Question about Xerox Office Equipment & Supplies
Black lines on drum that print on every print
  • Xerox Expert
  • 398 Answers
Bad drum blade try that first drums get expensive.
-Carl, please let me know if this helps.
Posted on Jun 26, 2009
Got a ir2225 canon copier printing some white lines, anyone know why?
quite possibly you might need to do a head clean or a re-alignment of your printer.
Dec 12, 2014 | Canon Office Equipment & Supplies
Getting a black line on paper when printer warms up...
Black lines on copy come from toner cartridge, or drum unit, or fuser unit which is in the back. check drum and see if you can see line, back of machine with flash light you may be able to see line on fuser roller. Be carefull Fuser is hot.
A copy that is good and then starts to get lines usually the drum unit...
Mar 26, 2017 | Brother MFC-9840CDW Laser Printer
Our Hp 5550 prints thin vertical black lines on high res images. They are evenly spaced (3cm apart on an A4 print).
This is caused by a damaged drum. The drum is the long metal cylinder inside the toner cartridge. You will have to replace the hold cartridge. You should be able to flip a plastic cover on the toner and see the drum. If it has black toner lines then it usually means the drum is scratched and there for toner fills the scratch and produces lines.
Replace the print cartridge (toner cartridge) and the lines should go away.
Jul 19, 2011 | HP LaserJet 5550 Printer
My copier machine is printing out black lines.
Hi, does stripes appears only on copies or also on printed images?
If only on copies that means that you have to clean the copy glass.
If on both, its probably drum unit that causes the problem. Usually the stripes are slim, and verry close to each other, like a sharp brush paint job.
How many copies do you have with these drum? check it on 123 button.
If the copie is on one side totally black and the toner isnt fixed on paper that means that you have to replace fixing film.
For service manual write me on emma.servis@gmail.com.
Hope that helped!
Jul 30, 2010 | Canon imageRUNNER 2270 Copier
Black solid line on the right hand of page when
Hi, remove the black drum and clean the corona wites and drum GENTLY with a LINT FREE CLOTH. If there uis no change in the print quality you may need to replace the black drum. Hope this helps
Feb 18, 2010 | Epson Aculaser C1100 Printer
Problem for print by photo copier
sounds like the charge grid is not set properly in the drum unit..did you et up the drum unit properly and run the new dev and drum set up..if youy are getting black the charge is not working correct as the charge of the drum help to keep the toner from adhering to the drum surface when copying .. I would take the drum chrge unit out again and check it is set in the right way when you put it back on also check the contacts arent put out of line.
Aug 05, 2009 | Kyocera Copystar CS-1820 Black and White...
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
SOLID BLACK LINE FROM LEAD EDGE TO TRAIL EDGE
"dk" means the the life black drum is over. You need to replaced the drum and blade. Or you can replaced the whole drum cartridge. The line that you are getting from one of the blades, more likely from the black drum. Pull out all the drum check if there is toner on the drums.
Mar 20, 2009 | Sharp AR-BC320 All-In-One Led Printer
Black line on prints from Kyocera fs2000d
remove the drum by opening the LHS of the printer & removing the toner waste bottle, then depress the grey button on the drum assembly & firmly pull the assembly out. Best done in a darkish room as the drum is light sensitive.
The black line couldn't be fixed as it is caused by a scratch less that 2mm long on the drum. Ether a new drun at £299 or a new printer ar £245..
Dec 03, 2008 | Kyocera FS-2000D Laser Printer
81 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
