Question about Refrigerators
Why kenmore 795.72052.110 making noise - Refrigerators
My kenmore washer model 110 20022011 is making weird noises. Its not just regular sounds that it makes. Has happened first time in 4 years.
many things cause noises coins going between inner basket and outer shell . bearing going out make odd noises also
Apr 10, 2015 | Kenmore Washing Machines
My kenmore 84052 is making a squeaking noise
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
The glides on drum worn and making metal to metal contact.
CHECK FOR LOOSE BELLOES inside the drum
Aug 14, 2014 | Kenmore 84052 Dryer
Kenmore dryer making a weird noise
sounds like a bad drum wheel,it won't do anything bad you can keep using it or replace the wheel-mike
May 07, 2010 | Kenmore 62602 Electric Dryer
Kenmore Washing Machine 82110 - Loud Noise
could be the brakes, if the loud noise is like a screech probably your brake rotor and lining need replacing.
Mar 31, 2009 | Kenmore 22422 Top Load Washer
I have a kenmore 70 make ratchet noise ,will not
Probably bad lid switch. Your ratchet noise is normal during the wash cycle.
Mar 24, 2009 | Maytag PAV2300 Top Load Washer
Kenmore 98702 Stacked Washer/Dryer. Dryer making clicking noise
There may be coins stuck inside the tumbling vanes in the drum.
Mar 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore washer makes a whining noise
The whining noise is usually caused by the pump. Try replacing the pump. Or cleaning it out.
Feb 01, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore washer makes a whining noise while pumping water
This is caused by the pump. Replace or clean out the pump.
Kenmore makes whining noise as it tries to spin
The drive coupling has probably broken. Usually happens when you overload the machine. Easy fix. READ MORE
Jan 21, 2009 | Kenmore 24902 Top Load Washer
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
