I bought a pair of tannoy cpa 15. The speaker biding post are speaktron (commercial) Can I just run one wire from one side plus to an rca binding post and the same with the other to an rca negative binding post. That I dont have to deal with the xover (dont know how). thx
4 Suggested Answers
  • 130 Answers
SOURCE: Speaker connectors not holding
I use to have that problem and what i did was to strip more wire. Then fold the bare wire over a few times and try poking it in there. Maybe you can wrap some foil around the wires also. Must be foil with metal on both sides, not a ciggerette pack. You may also try a pencil eraser. Cut it in the shape of a wedge and try and push it into where the springs are this could work similar to the spring.
Posted on May 06, 2006
tech240
  • 169 Answers
SOURCE: Trying to hook up 2 Hi Fi speakers to a reciever
Red left to Red left speaker
Black left to Black left speaker
then repeat for right speaker
turn on amp play somthing quite to start, check all is working. To check speakers are in phase play a bit louder and stand exactly in middle, bass should be defined and central, it helps to close eyes and listen. If not central and defined change over Red and Black on one side only then listen again with the same test.
Start flat with eq section adjust as you like when listening to something you know and like.
After all is working ok then make it louder.
Sorted!
Posted on Sep 21, 2009
dunnbiker
  • 8546 Answers
SOURCE: i purchase a denon AVR-591
Take a clue from the bare wire speaker connections on a speaker not matching RCA connectors. RCA is not for feeding +/- speaker terminals on REAL audio equipment.
The Denon requires an active (self-amplified) subwoofer which it feeds a specialized Low Frequency Line Level Pre Out signal.
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/denon/avr591.html
Disassembling the parts of HTS and reassigning them to other makes and models is unwise and unpredictable electrically and sound-wise.
Posted on Feb 26, 2011
I have a Marantz turtntable, a Marantz CD player, an Eltax tape player and a Marantz amplifier with two Cambridge speakers, how do I wire them up please.
If you have a pure amplifier, there may only be one set of inputs, and one or two pairs of speaker outputs. The inputs are probably RCA plugs. Connect the CD or tape player to these. The speaker outputs are typically heavier binding posts or wire clamps. Each speaker should have one pair of wires. One for the 'Red' post, another for the 'Black' post.
If you have a 'Receiver' you will have several inputs to use and switches in front to select them. The CD and tape can be plugged into either tape, CD, or Aux inputs. (Not 'Phono') The speakers hookup is the same as for the amplifier.
You may also want to google the make-model of your amp to find a manual....
Mar 11, 2015 | Marantz Audio Players & Recorders
Rca grounding sound with samsung smart tv
I see you are using wireless speakers. The biggest problem with the residential grade is everything interferes with them. Make sure you are moved as far away from power sources as you can be. Direct line of site is not optimal but a fix as well. The wire you have connected for the send receive could be the issue as well. a shielded heavier AWG will help as well as grounding from the source equipment and dropping the ground on the other side.
Apr 13, 2014 | Parrot Zikmu Wireless Stereo Speakers by...
I have a Monster cable running from my receiver to my sub. The end broke of and it has a braided copper shield like coax and the in the middle it has two seperate jacketed wires in the middle. One is...
Is this CABLE with RCA plugs? The best way is to Ohm out the two wires and the orher end od the cable to see if the inner two wires are tied together or it is using double ground connections. The braid wire is for the shield/ ground fro sure.
If you want to use the binding post , you need to feed it from the speaker output terminals of the receiver since the binding posts are made for speaker level signal, not audio line level used for the RCA jack (much lower signal level than the speaker level).
Jun 21, 2011 | Televison & Video
New Yamaha AV Receiver and Tannoy Speakers muffled weak bass only
Maybe some wire is faulty... Try to disconnect everything and connect each speaker one by one, first trying only radio tuner and then trying to connect the TV and other devices. Using that you can isolate the fault into the specific component/wire.
May 26, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
How does the speaker wire physically connect to the Harman Kardon DPR 2005?
You have 7 pairs of plastic binding posts.
Unscrew the post until it comes out an eighth of an inch.
You will see two spaces in the black plastic one at the top and one at the bottom of each binding post. That space is for the wire. Strip half an inch of jacket off your speaker wire and slip the stripped part inside the hole and screw the binding post down on it and it will squeeze the wire against the contacts.
If you find that difficult since the posts are so close tommorow, a "Banana Jack" may be put on the wire then pushed into the hole in the binding post.
It is difficult to describe in writing but onece you see it you will understand.
Black posts are the negative, they are all on a common ground. Coloured posts are positive.
Dec 23, 2009 | Harman Kardon DPR 2005 Receiver
I have a pair of TDL studio 10 speakers, both bass cones on one side are dead...any suggestions?
I'm guessing that you have Bi-wireable binding posts on the back and your jumper straps are not installed. You'll be able to tell if they are biwireable if there are 4 sets of speaker connections vs the standard two. When you are only using one set of speaker wires you need to have metal straps installed between the upper and lower pair of connections so that all of the drivers are getting signal.
Jun 06, 2009 | Audio Players & Recorders
I am not very technically literate with respect to audio/video. I purchased a Cambridge Audio Azur 840a V2 Integrated Amplifier last week to replace an Arcam A70. I have a pair of Tannoy DC3 speakers, as...
get an Ohmmeter, take a reading on each speaker line one at a time, on both A & B speaker lines. You should get a reading of 8+/- ohms. The speaker switch with the 6 spks will probably read almost 0 ohms when all 6 are running. That is what your amp is not liking. Try running it with one set of speakers on the switch,with the Tannoys on ch A on your amp and the switch on B. add one pair of the 6 at a time and you'll see that it won't like all 6 at once. 2, maybe 4, at a time is probably what you'll find to work.
Good Luck.
Dec 18, 2008 | Cambridge Audio Azur 840A Amplifier
Tannoy proto j plus. . .
Don't know but I've a pair of Proto-J's for 5+ yrs as my main spkrs and they are the best I've ever had / heard (for anywhere near the $200/pr. price I paid) - you won't be sorry - I'm sure the pluses are great - But I know the Proto-J's are killer....the dave
Jul 29, 2008 | Tannoy Proto-J Plus Main / Stereo Speaker
307 people viewed this question
 Grubhead
Grubhead
