Question about Logic Controls LD3000 Series Pole Display Monitor
Chevy s10 has trouble code: P1442. what does this mean?
WHAT WOULD CAUSE US TO HAVE NO POWER IN 1ST 2ND 3RD GEAR ON A 1998 CHEVY S10
Did you accidently disconnect the wire to an O2 sensor? Sounds like it is in limp home mode. Take it in for a free trouble code read at Advanced Auto.
Sep 30, 2014 | Ipcw Chevrolet S10 / S-pu 1998 1999 2000...
P1442 isuzu 1996
its g-sensor located at under chassis rear passenger near gas tank
Oct 01, 2012 | 1996 Isuzu Trooper
91 chevy s10 uses more gas check engine light stays on and when i first start to drive it in the mornings i press on the gas it doesnt do anything i have to pump the accelerator what can i do
Check the ECM for trouble codes. You can research the internet for the steps to access the codes and what they mean. There is a plug under the dash - you jumper two terminals to make the check engine light flash.
Jun 25, 2012 | Cars & Trucks
I have a 98 chevy s10 4x4 that when in drive the gear indicator "D" flashes. Does this mean anything? Thanks Mike
The flashing D is a trouble code from the electronic transmission controller. The flash pattern can be used to diagnose what the problem is. Something is not right with your transmission. Take it to the dealer or a mechanic and have it tested. Hope this helps, James Booth. PLEASE RATE THIS!!!
May 21, 2011 | 1998 Chevrolet S-10 Pickup
Dtc 1442 and 1446
P1442
The code actually has another character in front of it, most likely a P (Powertrain) code as they're most common, although it could also be a B (Body) or C (Chassis) code. So it's likely P1442 and it's description is Evaporative Emission Control System Leak Detected. That code is specific to Toyota vehicles, although it seems nearly identical to the generic code P0442. This error pertains to the emissions system in the car. You now have the choice of either taking the car to a qualified technician or you can try a few troubleshooting steps yourself. If you're not mechanically inclined, I would recommend you change the gas cap to a brand new Toyota one (not a cheap aftermarket one), reset the code and see if it comes back. If the code returns there are additional steps you can take. Take a look at this P0442 article for other ideas.
May 18, 2010 | 2006 Toyota Sequoia
What do the trouble codes mean? p0305 and p0135
P0305 IS # 5 CYLINDER MISFIRE DETECTED.P0135 IS BANK 1 SENSOR 1 OXYGEN HEATER CIRCUIT FAILURE
May 01, 2009 | 1997 Cadillac Eldorado
Computers & Internet Logo
18 people viewed this question
Top Logic Control Computers & Internet Experts
David Payne
David Payne
Are you a Logic Control Computer and Internet Expert? Answer questions, earn points and help others
