my frigidaire stackable dryer wont turn on when i
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch will not activate and the dryer will not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever.
I would also check the thermal fuse as well. it is located on the vent duct or blower housing. If this fuse is damaged or tripped, it will not allow the dryer to run as well.
Posted on Jul 20, 2009
SOURCE: I have a stackable Frigidaire Gallery Dryer. It won't turn on...
turn the start and it's like the drum gets stuck. then starts smelling like burning.
Posted on Mar 20, 2010
I have a stackable frigadare w/dryer. Washer works great but the button to start the dryer just hums. Belt is ok.
It seems like this dryer need new dryer motor
In order to be sure ,take belt off and try to start dryer ,if dryer still humms it is motor problem for sure,
Jun 04, 2014 | Frigidaire Washing Machines
Dryer won't start
have you left the unit unplugged for one night and tried to start??
doe sit make any humming noise when trying to start
Aug 25, 2008 | Frigidaire GLEQ642A Electric Dryer
What's the resistance value in stackable dryer motor model fex831fs2?
There should be some for both the motor and the heater coil. Don't know how much don't have schematic. Hope this helps
May 18, 2014 | Frigidaire 7 Cu. Ft. Stackable Electric...
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Mar 05, 2010 | Frigidaire Dryers
My dryer (frigidaire stackable washer/dryer) just stopped working, the washer is fine, but when I start the dryer nothing happens. I set the time and push the button and NOTHING.
Howdy: The circuit breaker could have popped in the motor. Maybe the selector on/off switch has gone south. Will need a AC meter to check voltages from switch to motor. Doug
Dec 09, 2009 | Frigidaire Dryers
I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
Sep 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Belt installation whirlpool stackable
thats funny cause they dont have belts
most have motor couplings that will break and it wont spin
if it still agitates its gotta a motor coupling
Jul 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire stackable washer-dryer
I would check the manual.
Mar 22, 2008 | Washing Machines
Frigidaire 7 Cu. Ft. Stackable Electric Dryer Classic White FASE7074 Logo
56 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
