Question about Crosley CLCG500FW0 Washing Machine Replacement Washer Lid Lock Switch Assembly
Crosley washer lid want lock - Crosley CLCG500FW0 Washing Machine Replacement Washer Lid Lock Switch Assembly
    Novelist:
    Scholar:
  • 166 Answers
Bad switch, loose or disconnected wire harness, or bad control board.
Posted on Jan 03, 2015
2 Suggested Answers
  • 2468 Answers
SOURCE: crosley front load washer one year old. doored
your drain pump or hoses are blocked with foreign material,either coins,hairpins,detergent residue from earlier washings,remove the front lower access panel if provided to access the drain hoses and pump and also check the drain itself,some washers have the access door in the back side of the machine,if the stand pipe in the house is slow to drain it can back up and cause back pressure and the machine will sense this and stop also
Posted on Nov 11, 2010
My washer keeps blinking lid locked and it will not do anything else
Typically, that would be caused by failure of a cheap chinese control board. In fact, failure-prone chinese control boards are at the heart of virtually all premature failures of modern appliances. They usually only last just long enough to span the warranty period.
There should be an electrical schematic diagram attached to the back of the unit. You may be able to use that to identify the faulty part. Don't be surprised if the replacement board costs alot more than it's size and simplicity might indicate.
Dec 28, 2014 | Crosley Washing Machines
My crosley he top load washer hit start/ it senses/then lid lock flashes and nothing!
Dec 05, 2014 | Crosley Washing Machines
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
Lid lock broke
My lidlock is broke, is there any way to bypass that so washer will work?
Sep 22, 2012 | Crosley CAWC529JQ Top Load Washer
Door is open and it want shut seems to locked but the lock light is not on
Sounds like your lid switch and timer are not communicating correctly. Please contact a professional to determine which needs to be replaced.
Jul 21, 2012 | Crosley CW5000 Front Load Washer
Crosley 1244 washer won't cycle
This indicates a faulty lid switch.
Apr 27, 2012 | Crosley Washing Machines
How to bypass lid switch
uplug power. remove switch, then tape the wires together. this will make a complete curcuit, so it should run. good-day !
Mar 29, 2012 | Crosley CAWC529JQ Top Load Washer
Water will fill into my Crosley front loader CW5000 but will not start washing, rinse, or spin
Sounds like you have a motor issue, listen when you press the start button, if you hear any squealing noises or any of the noises the system usually makes doesn't occur, then you probably have a motor issue, you may need to have your motor replaced
Jan 05, 2010 | Crosley CW5000 Front Load Washer
Crosley CLCG500FW0 Washing Machine Replacement Washer Lid Lock Switch Assembly Logo
88 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
