Question about Whirlpool Dryers
I have whirlpool dryer front loader AWA9708 and it stop through it cycle and leaves a flashing light on panel
  • 124 Answers
SOURCE: replaced high temp sensor on whirlpool front loader
Hi, Here is what is happening.
  1. Yeah fixed it by replacing hi temp sensor.
  2. Then sensor went out again.
  3. Reason there is another sensor that controls heating element. One is high temp, which controls the heating element from overheating. The other controls normal heating element temp range. What normally happens is the temp range goes out & heating elements overload the high temp sensor causing it to fail. Usually best to replace as pairs. Make sure your using the proper temp sensors as well. If you get temp range hotter than high temp results same problem.
Hope this cleared up your problem & fixed you for good. Please rate. Good Luck! If I can Help further please send comment.
Posted on Mar 13, 2009
SOURCE: Whirlpool dryer front panel
I located a video on youtube.com free of charge. I removed the lint screen, and removed the two screws located in the lint screen housing. Then I pryed the top off near the front of the dryer, which has two clips. Then I remove the two screws locate on the top of the front panel, but they are located on the inside. I removed the door lid swich by removing the two screws. Lastly, I pulled the front panel outward and pulled up lightly. The front panel was off. The issue I had was the dryer would heat up and then got cool after five minutes. The solution was to replace the coils. Important point is that the coils ohm readings were within specifications, but I did located information on the web that indicated this was a potential solution to the issue, and I replaced the coils even though the resistances were within specification. Total cost $22.95 plus tax.
Posted on Mar 25, 2009
SOURCE: whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Posted on Apr 21, 2009
  • 172 Answers
SOURCE: Fisher & Paykel front loader dryer ED56AU
What about the lint sensore, it may be faulty, sending a signal of a fire hazard.
Posted on Aug 11, 2009
dmftrucker
  • 1922 Answers
SOURCE: I need to replace a door switch on my Whirlpool Duet dryer. How?!
look toward the bottom the screws are recessed upward to hide them then it should open up like a car hood and there are spring clips at the top
Posted on Nov 01, 2009
My duet whirlpool washer has stop working. The control lock light is on. so what do I do from here
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer does not run. The control lock light stays on even after I hold down the end of cycle button for over 5 seconds and/or unplug dryer for over 15 min. The light comes on when door is...
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Whirlpool Duet Dryer Lockout function stuck
May 06, 2010 | Whirlpool GEW9250 Electric Dryer
A whirlpool duet dryer continues with control locked light on...despite holding the cycle button down 3sec. no other buttons respond.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%$#@
Feb 15, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
My washingmacine stopped working completely. it started with one cycle going out , then a week later another cycle stopped working. now none work. when i turn the machine on i can here a hum , but nothing...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.))))
Feb 13, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Control locked on my Whirlpool Duet GGW9250PW0.
(Tip Courtesy JSRock)
Sep 22, 2009 | Whirlpool GEW9250 Electric Dryer
My whirlpool duet 2004 front load washers door is locked, time is flashing and pump is on. Unable to stop or open door. tried to unplug. Control lock is not on. My wife tried to add clothes when the add a...
Sep 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front loader Model 48102 will not start
Mar 14, 2009 | Kenmore Washing Machines
Dryer quit running in mid cycle
It's the thermal fuse and it's easy to install if you have a front loader just take the kick panel off in front, make sure you remove the lint filter and the cover that goes up to the lint collector and you will see the thermal fuse. Make sure you unplug before doing this. Take the two screws out of the bottom of kick panel and than use a putty knife and push down and the panel will come right off. Hope this helps you out.
Jan 06, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
