Question about Pioneer Audio Players & Recorders
Lights on fm/am tuner come on put not on rest of the system
SOURCE: I have a Sherwood RX-2030R,
Check Sherwood RX-2030R specification of AM tuning frequencies limits in user manual.
Please confirm was it tune before below 1320 and above 1710 AM meter band?
Posted on Nov 06, 2008
SOURCE: FM Tuner in Sherwood RX-4105
Check your antenna connections. Make sure your FM antenna is hooked up to the FM antenna terminal or jack on your Sherwood receiver. If you have the antenna hooked through the coaxial cable, check your coaxial cable with an ohmmeter for continuity. You can buy a volt-ohm meter as little as $12. Usually bad connection occur between coaxial cable and the the coax cable connectors. If that doesn't solve the problem, then there may be something wrong with your tuner card inside of your Sherwood receiver.
If you receivers display does not change channels or frequencies or AM or FM mode, when you try to change the channel or frequencies, or AM or FM mode, there may be something wrong with the front board of your receiver.
If there is something internally wrong your Sherwood receiver, you need to take it to a qualified technician that can fix it. Do not try to repair it yourself. If you don't know what you're doing, you can do far more damage to that Sherwood receiver to the point that would be very costly to repair.
Before you take your Sherwood receiver to a technician, try to unplug the receiver, and leave it unplugged for several minutes, and then plug it back in. If that doesn't solve the problem, then you need to take your Sherwood to a qualified technician.
Posted on Jan 20, 2009
SOURCE: RX-V1070 tuner fault
This only a cold solder symptom in tuner section .Just reworks all solder joints components parts in tuner section.
Good luck:
Regards:
Dont forget to rate.
Posted on Jun 30, 2009
SOURCE: Yamaha RX-V757: Tuner not working
Is it set for XM / Sirius? If so, you need their special antennae unit; or are you talking AM & FM?
Posted on Jan 12, 2010
SOURCE: Sherwood RX-5502 receiver - get
After doing all this troubleshooting on your receiver, Check if master volume on the surround levels are too low. Adjust master and surround level.
There may aIso incorrect selection of the input source. Select the correct input source.
If after doing this the problem still continue, it means the sound ic in the receiver is damage. the sound ic brings out the sounds from the receiver. You will have to open the receiver to locate the sound ic in the receiver and use the multimeter to read capacitors and change the damage ones.
Thanks for using Fixya.
Posted on Jul 11, 2010
Sep 25, 2014 | Audio Players & Recorders
Jul 14, 2013 | Panasonic Rx-5090 Vintage Ghetto Blaster
Feb 19, 2011 | JC Whitney SONY XPLOD 10-DISC CD/MP3...
Apr 10, 2010 | Audio Players & Recorders
Jan 12, 2010 | Yamaha RX-V757 Receiver
Jun 30, 2009 | Yamaha RX-V2700 Receiver
Mar 06, 2009 | Yamaha RX-V663 Receiver
Dec 19, 2008 | Audio Players & Recorders
Dec 02, 2008 | Sherwood RX-4105 Receiver
Nov 06, 2008 | Sherwood Audio Players & Recorders
Apr 05, 2018 | Pioneer Audio Players & Recorders
