Question about Vector Vec051d DC/AC Power Inverter
Wattage meter not working
Power light on, 120v equipment works fine, but wattage meter doesnt
I have a sunny boy 5.0kw inverter and want to know what my total usage if for my house. how do i set this for the inverter to read the supply meter in my meter box
no idea as to the wattage used in your house as it varies with the equipment
you have to go around and add all of the wattages in use your self ---lights each, fridge , freezer , stove , fans each , air conditioners each, toaster , microwave etc and add then all up that will show the total wattage in use for the house
then you can put that in your supply meter
Jul 16, 2017 | Inverter Electronics - Others
Electricity current eratic
The output of the generator is listed as a constant voltage and a maximum current or wattage - that could also be thought of as capacity.
Typically, it would be rated for 120 or 120/240 volts for generators sold in North America and the wattage could be as low as 3,000 - 5,000 to substantially more than that. If you were to look at the watts or amps while a connected light bulb were turned on, you would see the voltage stay at 120V, but the amps would go from 0 to .833 Amps - and the wattage from 0 to 100 (assuming a 100 W bulb). Next, connect a toaster - again the voltage stays at 120, but the amps and wattage would jump from .833A and 100W to 8 or 9 amps and 1100 watts. As soon as the toast was done - the amps and wattage would drop back to .833A and 100W. The same could hold true for a well pump or air conditioner that is connected to the generator.. these devices turn on and off automatically as determined by a pressure switch or thermostat. Seeing a wattage or current that fluctuates is normal as the amount of power needed from the generator changes as the devices turn on and off by them selves.
Also, it is not unusual for motor operated devices to draw 2 or 3 times as much amps or wattage during the first few seconds when starting as opposed to what it uses when running.
May 18, 2015 | Electrical Supplies
Will my new LED malibu lights work with with my ML200RT transformer? They use considerably less wattage than my old bulb type lamps.
Malibu puts out 12 Volt AC without specifying type of bulb
If new bulbs work on 12 Volt AC, then they should work
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#install
Wattage on bulbs should match power pack wattage, or damage can occur to power pack.
Buy new power pack, call Intermatic, or Try it out and see if it works
Sep 05, 2014 | Hardware & Accessories
I need to know the wattage of my magic chef oven model 6898VV
Hi Nadia,
There's little to be found on the internet for this model oven now. There should be a name plate / manufacturer's sticker either inside the door - on the jamb; or on the rear near the power cord. If you see a rating given as "120VAC / 1200W" this would indicate INPUT wattage, which would be higher than the amount used for cooking. A typical 1200W rated microwave might have 800 - 1000 Watts of cooking power. If there are 2 ratings for wattage like 120V / 1200W / 850W; the 850 Watts is the amount of cooking power. The cooking power - or wattage - is always lower than the total wattage. If you see a rating somewhere that indicates 900W cooking power, then that would be the cooking power of the oven.
If you're not satisfied or unsure about the information you're finding on the oven - or it is missing - you might want to contact Magic Chef Customer Service Department at (888) 775-0202. They should be able to help you - or pint you in the right direction.
Apr 07, 2014 | Magic Microwave Ovens
I just put in a set of headlights on my 05 350z. They are they Spyder smoke and are plug and play. Hooked up HID and they worked fine, for a few minutes. Passenger side still works fine on low beam but...
For starters, "..worked fine, for a few minutes." sounds like a current overload issue. Is the headlight wattage greater than the wattage of the bulb(s) you are replacing? If so, you're asking for trouble; the least being burnt wires and circuits. Worst case would be a fire.
Assuming you're within wattage specs and assuming you've checked fuses, it's a matter of using a test light working backwards from the headlight ( if you have power to the headlight but light does not work, you either have a bad bulb or it is not getting "grounded").
Feb 16, 2014 | 2005 Nissan 350Z
Power ct70 wattage = ????
In the US (110/120V model) the CT70 is a 970 watt toaster
If this helps, please be sure to hit the "thumbs up" for me.
Feb 21, 2010 | Breville CT70XL 2-Slice Toaster
What is the wattage for the WS-65411?
POWER
AC 120V 60Hz
240W
Only WS73411 takes 275W otherwise, all other model with this series like
WS48311
WS55311
WS65311
WS55411
WS65411
WS73411 take 240W as yours.
Hope you are talking about main wattage. Audio wattage is exceptional.
best of luck
Jan 27, 2010 | Mitsubishi WS-65411 65" Rear Projection...
What is the wattage on my kenmore 90 series washing machine?
if there is any power label at all you may be able to figgure it out. If you find a tag on the back that has something like this-
Model XXXX
Serial XXXXX
120 V 60 hz 12 A
To get the approx wattage, volts x amps= wattage
So in this case.... 120v x 12a = 1440 watts
Hope this gets you somewhere....
Dec 15, 2009 | Kenmore Dryers
NEED TO CONVERT 230V TO 120V
You need to buy a power converter to be able to do this. check the wattage requirement for your dryer then get yourself a power converter with the same wattage or higher. Usually, dyers consume around 1000 to 1500 watts.. so you probably need to get yourself a 1500 watt power converter or AVR (automatic voltage regulator) AVRs usually has 220v and 120v sockets...
May 26, 2009 | Dryers
Open Questions:
See all Vector Vec051d DC/AC Power Inverter Questions
Vector Vec051d DC/AC Power Inverter Logo
27 people viewed this question
Top Vector Electronics - Others Experts
Matt Olenzek
Matt Olenzek
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
