Question about Dell Computers & Internet
How to remove cd drive from HP Pavilion a410n
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
Unplug & remove the battery about a hands width from the DVD face on the back is one screw. Remove that screw and extract the drive. Generally it is easier to remove it with the gate open & pulling gently straight out.
Posted on Jan 25, 2015
3 Suggested Answers
gandhiforyou
  • 275 Answers
SOURCE: how to remove the CD
go to this link http://www.jamesthebard.net/blog/?p=5 i think it will help in some way
Posted on Jun 20, 2008
machineindep
  • 55 Answers
SOURCE: remove hard drive from HP Pavilions a6230n
No you have to remove the media drive cage from the front the panel comes off. then pull on green tab to remove it completely then you'll be able to reach the harddrive
Posted on Dec 07, 2012
If my hp a410n pc has power, why wont the monitor come on
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Test all leads that attach to your hard drive including electrical extensions IDE SATA the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure dust free connections and are not faulty even something as small as an electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard or you might try You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. If you can get an extended desktop your monitor is faulty if you cant get an exended desktop Hope this helps.
Jan 14, 2013 | HP Pavilion a410n (DQ174A#ABA) PC Desktop
How do i change the cd rom on a hp pavilion laptop
Hello Turn off your Pavilion laptop and remove the AC power cord. Slide the battery release lever to the unlocked position and remove the battery.
Read more: How to Remove a CD-ROM Drive From a HP Pavilion Notebook N5425 ' eHow.com http://www.ehow.com/how_6138972_remove-hp-pavilion-notebook-n5425.html#ixzz2BTQ7dMMi
Remove the small Phillips head screw on the bottom of the laptop. This screw is used to secure the optical drive to the laptop case.Grasp the front of the CD-ROM drive and carefully slide it out of the bay. Slide the replacement drive into the bay and secure it with the Phillips head screw. Then replace the battery, connect the AC power and turn the laptop on.
Good luck
Nov 03, 2012 | Computers & Internet
How do I remove/replace the keyboard from a HP Pavillion dv7-2277cl
1. Remove 6 screws from the bottom of the case (as shown). These screws hold the accessory cover.
2. Remove one screw securing the CD/DVD drive. Slide the CD/DVD drive to the left to disconnect it from the motherboard. Remove the CD/DVD drive.
3. Remove all marked screws from the bottom of the notebook.
The yellow circled screws secure the keyboard cover, and the green one secures the HP Pavilion DV7 keyboard.
4. Turn the computer display-side up and open it as far as possible. Insert a guitar pick or small flat screwdriver between the keyboard cover and case and slowly move along the side.
5. Lift the keyboard cover. Be careful, it's still connected to the motherboard. Release the zero insertion force (ZIF) connector and disconnect the cable from the LED board. Remove the keyboard cover.
6. Remove the four screws that secure the HP Pavilion DV7 keyboard.
7. Lift the rear edge of the HP Pavilion DV7 keyboard until it rests at an angle. Slide the keyboard back to disengage the tabs on the front edge of the keyboard from the top cover and rest it on the display.
8. Release the ZIF connector to which the keyboard cable is attached and disconnect the keyboard cable. Remove the HP Pavilion DV7 keyboard.
You can refer to the complete article via the link below:
http://laptoppartstore.weebly.com/replace--remove-hp-pavilion-dv7-keyboard.html
Apr 08, 2012 | HP Pavilion dv7 Keyboard (483275-001)
How can I unlck my a410n hp comuter It will not accept my pass word
Hi, it sounds like an incorrect password has been used on your system and you are only given three trys to insert the correct password and then your system locks you out completely. There is however a way around this and that is, you need to open up your pc tower and on the motherboard next to your cmos battery, this is easy to spot, it's a coin shaped battery, there's a group of metal pins also known as jumpers. These jumpers will have a tiny cap covering two of the metal pins. Remove this jumper. Close your tower and reboot your system. By doing this your system should no longer ask for a password. The alternative to this is you can remove the coin battery and replace it and again, close up and reboot your system.
There is something very important to consider. Before you do any of these things make sure you ground yourself. This relates to ESD or Electro Static Discharge. This is very bad for all components on your motherboard inside the pc. Before touching anything inside your pc on the motherboard ground yourself by touching a metal port on the outside back of the pc or the metal powersupply and this will release any static discharge from your fingers. It's then safe to take the above actions. Make sure all the power is off before going inside. I have enclosed a video for you to look at which will explain things in detail. This will remove your bios password if any.
In relation to your windows password there are utilites that you can use and I will provide details for you in another video as follows: This relates to a free bootable cd from the following website with the video underneat. I hope this helps. Please let me know how you get on. Andrew
http://ultimatebootcd.com/
Apr 01, 2011 | HP Pavilion a410n (DQ174A#ABA) PC Desktop
My power button for my HP a410n desk top flashes and beeps when I try to turn it on. I removed the side panel, checked the memory stick to make sure it wasn't loose, put it in the second slot, and checked...
It can be an issue with the motherboard or the SMPS(power supply unit)...
You can remove the 24pin power cable plugged in the mother board and you can plug it back...
also try to remove the cmos battery and place it back in the motherboard...
The data that is stored on the Hard disk will never get erased, so you need not worry about your data...!
Feb 06, 2011 | HP Pavilion a410n (DQ174A#ABA) PC Desktop
Remove cd from hp pavilion hard drive expansion
Use a paperclip and push it in the little hole on the side.
Oct 25, 2009 | HP Computers & Internet
PC won't turn on, blue light flickering, green light flickering
check your monitor's connection, its power and VGA connection to cpu, the cpu may be good but you just see black screen bec. your monitor remained off. please bring it to HP service center for more help
Oct 18, 2009 | HP Pavilion a410n (DQ174A#ABA) PC Desktop
Reboot maah hp for hp dv6405us
Hi Ash,
1. Check the CD drive and remove any CD inside.
2. Remove any USB drive from the USB port.
Your laptop could be configure to start up from CD, USB, or Floppy Drive before the hard disk.
Rgds
S88
Jan 02, 2009 | HP Pavilion DV6405US Laptop
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
