Question about Rubbermaid Power Tool Hook Black
I need to glue a rubber maid trash can together any ideals on what type of glue ?
    Champion:
  • 225 Answers
I would try J B Weld.can find at auto parts store or hardware store.
Posted on Jun 23, 2009
Do the maids we hire for time in Singapore is professionals?
Since a maid has become one of the essentials of your home, you need to hire a competent one to make your home neat and clean. There is no doubt that hiring a right maid is one of the toughest activities to do. If you are also going to hire a maid for your home, you must ask her the following 10 questions. They will help you to recruit a proficient one for you:
  1. How long have you been working as a maid?
The answer of this question will help you to get known about her experience in field. Also, you will be able to analyze her dedication being as a maid.
  1. Why did you leave your last job?
This will help you to understand her behavior and the problem she has faced in her last job. You may make it possible that the reason of her to leave the last job may not occur again.
If the maid is not a Singaporean,
  1. Why did you prefer Singapore to do a job?
There are numerous foreigner maids in Singapore who work to earn money. This question will make you know that what she thinks about your country.
  1. What about your family?
This will help you to get known about her family and its background. Maids having husband and kids are found more trustworthy and reliable than those who are single or have fewer responsibilities.Read more
10 Questions to Ask Maid
Feb 22, 2017 | The Kitchen Appliances - Others
Tip
Tip on tools you may need while fixing a flat tire.
You need A pump. <br />A puncture repair kit containing:<br />Tyre levers (at least two, preferably three) <br />Rubber patches <br />Rubber vulcanising solution (glue that sticks rubber together) <br />A small piece of sandpaper or other rough material <br />A crayon <br />You might also need:<br />An adjustable wrench <br />A talcum block (the small grey block included in some kits) or small bag of talcum powder.
on Dec 21, 2010 | Cycling
Weather stripping is coming off the doors on dodge caravan What glue to use?
There is a glue from 3M at AutoZone for about 10.00 dollars. This is strong stuff! Part number 08001.
Jan 25, 2017 | Dodge Cars & Trucks
HOW DO I KNOW IF MATSUI OVEN IS SELF CLEANING?
If it doesn't come with a little maid type female with a scrubbing brush and rubber gloves, you have to clean it....
Jan 11, 2015 | Ovens
Cleaning the Microsoft Wireless Mobile Mouse 4000
I disassembled my Microsoft Wireless Mobile Mouse 4000.
You need a set of precision screwdrivers to do this.
1. Peel up the teflon pad on the bottom of the mouse with a flat head screwdriver. Leave the other (the one under your fingertips) alone.
2. That will reveal a tiny silver screw. Remove that and then lift the gray upper section up from the back, then pull it free by moving it toward the back. The clips up at the front go in a forward direction, but they are not clipped in. You could just shake it free.
3. There are 4 tiny black screws. 2 at the front and 2 at the back. Remove them.
4. Use a flathead screwdriver to pry the retainer clip from the back of the mouse. It's just held on by a couple of little nubs. Don't break it. Be gentle with this part.
5. Now, the mouse can come apart. You need to pull the bottom of it free at the back and then slide the entire bottom section back. There is a little piece of circuit board that sticks out underneath the right-click area that will get hung up on the upper shell if you try to pull it straight down. This will take a little bit of prying since it's all clipped together, but it will come loose.
That's it. I didn't take any of the inner parts apart after that. I will say that my sticky scroll wheel was scraping against the upper shell. By loosening the two screws at the front, it relieved some pressure and let it run more smoothly. I didn't actually have to take it all apart after step 2 in order to fix that issue.
Mar 08, 2012 | Microsoft Wireless Optical Notebook Mouse...
Our dishwasher has a problem that keeps on re-occuring: Rubber hose, front right (Standing in-front of machine Model: extreme clean KD 12WW) keeps on dislodging from connection to what looks like the pump....
Dry all parts completely.
Hang a hose-clamp around pipe.
Apply KS2 UPVC solvent cement uniformly to coat both surfaces.
This is the same glue used to join PVC electrical conduit.
Quickly press and twist together.
Make sure pipe is fully on all the way.
Tighten hose-clamp over solid part where pipe is under.
Allow to dry. Minimum 5 minutes, preferably longer.
The solvent-based cement 'glue' slightly dissolves the meeting surfaces so 'welds' them together.
It may be that the clamp being used is worn or weak if spring-type.
Hope this helps u.
Clive.
Nov 17, 2017 | Kelvinator MDP531RF Dishwasher
Rubber on the inside of car door door is ripped
if you do use glue use a hot glue gun but becarefull not too touch the rubber with the gun
Jul 22, 2009 | 2001 Chevrolet Suburban
I am having difficulty glueing PVC together. I
3M Hot Melt 3764 is the correct adhesive for PVC.
Apr 22, 2009 | 3M Polygun AE II Hot Melt Glue Gun
Rubbermaid Power Tool Hook Black Logo
538 people viewed this question
Top Rubbermaid Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Rubbermaid Craft and Hobby Expert? Answer questions, earn points and help others
