How to Open G Guitar Tuning? - Televison & Video
How do I set the tuner to tune at different keys?
Good question, tuners can be simple and some are complicated
a basic automatic guitar tuner you would not have to do anything to the settings, just tune normal on the E string then slowly down tune to D most tuners are a little sensitive, so go slow
and one thing I always do is go lower than the note I'm tuning to then tune up tell it's correct, strings seem to stay in tune better
Hope this helps ?
and if you have time check back on my profile
I will be doing some video tips this weekend
showing tuning, and some basic guitar repairs
thanks for your time
Mar 06, 2015 | Music
HOW DO I TUNE A KRAMER GUITAR
Without seeing your guitar, I'm going to assume the "tightening lugs" you're reffering to are the string locks on the nut. On a guitar with a "floyd rose" style tremolo system, the strings pass through a clamping system at the nut before going to the normal tuning keys. This clamping system "lugs" must be loosened then the guitar is tuned as it normally would, then the lugs are tightened to lock the strings in place. These clamps are not part of the tuning mechanism, but instead lock down the strings after they have been tuned by the keys. After all that, one would fine tune the guitar at the bridge rather than at the keys. A more complete explaination is found here-
String Tuning Instructions
Feb 17, 2015 | Kramer Music
Bridge: the guitar keeps getting out of tune. Should I block it with a piece of wood, making it more like a fixed bridge?
Do NOT modify the guitar. Take it to a shop where they can set it up properly if you are having intonation or clearance problems. Also the quality of strings has a lot to do with changes in tuning. It is NOT uncommon for a guitar to require tuning during a half hour of playing. This is normal, especially if you are really driving it. Temperature affects the tuning drastically as well.
Apr 11, 2011 | Ibanez RG370DX Electric Guitar
Is he tuner supposed to light up green when the string is correctly tuned?
Before turning the unit on, press and hold down the calib/batt switch to check the condition of the battery on the battery meter.
Then either plug in your electric guitar to the input side of the AG-6 or if tuning an acoustic guitar without electronics placing the AG-6 near the front of the guitar should work. You will not need to press a button to select which string you are about to tune. The AG-6 will detect it and the corresponding light will turn on when it is tuned within range.
Turn on the AG-6 and start by striking the low E (thickest) string while open. This is the number 6 string or 6E. Slowly turn the guitars low E tuning key untill the red LED below the 6E marking on the AG-6 lights up. Continue stricking the open string and turning the key untill the needle centers on zero and the 6E light remains on.
Repeat this for the open A string untill the 5A light turns on and the needle centers on zero.
Repeat for the remaining four strings, 4D 3G 2B and 1E, being careful not to over tighten and break them.
Tip: It may be a good idea once the low E string is tuned, to tune the rest manually, especially new strings or strings way out of tune. Then tune again using the AG-6 tuner.
If installing fresh strings you will probably need to stretch each string and re-tune, possibly several times, before they hold their tuning.
Feb 19, 2011 | Fender AG6 Automatic Guitar Tuner
How do I change the strings on my Dean Vendetta
How to Change Strings on a Dean Vendetta Guitar
Dean Vendetta is a company that makes a wide range of electric guitars. These guitars are used by famous musicians and bands such as Alice in Chains and Megadeath. If you own a Dean Vendetta guitar, you will need to change the strings periodically in order to keep your guitar sounding bright and crisp. Without changing the strings, your instrument will sound dull due to dirt and oil build-up on the strings.
Instructions
Things You'll Need:
* Dean Vendetta guitar
* String winder
* Guitar strings
* Electronic tuner
* Wire cutters
Locate the high E string. This is the string that is highest and thinnest and closest to the ground when you play the guitar.
Loosen the high E string by turning its tuning key counterclockwise. Use a string winder for this if you have one. Pull the string off of the tuning peg and out through the bridge.
Insert a new high E string through the hole in the bridge, up the neck, to the head of the guitar.
Thread the string through the hole in the tuning key so that about two inches extends beyond the hole.
Hold the string at the top end of the neck in one hand as you turn the tuning key clockwise with the other hand. A string winder makes this task much easier.
Continue to wind the string until it tightens to pitch. Use an electronic tuner to check the pitch.
Clip off the excess string with wire cutters.
Repeat these steps to install the B, G, D, A, and low E strings.
Tips & Warnings
Expect to re-tune often for the first few hours after installing the new strings, as they tend to stretch quite a bit at first.
Hope it helped.
Thanks for using fixya..
Jan 14, 2011 | Dean Vendetta XM Electric Guitar
Tuner
In the navigator display in the upper right corner of the face, after holding the tap switch or the tap footswitch for over two seconds the display will indicate your tuning. Strike an open string and the left end of the display will show you the note. Then there will be left and right arrows on the screen until you adjust your tuning for that note. When in tune for that note, two asterisks will be displayed in the center of that display.
Read your manual on the page with the "Smart FX" at the start.
May 14, 2010 | Line 6 Spider Iii 30
How to tune?
the standard tuning is e a d g b e .go to www.fretjam.com/online-guitar-tuner.html. they have about everything you need on tuning and alternate tunings.
Dec 29, 2009 | Washburn D10sbc Acoustic Guitar
Washburn acoustic electric guitar eq & turner system wt-92 how do you use it for tuning
Try this site:
Select the lesson on "Tuning Machines"
This looks like a good resource for information.
Dec 15, 2009 | Washburn D10sbc Acoustic Guitar
SChecter c1 plus tuning problems
If you do a lot of bends or use a whammy bar this will happen a lot. The best way to keep a guitar in tune is to buy a locking system to put on it. I use a floyd locking system for my own guitar.
Sep 07, 2009 | Schecter C 1 Plus Electric Guitar Cherry
How can i tune my electric guitar
You can go to YouTube where people have videos of guitars of various tunings.
Here's one for standards tuning.
and here's one for Eflat tuning - Use this for Guns N Roses
Here's another way - Harmonic tuning - very cool
Aug 17, 2008 | Fender Fm25dsp 1x10' Guitar Combo...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
