Question about Kenmore 63942 Dryer
Kenmore electric dryer heats but does not dry the
Kenmore electric dryer 110.60712990 Series 70 heats but does not dry the clothes. Assuming the problem is obstructed air flow, I checked the lint filter, the vent hose to outside. All is clear. What next?
I ordered a new thermostat, am I on the right track?
    President:
  • 744 Answers
Hi, Here are the obvious parts to check: Heater, High limit, Thermal fuse or thermostats...these are all generally located in the back but some models you access them from front. the most common cause is either heater or thermal fuse, I will include a picture of the thermal fuse. If you test these parts and find they all work you may be looking at a centrifiacal switch problem.
Here is a picture of the thermal fuse check this part first:
http://www.partselect.com/repair.aspx?appliance=dryer&part=replace-thermal-fuse
Please feel free to contact again if you have any other problems.
Hope this helps.
Posted on Jun 24, 2009
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 24, 2017 | Kenmore Dryers
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Kenmore Series 70 Dryer
I'm not familiar with your dryer model but general advice regarding dryers with the problem that you have described would be to ensure that any filter on the outlet is clean, whether it be a condenser or traditional external vent.
Ensure, if it is vented rather than condensing (only connected to a drain) that the vent tube has clear access to expel the damp air circulated during the drying process.
If the wash load is heating to a substantial temperature in the dryer, it isn't the element causing the problem.
May 07, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Not drying
is it electric?is the drum turning/are both your vent holes(wall&dryer)clear?mike
Mar 21, 2009 | Kenmore Dryers
My kenmore 70 series dryer will not dry clothes, but it does heat up inside and lets hot air out the dryer vent on the outside of the house.
make sure the dryer vent and the house vent are not clogged with lint this will slow down the drying process-mike
Mar 14, 2009 | Kenmore 62802 Electric Dryer
Kenmore 70 Series
You probably have an open thermal fuse, the dryer will run in some cases and not heat, Just moving air across you clothes will dry them however it takes forever.
If you are electrical or mechanical replace the thermal fuse yourself if not call someone you trust, you can purchase thermal fuses on line from Sears.com just do a parts search for you specific dryer.
Jun 04, 2008 | Dryers
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Kenmore 63942 Dryer Logo
285 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
