Red lines I wrote a legenthy emain and towards the end almost two thirds of the email became under lined with red kines as though the entire thing is mispelled. I am operate an Asus laptob that runs on windows 8.1. The laptop is only about 8 plus old. What I have done wrong and how do I rest assured that the entire Emai,[yery imoortant],that the entire email goes out wherein it is very important that the entire email goes as it is now written Can You Please help me?
    Habit-Forming:
  • 75 Answers
Sir...I think you are not very computer savy...I can help you with sending correct email...I can take remote access of your system and fix issue for you, one time charges USD 20; pay only if issue is resolved.
Call me at
OneEighthundred,ThreeThreeNine,NineSixThreeFour (Free number).
My Name is Harry.
Posted on Jun 16, 2017
3 Suggested Answers
  • 142 Answers
SOURCE: white line on screen
Usually a white line straight across the screen indicates that the LCD screen has a bad row. There's not much you can do about it I'm afraid.
If you're mechanically capable, you can go to e-bay and pick up a non-working unit (for parts) and replace the screen on your working unit. I guess it depends on the cost of the unit. You might just be better off using it as is.
Posted on Apr 02, 2008
SOURCE: How do you remove the red line on the little time line while songs are playing?
when you play your music and you see this red line, you click on the "Menu" button. A menu will appear. You select "Bookmark" , then "Delete", then "Delete All". This will erase those red lines, which are in fact bookmarks.
Posted on Jul 22, 2008
I have red lines undrelines on a email that I do not know how they got there much less how to make them go away. I fear that m,y hy
Those red lines are telling you the word is misspelled. Correct the spelling and the red lines will go away.
May 18, 2014 | Samsung Yepp YP-T9 Digital Media Player
1 inch red and green lines in a strip across top third of tv
Id start by replacing the tcon board, its the small board generally at the top of the set. sometimes under a metal cover
Nov 27, 2017 | Vizio Televison & Video
Gear timming in line sander
The Matco is very similar to the IR-315 straight line sander as well as the Central Pneumatic Straight Line Sander sold by Harbor Freight-shown here: The Central Pneumatic became the focus of my attention when I realized it was not timed properly after re-assembly!
gear-timming-in-line-sander-ouwmaoiy3rgyhljowtwgziyj-2-0.jpg Assuming you are having the same problem,(1) I recommend mounting the body upside down in a small vise as shown here:
gear-timming-in-line-sander-ouwmaoiy3rgyhljowtwgziyj-2-2.jpg(2)Rotate both piston gears full forward (to the left in this photo). (3)Then carefully rotate each toward the back end precisely three teeth (to the right in this photo). It is important to note: Begin counting to the precise 3rd tooth once the first tooth is near top center in step (2). Thus, if after rotating the gears forward until they stop, you ideally want a tooth visible right at the top center. If the tooth is not at top center, move the gear(s) slightly toward the back until the very first tooth is now centered up: then begin counting to the 3rd tooth. If after rotating the gears forward until they stop, a tooth is NEARLY at top center: use it as your starting point and count to the third tooth (step 3). I recommend wiping the oil/ grease off of these two centered teeth and coating them with red majic marker.
(4) Reference next picture: Hover cursor near rotary air valve gear. The dotted gear lobe should be a 1 oclock, assuming 12 oclock is in line with the center of the body toward the knob end of unit. Note the piston gears are marked for the centered 3rd tooth. Note the two teeth on each side of the center valley(s) of the rail gears are highlighted as well.
gear-timming-in-line-sander-ouwmaoiy3rgyhljowtwgziyj-2-5.jpg (5) I recommend marking the valley after the tooth that follows the dotted tooth and verifying its position is at 3 oclock. Notice in the background that the center tooth is highligted (it is the fifth tooth from either end of that straight gear on the rack).Also reference the second photo after step (6):
(6) visually confirm all teeth are in perfect alignment for placing the rack upon the unit:
gear-timming-in-line-sander-ouwmaoiy3rgyhljowtwgziyj-2-14.jpg (7) Simply place the rack onto the unit's body making sure all your marks are centered up. If correctly lined up, you will incur no resistance or offsetting. If rack does not simply "lie onto the gears", lift back off and re-check the alignment of each of the teeth and valleys. A slight movement of one of the piston gears is usually the cure.
(8) re-attach the rack retainer bars with at least 2 screws on each side before moving the unit.
(9) you should visually be able to see about 1-1/2" of rack movement from the unit by pushing the rack to its limits. A centered rack measures approx. 15/16" on both ends of unit to the center of the bolt in the rack.
Sep 30, 2012 | Heavy Duty Air Twin Piston Inline Sander
Changing the fuel filter
Your gas tank is in the back of your car between the frame rails. The fuel line runs up toward the engine along the drivers side frame rail on the inside of the frame rail. The fuel filter is located along that fuel line inside the drivers side frame rail, about at the back of your front door. You should be able to trace the fuel line all the way to the intake of your engine. Once you locate the fuel filter, you will need a special tool to remove the filter from the line. You should be able to get the 'fuel filter tool' at your local auto parts store for under $10. The tool has a flanged end on it, and it 'scissors' open and closed. Place the proper sized end on your fuel line just in front of the filter so that the flange sticks in toward the filter. Gently push the tool in toward the filter, while pulling back on the fuel line. The line should come disconnected. Remember, the fuel line is pressurized and may spray gas for a second or two when it comes apart. Then do the same to the other end of the fuel line. Good luck. Any problems, write back.
Jul 31, 2010 | 2002 Ford Escape
Were is the fule filtter on 1995 toyota 4runner
Fuel filters for 1995 Toyota 4Runner would be under the vehicle driver's side halfway between front and rear. It is an inline design and would look like the image below. The two (2) ends have threaded openings that connect to the fuel line from the tank and the other going towards the engine.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Take care
Jul 25, 2010 | 1995 Toyota 4Runner
A line is leaking coolant under the car(the line is metal) what is the kine called. thanks
Those are probably your rear coolant lines. Try to follow them to see if they end at the rear of the van. Also check your water pump it could be that leaking and it just appears it's coming from a pipe. I have a 2002 with 113.000 miles and my lines just rusted and exploded this past winter. Once they do rust through the van will immediately overheat. I am not sure if this is DIY job unless you have the tools to bend pipe. It cost me $400 to get all of rear coolant lines repaired.
Jun 09, 2010 | 2002 Kia Sedona
Location of ac drain to try and stop wet floor board on 98 tj?
The problem is with the evaporator drain. There is a, (usually soft flexable), tube that drains condensation from the evaporator to the outside. It is located in the passenger compartment, under the dash. The hose has, (A)-became disconnected from the evaporator. (B)- Has gotten a kink in it. (C)-Became clogged, causing the evaporator to overflow into your passenger floorboard. Your vehicle probably has some covers over these components, you will likely have to remove. Locate the hose, it typically drains just behind and inside your right front wheel. It may be concealed behind a kick panel, or may go thru the floor or firewall. You must find it and follow it to the evaporator and make sure it is not clogged or kinked and is properly connected to the evaporator.
Oct 13, 2009 | 1999 Jeep Wrangler
Thin vertical lines
Those lines are called retrace lines. They are there all the time on projection TVs but you should be able to see them. When you do see them, that's an indication that the kine screen settings are too high or the supply voltage to the kine driver circuit is low or missing. There is a small, black control unit located behind the speaker grill assy in the front of the TV that has 2 sets of 3 controls. A red, blue, and green focus and screen controls. See if you can make the lines dissappear by turning the screen controls counterclockwise. If you can't you'll need to have service come out to troubleshoot it.
michtech
Feb 02, 2009 | RCA D52W19 52" Rear Projection Television
Red text and lines appear in Black text
The red line is indicating a HYPERLINK to the email address of the user name, or other linked text in the Email.
If you are printing a program, you will not be printing anything with a hyperlink, so that should not be an issue.
Apr 27, 2008 | HP PhotoSmart 7660 InkJet Printer
54 people viewed this question
 Grubhead
Grubhead
