Question about Exercise & Fitness
I have a life fitness treadmill. My four year old son got too close while I was running and got his blanket sucked in the bottom side of the belt. I cannot pull it out. Any ideas?
  • 708 Answers
You should be able to access the belt spools by removing the side covers. Then try and turn the spools in the opposite direction to pull the blanket free. If this doesn't help listhe model, series and make of your unit and I can help you out.
Posted on May 18, 2014
vpaaf
  • 115 Answers
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
Posted on May 01, 2009
  • 74 Answers
SOURCE: I am moving and my treadmill won't fit thru the door
Follow the steps from the user/assembly manual in reverse. Find the manual here:
http://us.home.lifefitness.com/resources/content/8/2/0/documents/T3%20Manual.pdf
Installation begins around page 9
Posted on Aug 29, 2009
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
bwinton
  • 83 Answers
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Posted on Mar 24, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have a life fitness treadmill and put new wax in
you will need to go into service menu by pressing and holding the pause button then pressing the clear button twice , continue holding the pause until the service menu appears. then use the arrow up and select maintenance press enter then either use arrow up or down scroll and say refill waxer system or replacing wax bag press enter, this will reset upper console. Upon completion of this the go back into the diagnostic menu select system test press enter scroll up or down to waxer manual mode hit quick start and that will fire up the wax pump and your done
Posted on Apr 12, 2010
I have a life fitness next generation treadmill and the belt has slipped all the way over to the right hand side and is unusuable. How can I fix?
Belt adjustments are on the back of the machine on either side on the rails. Loosen both off first to slide belt over towards center. Then tighten slightly. Run treadmill on lowest speed and adjust from side to side until belt stays centered. After it seems to stay centered run treadmill on high to see if it stays centered and make small adjustment until it does
Jul 09, 2014 | Exercise & Fitness
Belt keeps slipping on treadmill and belt is all the way back
If you have adjusted the tension on your belt to the max, it is more than likely time to replace your running belt. The running belt naturally stretches over time. I would suggest replacing the belt and flipping your deck. If the deck has already been flipped once, then you would need to replace the deck as well. Life Fitness Treadmill Belt and Deck Replacement Video 95T
Apr 01, 2014 | Life Fitness 91Ti Treadmill
Lifefitness treadmill belt sticks even though wax bag is fulll
alot of times you have to remove the wax spray nozel and clean as the wax hardens over it
It shut offs
Questions for analysis:
How old is this machine?
What is the condition of the walking belt and deck?
(most problems with treadmills cutting off during use stem from worn walking belts and decks - replacement is always recommended unless unit is less than 1 year old)
If you are able to walk on the edges of the walking belt (away from the center of the deck), run a test to determine if unit is still shutting off. If not this may be another indication of excess friction in the center (walking) area of the walking belt/deck. The only way to be accurate about this test would be to perform an amperage test, testing the machine unloaded, with load at 3mph, and with load walking on the edges of the walking belt
Nov 25, 2013 | Life Fitness T5-0 Treadmill
I have a life fitness t5 and live in the middle of nowhere in new Mexico. I run at 6.5 mph for 40 minutes around 5 times a week. I have used it for approx 1 year. It is impossible to get reliable...
Dear Sir:
I will indicate some Tips for maintenance:
Any equipment is difficult to survie without a properly maintenance.
But you can do something very simple.
Cleaning Dirt and debris is a major cause of premature belt and deck wear. Clean between the belt and the deck once per week. Also clean the small exposed areas of the deck on each side of the belt. Dirt tends to accumulate in these areas. Wipe down the entire treadmill once per week. The outside surface of the belt can be cleaned with a damp sponge or cloth. Vacuum or wipe up the area around your treadmill at the same time. You should clean the motor area three or four times per year. Unplug the treadmill before removing the cover. Follow the instructions in your owner's manual for removing the cover. Carefully vacuum the dust and debris from around the motor.2)
Lubrication Read and follow your owner's manual for lubrication recommendations. Some treadmills do not require lubrication. In fact, unnecessary lubrication can cause damage. Many decks are made of materials that do not require lubrication or are pre-impregnated with wax. Lubricating these types of decks can actually increase the friction between the belt and deck, which can lead to motor damage. If your treadmill does require lubrication or waxing, follow the manufacturers guidelines.
Belt Tension Belt tension is pre-adjusted at the factory, however, new belts will stretch and require readjustment. If the belt is too loose, it will slip and cause excessive wear to both the belt and the deck. If the belt is too tight, it will cause wear to the rollers and to the motor. The belt should be set just tight enough so that is does not slip. With the belt running slowly, stomp your foot forcefully down and slightly forward on the belt. If you feel the belt slip, tighten both bolts 1/4 turn. Again, follow your manual for instructions specific to your make and model.
Belt Wear There are two components in your treadmill, which will require periodic replacement - the belt and the deck. Check the condition of your belt every three months. Feel the underside of the belt. If it feels rough and worn, it may be time for a new belt. Continuing to run on a worn out belt will increase the wear on the deck. The deck will eventually wear out also, but if you replace your belt when necessary, you will increase the life of your deck
I hope this will be keep your safe with your equipment.
blessing.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Sep 13, 2011 | Life Fitness T5-0 Treadmill
I have noticed a few times that my f3 life fitness treadmill changes pace on me, and so does the incline. i can see it on the monitor, also it has started feeling like the belt is catching or something, or...
It might just need a simple adjustment of the running belt that can eliminate the slipping refer to you owner's manual for the procedure. It will be close to all treadmill adjustments.
Here is a generic procedure for adjusting the belt:
If the walking belt slips when walked on. Run the treadmill @ 3 to 4 mph, walk for a few minutes, Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. Then repeat adjusting procedure until walking belt is properly tightened.
Jul 18, 2010 | Life Fitness F3 Folding Treadmill with...
Belt is slipping,
It might just need a simple adjustment of the running belt that can eliminate the slipping refer to you owner's manual for the procedure. It will be close to all treadmill running belt adjustments.
Jul 06, 2010 | Life Fitness 9000 Next Generation...
Life fitness 95ti belt moving to one side any way of correcting
If the walking belt has shifted to the left, use the Allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left rear roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centred.
Jun 09, 2010 | Life Fitness 95Ti Treadmill 95 Ti
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
