Why does our dishwasher lg mosel LDS 4821ww make a grinding noise during drain cycle?
SOURCE: Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
SOURCE: Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
SOURCE: LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
SOURCE: LG Dishwasher LDF7811 Making Growling Noise
Recommendations:
-Switch to a brand name detergent powder - like Electrosol or Cascade and do not fill the dispenser cup full. You will notice the difference immediately.
-Remove the filter assembly one more time and inspect underneath with a flashlight. Look closely for debris and also inspect the impeller to look for damage and that it is spinning freely.
Reassemble and listen for the growling sound. It should not happen. If it continues, you may have a a failing wash motor / motor bearing.
Please report back what you find. OK?
SOURCE: Samsung DMR78 dishwasher makes a grinding noise at
Check the brackets that hold the top rack for any broken plastic brackets. My dishwasher was making the same noise and after noticing the broken plastic pieces I pulled out the dishwasher put it on its side removed a white panel on the bottom that is attached with two screws, removed the drain line and inside there were two plastic tabs from the broken bracket. Once those were removed the grinding noise stopped. The bracket holding the drain hose can be removed with a pair of pliers.
