Question about Emerson Quiet Kool 10GV13 Air Conditioner
Do you know the quietest window air conditioner for under $250?
I need a window air conditioner for appprox 200 sq. ft but it has to be quiet. What do you recommend?
    New Friend:
  • 14 Answers
Most people buy the largest one they can find. It comes on, cools the room quickly and then shuts off. This is exactly what you don't want to happen because it does nothing to solve the humidification problem that is usually more of a problem than the temperature. Buy a smaller air condition that will come on and remain on for an extended period. It will remove the moisture from the room and make the air more comfortable. It will also draw less power and typically operate quieter since the compressor and fans are smaller. Of course it all depends on where you live... if you are in the desert, then humidity probably isn't the issue....
Posted on Jun 11, 2014
5 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: Not removing humidity
Just adjust the thermostat lower or colder!
Posted on Sep 05, 2008
  • 16 Answers
SOURCE: I have a 1985 Emerson Quiet Kool model 19LD4E
you may have to buy a cut to size filter from a hardware store
Posted on Jul 07, 2009
jumptrout51
  • 3361 Answers
SOURCE: 4 ton HVAC Unit for 2000 SQ FT Residential Bldg (Single Story)
One ton of cooling per 500 square feet of space assuming you have good insulation. Yes, 4 tons for 2000 feet would be accurate.
Posted on Jul 21, 2009
  • 4736 Answers
SOURCE: I need a master control
Without the Model Number, it's hard to know what knob fits your model. However, the link below, may provide some help. But, having the Model Number would be a bulls eye. Remove the front of the AC unit. There may be a manufacturer's data plate inside, which would provide the model number.
http://www.appliancefactoryparts.com/airconditioners/emerson/emerson-knobs.html
Hope this helps you.
Posted on Jul 13, 2011
Need manual for emerson quiet kool air conditoner model 12HT13?
I found this I hope it helps.
Performance BTU/H Cooling: EER: Voltage: Amps: Watts: Cooling Area (Sq. Ft.): Pints/Hour: Room Air Delivery (CFM): Plug Cap Amps: Plug Type: Dimensions Width: Depth: Height: Net Weight: Shipping Weight: http://www.appliancefactoryparts.com/airconditioners/emerson/12ht13.html#Manuals
Jun 02, 2014 | Emerson Quiet Kool 12HT13 Air Conditioner
How to measure air conditioning tonnage to square feet of hom
Read size of air conditioner you need , each ton of air conditioning will keep cool 400 square.so higher ton yo pick you feel cool.please read below square feet to ton chart.
1 ton on 400 sq. ft.
2 ton on 800 sq. ft.
3 ton on 2000 sq. ft.
5 ton on 2570 sq. ft.
May 28, 2014 | Computers & Internet
Haier air conditioner won't cool the room anymore
i bought the air conditionor new and it will not cool what can i do
Jul 05, 2012 | Haier ESA406K 6,000 btu ECO-Friendly...
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
Need window air conditioner to fit window 23" wide. Studio apartment main room is 13'X17' with kitchen 6'x17' and walk-in closet and bath 5'x17'. Would like a kenmore and quiet while in operation.
Hi; Try purchasing an up right portable ac unit. Then all you need to do is vent the hot air tube out a convienant window or dryer duct. Needs to be at least 12,OOO BTU. I size my installs to 400 sq. ft. per ton(12,000 btu)
Jan 18, 2010 | Kenmore 75085 Air Conditioner
I need an idea of square foot coverage
There are more factors than sq ft. You have to factor in window surface and R factor of insulation.
Aug 18, 2009 | Heating & Cooling
Amps needed to run a central air unit
Central air requires a 2 pole 30 amp breaker or fuse. You may be able to get by without it but 200 amp service is recommended.
Jan 31, 2009 | Weather King 12AJA4801AH Air Conditioner
Emerson Quiet Kool 10GV13 Air Conditioner Logo
175 people viewed this question
Top Emerson Heating & Cooling Experts
Tim Whalen
Jay Finke
Jay Finke
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
