Question about Kenmore 43142 Front Load Washer
The cylce stops and reads f2 - Kenmore 43142 Front Load Washer
  • 15,935 Answers
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Kenmore washer model 110 82781800 won't cylce, just hear timer ticking
If the motor is going thru cycles and the agitator doesn't move, than it means the drive link snapped. cheap repair. it was made to protect the motor and trans. Read the manual before doing this. it will show you how to do it easily. iv'e done mine around 4 times. my wife keeps jamming too many clothes into the thing.
good luck
Apr 10, 2014 | Kenmore Washing Machines
Frigidaire model RE36BNW*3 F2 alert. The cancel button shows an F2 signal. Cannot stop the F2 alert with the can button.
Hi
F2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 23, 2011 | Ovens
Received E6 and F2 code. repair man replaced the control panel key padand it worked for a while. stopped working and got same codes E6 and F2. Repairman saw the control's behind the key pad needed to be...
Hello & Welcome to FixYa
F2-E6 error code indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure then before replacing the sensor you can test it with a voltmeter for around 1100ohms....if it reads more then 1120 ohms then it needs replacement however, if the reading is between 1080-1120 ohms then it is the control board that needs replacement. However, after reading your problem it seems that the sensor is causing this and replacing it is recommended repair. Please get back to me if you have any other questions.
Kevin
Mar 15, 2011 | Whirlpool GBD307PR Electric Double Oven
My washer will run up until the spin cylce. I wont drain the water or spin, it just stops. My roomate followed your suggestion on this site to check the pump and pipes to make sure they were clear. He siad...
Twist timer very fast a few times and stop it on spin with the lid closed. Wiggle the timer to get the points to connect. Even if you
just get a little bump then its the timer.
If none of this works then it is the timer plus maybe something else contributing.
Don't forget to check the lid switch plunger on the lid
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 06, 2010 | Frigidaire FWS833A Top Load Washer
Samsung j845 oe error
What you need to be looking at is the water lever sensor. Take the top off by removing 2 screws in the back (Top right and top left). Slide the top off. Now you want to be standing in the front. The front right side is the sensor. Make sure the hose is properly connected underneath. If you have a meter, take a resistance measurement across the two end pins. Should read about 20 ohms or so.
Dec 13, 2009 | Samsung Washing Machines
My ac was working and then just stopped.
NO that means that the system is working properly.The switch is a low pressure swtich and it is in the open position because the system needs a charge, if you bypass the switch you run the risk of burning out your A/C compressor. The refrigirant is also a lubricant.
Sep 24, 2009 | 2003 Honda Odyssey
On HE3T wash stops in middle of cylce and flashes F2
"F02" is a Long Drain error. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Most commonly, your drain pump has something clogged in it causing the drain flow to be obstructed. I would begin by checking the drain pump reservoir. I provided a follow-on link with the advice I gave you that explains how to do this. If you have any questions along the way, please let me know. I hope this helps you.
May 02, 2009 | Kenmore Elite 45986 Front Load Washer
F 2 error code
Hi KG Oliver,
This is a common complaint on the Whirlpool built Kenmore's. Please follow this link to my solution for it.
Thanks,
SG
Apr 05, 2009 | Kenmore Washing Machines
Kenmore 43142 Front Load Washer Logo
23 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
