Question about Intek America Inc Sentinel 6-Sheet Crosscut Shredder
How do I fix my Intek model tq101bc? - Intek America Inc Sentinel 6-Sheet Crosscut Shredder
I have an intek 55 ohv engine as fitted to my self propelled mower but there are no id numbers on the motor apart from the sticker that says intek 55
If I remember correctly they are hard to see as are under the engine cover on the metal piece over the muffler. It be 120000 series. The governor spring depends on the model and type numbers of the engine.
Feb 16, 2015 | Garden
Carbarator linkage placement
well model number or what we are working on or something rellevent
Aug 19, 2014 | Briggs AND Stratton Intek 331977-0001-G1...
What is the compression lbs for a 18 hp brigg/stratton intek engine
Not sure where to get compression pounds for this, but let me refer you to the Briggs website for detailed product specs and power curves.
Intek can be twin or single sylinder.
For Twin....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-series-v-twin
For single....the are in 1/2 HP ratings but the link is below....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-with-xrd-single-cylinder
If further detail is required, I will need the model type and trim found on the valve cover.
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to replace fuel line on troy bilt tuff cut 230 lawn mower with B&S intek engine
The easiest why is to remove the carb, usually the gas inlet on the carb is between it and the engine, the other end is beneath the gas tank, once again it is easier if you take the tank off the mower.
Aug 01, 2014 | Briggs & Stratton Garden
Yardman 6.5 HP. Intek / 21" 6speed self propelled
its probably a tecuseh engine no fix for that other than put new primer ball on
Apr 28, 2013 | Garden
Battery is not charging. Does the Intek V Twin have an alternator and voltage regulator?
Yes, to both. Plug the model number in the searspartsdirect.com and you can get the parts listing & part numbers..
Oct 28, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman Tractor (B&S 20 HP Intek) starter motor spins, but the gear does not move up and engage the fly wheel. How is it supposed to work? Can I fix it?
All it should need is a kit that gives you the top half of the starter. I just did one on my 12hp craftsman. The kit was $23.00 and even came with the directions. very easy. Hope this helps
Apr 21, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Does the exhaust vavle have a stem seal on a intek twin cylinder?
Most do not. Check your exact model/type/code numbers on the parts lookup site here.
Sep 26, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Intek America Inc Sentinel 6-Sheet Crosscut Shredder Logo
Top Intek America Inc Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Intek America Inc Office Equipment and Supply Expert? Answer questions, earn points and help others
