Question about Solar Noma 7 Day, 6 Event Outdoor Timer - Easy To Use +warr
How to set timer
Unable to locat instructions. Not known how to set for different times and days.
How do I set the clock? The included instructions for setting the clock do not work. I can set all the programmed on & off times, days of week, etc., everything except the friggin' clock. The cl
Give us the model number so we can see what you're talking about. Tell us what link you have tried, and how the instructions seem to be different.
Display showing no-op is sometimes associated with defective timer, bad battery. Resetting timer will clear memories and restore functionality in some cases.
http://waterheatertimer.org/How-to-troubleshoot-timers.html#digital
Attach photo of timer, or description of timer.
Add if this is new timer or if timer worked before, and what load the timer controls
Do you have correct instructions for timer ?... scan the manual into .pdf format. and then post the .pdf manual on your website .... then post link here to assist other folks with same problem.
Gene
Water Heater Timers Save Money
Dec 11, 2014 | Hardware & Accessories
I need to know how to set the time on my model RETP RINGGRIP TIMER
To set the time;
Press and hold the TIME button during the time setting procedure. While holding the time button press DAY to set the correct day and HR to set the correct hour (make sure the am/pm is correct) and then MIN to set the correct minutes. (If you hold down the Day/Hr/Min button for more than 2 seconds it will give a fast run-through)
Dec 13, 2012 | Hardware & Accessories
Unable to Program Utilitec 0192773 Timer
Let's figure it out together. I have one of these timers for testing, and can hook it up if needed. Add a comment as needed.
PLEASE read following material, so we are both saying the same thing.
There are two different options for programming.
7-day programming, and dawn-dusk programming.
You choose one or the other
This might be the point of confusion.
Copy following link for larger print instructions.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
DST is daylight savings time, and you can choose to have automatic DST adjustment twice per calendar year, or choose not to have DST
Be sure to RESET timer before programming. This will clear any programming glitches.
Make sure that each ON time has an OFF time.
So Program 1 ON is set for day(s), hour, minute
The Program 1 OFF is set for same day(s), hour, minute.
Make sure there are no conflicts between day(s).
If selected time is 12:00, then use 11:59 to avoid am-pm conflicts.
Oct 08, 2012 | Hardware & Accessories
Need help getting light timer to work
Timer is not known.
Please add a comment and include brand and model number of timer, or carefully describe the buttons so I can compare with known timers.
In mean time, here is ez instruction walk-thru for Intermatic ST01C timer.
http://waterheatertimer.org/ST01C-program.html
Aug 22, 2012 | Hardware & Accessories
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
To override time and turn on Load, move override to ON position.
Dec 06, 2010 | GE 51587 MultiEvent Timer
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
Clock is set properly. I want to turn on outdoor lights at 5PM everyday. In addition I want to turn off the lights each night at 11PM. Problem - When I go thru the process of turning on the lights it...
I answer questions for free.
I know timers and electrical devices, and have tested most of the brands.
You posted under the Woods 7-day timer 59018 or 59028.
Here is the manual:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
There are several programmable timers today that look like Woods, and each brand has different programming.
If you do not have Woods, add a comment and I will walk through programming your brand
1) You have the clock set correctly which implies the wiring is correct. Good job!
2) Programming review:
Each program requires ON time to be set, and then OFF time to be set
For example you set Program1 ON 5:00PM for ALL days.
And then you set Program1 OFF 11PM for ALL days.
3) Programming steps:
Press PROG button until Timer 1 ON appears on display
Use Hour button to set 5 PM
Use MIN button to set :00
Default selects ALL days
(If you want other days, press DAY button until display shows correct block of days)
Press PROG button again to save Program1 ON
4) Now for Program1 OFF
5) To set Program1 Off
Press PROG button until Timer 1 OFF shows in display.
Use Hour button to set 11 PM
Press PROG button again to save Program1 OFF
6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time.
If you want to set another program, press PROG button until Timer 2 ON displays
7) After setting programs, press Clock button so current time shows.
8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
If you need more assistance, add a comment.
If instructions help, give it a 4-thumb
Nov 10, 2010 | Woods InWall 7 Day Digital Programmable...
My paragon timing motors model 1015-00RSB are not timing as desired,how can i or guide me on how to programme and make schedule adjustments on it? Please help me
http://waterheatertimer.org/Paragon-timers-and-manuals.html#1015
The Paragon 1015 timer is a 24-hour timer.
The tripper pins or tabs are built into the timer dial.
This timer has NO and NC terminals.
NO NC terminals mean the timer can control two different circuits.
One circuit would be ON when the other circuit is OFF.
When the timer turns on, the circuits change so now one circuit is OFF and the other circuit is ON.
If you have just one circuit, then the following instructions will help you.
If your timer controls two circuits, you can add a comment and I can help further.
OK, your timer controls one circuit.
Locate the tabs on the timer dial.
Push down all the tabs.
Now lift all the tabs for the times you want your Load to turn ON
So if you want the Load to turn ON from 7pm to 5am, then lift all the tabs between those times.
Now when the timer dial rotates, the tripper tabs operate an on-off lever that turns the Load ON and OFF.
Set current time of day
The timer has to be set to current time.
For example it's 6pm.
Grasp and rotate dial until 6pm lines up with the stationary red pointer
Skipper wheel:
The 1015 series has a skipper wheel that lets you skip days of the week.
On these days the timer program will not turn the Load ON or OFF
So if your regular schedule is ON from 7pm to 5am, then the Load will remain OFF for those times.
Set skipper wheel:
Locate day to be skipped on the small dial.
Raise the set screws for the days you want to skip
Raise set screw until it is tight, but do not force
After a power failure, current time of day has to be reset.
If you need more help, add a comment and I will assist.
Nov 03, 2010 | Paragon 1015-00RS Indoor Multi Operation...
I just bought a woods timer model rand 1400 ( 49750) .\r\nI dont have manual can i set that for 18 hrs on 6 off . and how do i set it.
I specialize in timers
You can add a comment and I will answer
My files do not show a 49750
The Woods product site does not show a 49750
A web search for Woods 49750 shows no product
Below is a photo of the Woods manuals that I have. These manuals are for the programmable timers.
Are you sure you have the correct product number?
Add a comment so we can get your question answered.
I post the manuals for free.
Nov 01, 2010 | Hardware & Accessories
Grasslin Digital wall mounted timer programme setting instructions please
pdf file link, instructions will say it is for a topica500 also known as a logica 500.
Hope this helps.RoyG
Oct 31, 2008 | Hardware & Accessories
Solar Noma 7 Day, 6 Event Outdoor Timer - Easy To Use +warr Logo
63 people viewed this question
Top Solar Hardware & Accessories Experts
Gil Shultz
Bill Boyd
Gene Haynes
Are you a Solar Hardware and Accessory Expert? Answer questions, earn points and help others
