Question about Homelite Garden
How to reduce fuel flow home lite leave blowers
Runs perfect , uses way too much fuel empties fuel tank in mins
4 Suggested Answers
  • 59 Answers
SOURCE: my home lite blower wont start not getting fuel
Primer bulb pumps fuel from gas tank to carb. Once started gravity takes over.
Posted on Oct 09, 2009
rwvanlue
  • 486 Answers
SOURCE: stihl bg 55 blower runs good for 5 min. then loses power
1) carburetor gaskets/diaphragms may need to be replaced
2) ignition coil may be breaking down when hot
3) check compression when cold, then after it stops, when hot
4) could have a vacuum/pressure leak
*I would investigate carb first
Posted on Nov 08, 2009
  • 21 Answers
SOURCE: blower does not start. carb
how many lines run into the carb or come out of the gas tank maybe you got them mixed up
Posted on Nov 30, 2010
Why does it run for 10 mins, then stops?
Loosen Gas cap and see if that helps. Many times the Gas tank Vent gets clogged. When engine runs, it creates a suction and starves the engine of gas.
OR
If the engine was stored with gas in it, sometimes the Rubber seat in the carburetor deforms and wont let the gas flow into the Carb Bowl at a fast enough rate to keep up with the running engine. The bowl empties (after 9 minutes) and the engine quits. Takes a while for the bowl to refill (5 minutes).
Jan 16, 2016 | Toro Snow Blowers. Power Clear 621 QZR 21...
Blower shots off when trigger is pulled?
Try applying about half choke and see if engine will run. If it does than I expect the fuel is stale and if the unit has recently come out of storage the fuel in the carburetor has evaporated while in storage leaving a residue behind
This residue restricts the fuel flow and the engine runs lean. Appling choke compensates for the restrictions in the fuel passages.
Replace the fuel in the tank with fresh fuel.
Run the unit with partial coke if required.
After some run time the carburetor (from the engine vibration and clean fuel flow) will likely clear eliminating the need for the choke..
Ready mix fuel if the machine is not used often is available from Lowes or Home Depot. This fuel has the oil mixed and does not contain ethanol one of the causes of the carburetor contamination.
Nov 30, 2015 | Garden
My fuel tank runs on diesel I put premium unleaded gas in error Need to drain the tank It is a 2005 pathfinder 7 seater Help! jobever1@yahoo.com
JUST DRAIN OUT GASOLINE IN FUEL TANK.CHANGE FUEL FILTER AND.FILL UP TANK WITH DIESEL FUEL. ENGINE WILL RUN ROUGH UNTIL ALL GASOLINE LEAVES THE FUEL LINES.
Mar 01, 2011 | 2006 Nissan Pathfinder
Runs for awile...but then blaa blaaa blaaaa....like a dead plug...wait fifteen minutes and she runs again,perfect for a little wile then blaa blaaa blaaaa all over again...all the way home...it has lights...
check your vent on your fuel tank cap and hose must be open or will pull a vacume. make sure there is nothing in tank that could shut off fuel like a leaf. make sure the petcock on tank flowes unrestriced through the screen. if you have a fuel filter make sure it flows free. check coil run it till it quits. then feel the coil with bare hand if to hot to hold on to replace it is breaking down.
Oct 17, 2010 | 2003 Yamaha WR 250 F
I am having running problems with my 2004 Yamaha Roadstar. I drove the bike at spring break 2009. Bike sat until yesterday. I tried to start it but the battery was dead and the gas was bad. Recharged the...
You have done a good job ... pat yourself on the back ... following that, go get some injector cleaner and add an appropriate amount to your tank and go for a ride. Do what ever you need to do to keep from pushing it home. I think this will solve your trouble.
May I recommend a fuel stabilizer for your fuel for future periods of time when you will not be riding? StaBil is a good brand but there are others as well.
Thank you for posting your question on FixYa.com
Please vote
thanks
a
Nov 09, 2009 | 2004 Yamaha Road Star
My craftsman 205mph leaf blower starts and runs for 4 min stalls
Replace the fuel filter that is inside the fuel tank. Purchase a can of Seafoam Motor Treatment. Ask for it at most auto parts stores and WalMart. Pour in the correct amount as listed in the instructions, and fill the tank with fuel. Start the blower and run it wide open. If your problem is a fuel system problem this may very well solve the problem. This is one of the best fuel system cleaners you can buy.
Nov 07, 2009 | Garden
Hi. My craftsmal leaf blower runs OK for 3-5 then dies????
Could be a blocked vent on your fuel tank - is there a vacuum in the fuel tank immediately after it stalls?
Oct 25, 2009 | Craftsman Garden
Honda 5.5 HP starts & dies
had the same problem with my Honda engined mower. you can't see it easily, but there is a very fine screen in the outlet of the fuel tank that gets blocked and fuel will not pass thru it fast enough to refill carb. remove tank and pour fuel in another container . Use a flexible plastic tube in the outlet or make a small wire hook to penetrate the screen,or preferably, remove it. confirm that fuel flows freely thru it, remove any debris, and reassemble. Change spark plug, add fresh fuel,and test. best of luck!!!! Ray
Dec 18, 2008 | Honda Chipper Blower and Vac: 5.5 Hp Gas
Garden Logo
23 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
