Question about Exercise & Fitness
Treadclimber tc5000 shock leaking fluid - Exercise & Fitness
SOURCE: the machine will quit wright after you start and
Had my TC5000 for a year and this is the first time this happened. I use it everyday. Googled "Bowflex Teadclimber error codes" and found this link  download.dfxi.com/supportdocs/AM/Bowflex/BFX_TC135_AM_2008.pdf which is a pdf manual.
I'm going to try this fix now, hope it works for you and me
Here's what it says for ERR LS:
Belts stop turning and “err LS” or “err OS” is displayed Calibration Re-calibrate machine using Owner’s Manual calibration procedure. Speed sensor 1. Cycle power off and on. 2. Put the machine in calibration mode (see Calibration procedure in Owner’s Manual) but do not start the calibration routine. 3. Remove right rear plastic cover to view LED diagnostics on control board. Caution: Machine is on. Current is active!! 4. Locate LED D on the motor controller board. LED may be lit or unlit. 5. Manually advance the treadle with your foot, and check if LED D is blinking. 6. If LED D is not blinking, then the speed sensor is not supplying a signal. Check that the speed sensor wire is plugged into the motor controller board, to the connection labeled “P1”. Check connection of speed sensor to jumper wire. Check speed sensor adjustment (use business card to set gap between sensor and pulley). If LED D still does not flash replace sensor. I/O cables If LED D is flashing when the belts are turning but err LS or OS persists check connections and for signs of visible damage to any of the three I/O cables. If no damage, check continuity using a multi-meter. If a multi-meter is not available contact customer service for replacement cables and further assistance.
Mike
Posted on May 30, 2009
SOURCE: one treadle is rubbung on the upright
The rear bolts are loose. I had the same problem and found the four 3/8" bolts loose. You need to take the rear side covers off first then the rear cover to get to the bolts.
Posted on Dec 30, 2010
  • 5 Answers
SOURCE: hey we moved my treadclimber tc5000 and now it
there could be several reasons why but i think that you have bumped a wire loose somewhere else. look and see on the control board that wires havent come loose. also check the wires from the console down to the control board. i have fixed several treadmils from people complaining about this same problem.
Posted on Jan 28, 2011
ercupa190
  • 12223 Answers
SOURCE: how do you replace the breaker on a tc5000
VERY EASE DISCONNECT THE POWER CORD.
Disolder the wires with Solder Gun, change the breaker and again put solder in the terminal, please do it with carefully, and very tight the terminals.
the breaker is to side from main switch.
sincerely.
Posted on Nov 30, 2011
ercupa190
  • 12223 Answers
SOURCE: TREADCLIMBER tc5000 error code e5_5
see the steps and fix it. God bless you
Error 5
Description
The power up test sequence has detected a key in the operated condition. The power up test
sequence is performed every time the unit is turned on (powered up). This test is performed
because a permanently stuck key will inhibit the correct operation of the unit.
Possible Causes
1. A key on the display housing is permanently stuck in the operated condition.
2. One of the upper PCA's keypad interface chips has failed.
3. Liquid (perhaps perspiration) is present on the surface of a touch sensitive display.
Possible Remedies
1. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is no longer present, the keypad is the cause. The keypad is typically part of
the display housing. Replace the display housing to correct the problem.
2. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is still present, the upper PCA is the cause. Replace the upper PCA to correct
Posted on Nov 19, 2012
What does error code 1649uli indicate?
You have to call the Company representative who will guide you through the error code. Call :1-800-628-8458
In case you don't have the manual, here it is: http://www.searspartsdirect.com/partsdirect/user-manuals/TC5000-Bowflex-Parts-BOWFLEX+TREADCLIMBER-manual
Good Luck!
Feb 02, 2016 | Bowflex TreadClimber TC5000
Why does my Bowflex TC5000 cut out?
If you're running the machine on a dedicated circuit then your unit is drawing too much current. This can be caused by friction and drag. Solution: Lube deck/belt. If problem persists, replace deck/belt. If you ignore this fix this will blow your controller. .
Apr 29, 2014 | Bowflex Tc5000 Climber Treadclimber...
Bowflex TC5000 won't start! Lights on circuit board show power.
see the video and proceed according and fix it. God bless you
Jan 08, 2013 | Bowflex Tc5000 Climber Treadclimber...
My tc5000 keeps failing the cal can you help
Try again RUN the software calibration. and adjust the REED SWITCH, and Speed Sensor, test it, clean it, and tight the plug or connector from UPPER board vs lower board.
God bless you
Nov 16, 2012 | Bowflex Treadclimber Tc5000 Tc 5000 W In...
How do you replace the breaker on a tc5000 treadclimber
sincerely.
Oct 09, 2011 | Bowflex Treadclimber
Hey we moved my treadclimber tc5000 and now it won't power on. Cord is plugged in and outlet is good
Jan 28, 2011 | Bowflex Treadclimber
Where can I get this machine serviced? The gate feels uneven. The left pad almost seems to be hitting ground before the right pad completes its stride.
hello. call bowflex directly and ask Call (800) 667-1689. They probably have service centers located around the world. Joe
Mar 01, 2010 | Bowflex Treadclimber TC5300
Bowflex treadclimber 5000
Napa 8300 silicone is recommended. Apply under belts from front to back one fluid spray and also in bearing areas. Squeaking can also be caused by the center of the treadles rubbing to hard. If this is the case they need to be adjusted.
May 29, 2009 | Bowflex Treadclimber TC5300
Exercise & Fitness Logo
61 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
