Question about Samsung Audio Players & Recorders
Samsung model sps4243x/xaa doesn't power on - Samsung Audio Players & Recorders
4 Suggested Answers
  • 1039 Answers
SOURCE: snowy color screen & have sound
On the back of th panel are list Vs, Va voltages. Find the test point on the power brd. Labeled on one of the connectors. See if voltages match. If they are slightly off find coresponding trimmers and adj. if way off disconnect x and y sustain boards from power board. if stays low then replaced power board. if it is normal with x,y disconnected then one of sustain boards. if voltages all ok suspect panel. ry checking other inuts first to see if this is a vseo problem or not.
Posted on Apr 25, 2009
MNfisherman
  • 11896 Answers
SOURCE: great picture, no sound
There is most likely a faulty capacitor or resistor on circuit board for the audio ouputs. It will have to be tested to find faulty capacitor or resistor
Posted on Aug 27, 2009
  • 556 Answers
SOURCE: Samsung Model Hlt6176SX/XAA has Check Fan No. @
The lamp fan needs to be replaced.
Posted on Jan 12, 2010
I have a Samsung Plasma TV (SPS4243X/XAA). When I turn the TV on, the picture fades to black after about 1 minute. I can turn the TV off and back on and it fades after about 5 seconds. What is wrong?
Fault to its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 03, 2015 | Samsung Televison & Video
Dryer heats for maybe 1 minute then stops. Samsung Model DV328AGW/XAA
In the rear of the dryer is a thermal limiter which will kick in when the exhaust temp is too high and can cause a fire. One link will show what the limiter looks like and the other will show how to commonly get to the limiter. Your mileage may vary.
Samsung Dryer Model DV328AGW XAA Fuse Thermal Fuse Breaker Parts Take Apart Samsung Dryer Samsung Dryer Repair Help
Jul 30, 2014 | Dryers
Manual samsung YP-U2
I've found several YP-U2J (not just YP-U2) MP3 players listed by Samsung support. The direct link to the support for the YP-U2JQB/XAA is http://www.samsung.com/us/support/owners/product/YP-U2JQB/XAA . The manual is here: http://downloadcenter.samsung.com/content/UM/200604/20060401094436140_YPU2J-USA-ENGLISH0.0.pdf . If this link doesn't work, start at the above link and the Manuals & Downloads tab. (You'll see a pop-up, click Send.)
Alternatively, start at http://www.samsung.com/us/support/downloads . Select Media Players under Mobile. Then select MP3 Players and finally the model. Then look for the Manuals & Downloads tab.
I hope this helps.
Mar 15, 2012 | Samsung YP-U2 MP3 Player
The LED indicator is flashing/blinking we replaced the lamp and it will not still turn on. someone suggested the cooling fan? Thank you Shawna2735@Gmail.com
If Fan is running when you turn TV on and keeps running then its OK ,Ballast Board is what turns Lamp on, Is Lamp Lighting at all?
Encompass Parts Distribution has Ballast board for $62.00
Be sure to give the whole model # to TV Ending in WXXaa
WAX/XAA or WX/Xaa HLR6167wxxaa or wax/xaa or wx/xaa
1-800-638-3328 You can also go to their website and type in your model # for List of Parts and Free Service Manual.
Sep 28, 2010 | Samsung HL-R6167W 61" HDTV
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Great picture, no sound
Aug 27, 2009 | Televison & Video
I have a Samsung HDTV. Model Code HLR4667WAX/XAA,
IT'S YOUR DMD MODULE IT'S PART OF LIGHT ENGINE IN THIS PATICULAR MODEL WHEN THAT GOES BAD YOU HAVE TO REPLACE WHOLE LIGHT ENGINE CONTACT DISCOUNT MERCHANT OR RIVER VALLEY ELECTRONICS THEY HAVE THEN FOR PRETTY CHEAP.
Jun 24, 2009 | Samsung Televison & Video
Snowy color screen & have sound
Apr 22, 2009 | Televison & Video
20 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
