Question about Xpedo Thrust 8 Ti Spindle Clipless Road Bike Pedals 175g Lightweight Black 95 X 95 X 10 Mm
I have an annoying clicking sound every time I pedal
Rear wheel clicking
Could be caused by worn wheel bearings if the clicking is not intermittent. If the clicking only occurs when pedaling and sounds rhythmic, this could be caused by the chain and/or sprocket. Some 6 and 7 speed sprockets are renowned for this rhythmic sound under pressure but it doesn't seem to be a serious problem.
Apr 21, 2014 | Huffy Cycling
Sanpera I amp pedal does not work consistently with peavey 30w amplifier
Either the cord is bad or more likely the jack needs to be resoldered or replaced.
Apr 07, 2014 | Peavey Sanpera I Amp Pedal
On my 2000 camaro ss clutch pedal is making clicking noise at the begining of pressing it in and at the end of when i release it.
Do you feel this click when you push the pedal downwith your foot? Can you see if any wiring or anything is rubbing the arm connected to the pedal. SS camaro probably has a heavy duty clutch.Cheers Denny
Oct 11, 2013 | Vehicle Parts & Accessories
I have a very annoying clicking noise from my Shimano Ultegra PDR6oo pedals.This noise only happens when climbing.I have just changed the cleats,but the noise persists.They are about six years old and have...
Hi, the clicking noise that you hear is the sound of bearings/races reaching the end of their service life. You will need to take the pedals off and then remove the pedal from the shaft itself. Inspect the bearings and the races for excessive wear. The new bearings can be put in place using some thick grease on the race you can then stick each bearing into the grease and the will stay put until you are ready to do the opposite side of the pedal.
Nov 17, 2010 | Cycling
I have a new trane system - thermostat makes an annoying clicking sound every 10-15 minutes -
Sorry to say, that annoying clicking sound is the thermostat calling for cooling/heat. Whenever the temperature is reached it will "click" off and then "click" back on when needed. Some thermostats are quieter, but all digital thermostats will have that sound. Sorry again and I hope this answers your question!
Sep 01, 2010 | Heating & Cooling
Default music
I think you computer be running on screen saver options.To rid of problem go to Display Properties on you computer.Get there by going to click start button then click on control panel then click on display.That will take you to display settings,click on screen saver and then on settings. In there there should be a option to mute sound.
This should bring silence
Nov 11, 2009 | ASUS Eee 4G Notebook
Emergency break pedal stuck to floor, but break is disengaged
sounds like your brake cable has broken or there is something damaged in the pedal assembly.........try pulling on the release handle and move the e-brake pedal back to its off position by hand at the same time.(you may have to tie it in this position to keep it up)If that doesnt work there is a sensor on the pedal assembly that you should be able to bypass by either disconecting the wire(1 wire system) or connecting the two wires together (2 wire system)Especially if your truck is a standard the e-brake is an important safety feature,so if these steps fix the light and dinging problem you should still take the steps to have it repaired.
hope this helps.........Good Luck!
Dec 09, 2008 | 1999 Chevrolet Silverado 1500
Xpedo Thrust 8 Ti Spindle Clipless Road Bike Pedals 175g Lightweight Black 95 X 95 X 10 Mm Logo
26 people viewed this question
Top Xpedo Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Xpedo Exercise and Fitnes Expert? Answer questions, earn points and help others
