Question about Canon EOS 600D Rebel T3i Digital Camera
New 32 sd card showing full after 4 pics, why?
  • Canon Expert
  • 488 Answers
Try formatting the card in your computer then put it in the camera and format it in the camera as well.
Posted on Sep 02, 2016
3 Suggested Answers
  • 11967 Answers
SOURCE: Memory Card Error
You could take the card to a store that has a Kodak picture maker machine (Walmart, etc.). From there, you can print your pics or even make a cd of them. The card may be faulty or just may not work in Canon cameras.
Posted on Aug 28, 2009
  • 4738 Answers
SOURCE: New pictures I am taking with my camera are
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Feb 21, 2010
Camera saying memory full but card brand new
Not only the size is important, the manual says SD max 2 GB.
But even a 1GB SDHC card won't work, because the camera is not compatible with SDHC and SDXC.
They used to make SD cards up to 4 GB, but most new cards from 1 GB and up are SDHC and above 32 GB the cards are SDXC. Older camera's can't handle these cards, although they look the same.
To read more and to understand compatibility from device versus Memory card, read this:
Secure Digital Wikipedia the free encyclopedia
Apr 10, 2015 | Samsung Digimax D73 Digital Camera
What is the class of this card? 4 or 10
If on the card is no C with the 4 or 10 in it, it even can be worse. As you can see on the picture a Class 10 card sometimes only has a C with the 10 inside.
The 32 Mbyte card you show here, is an old SD card and in those days they only gave read and write speed in Mega byte / second, if it was a real good card. If it should be a class 10 card with say 40 Mb throughput a second you would have 0,8 seconds to completely fill the card.
In a modern photo camera with 12 or 16 M pix, it could hold 3 or 4 pictures and it would be full.
Jun 22, 2014 | Canon 32mb Sd Memory Card Sdc-32m
When i remove the sd card to upload photos to my computer my new pictures are not there but are when the sd card is in the camera?
There are two possibilities that I can think of. 1) The SD card is full. You will need to copy the pictures off the SD card and onto your computer, then format the card. You can probably do this in the camera, but MAKE SURE you have copied the pictures you want to your computer because the format will erase everything. 2) The SD card is write protected. Look closely at the SD card there is a little slide switch that "locks" the SD card so that your camera cannot put any pictures on it. This slide switch must be in the unlocked position (or NOT locked).
Hope this helps.
Feb 02, 2013 | Fujifilm FinePix S4250 Black 14MP Digital...
Im trying to transfer pics from my sd card in my camera but it wont work. it will show that there is a pics on my camera but not on my sd card. when i put in a 1 gb sd card it will show the pics on there...
The C330 works with SD cards, which max out at 2GB. Your 4GB card is actually an SDHC card and will not work with the C330. Thus when you put in the 4GB card, the camera completely ignores it.
Oct 23, 2012 | Kodak EasyShare C330 Digital Camera
Samsung s1030 digital camera keep showing memory full but have inserted new sdhc card how do i clear this as i cannot take any pics
Clear it by putting in a compatible memory card. The S1030 works with SD cards. Your 8GB SDHC card in not compatible. You need to use SD cards, 2GB and smaller.
Sep 08, 2012 | Samsung S1030 Digital Camera
Bush card error message
Not compatible with the new camera.
Oct 20, 2017 | Video Cameras
4gb micro sd card says its "full" when its empty
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
May 08, 2009 | SanDisk 4GB microSDHC Memory Card
Chip says full after few pics
The chip may not be inserted correctly. You can tell by seeing or not seeing SD symbol in the view screen. Try removing the SD card. Go through the memory and see if the pictures were saved to the camera or to the card. If the pictures were saved to the camera, turn off the camera and re-insert the card. See if the cards responds by showing more pictures available for taking and move the pictures to the card. If the pictures were saved to the card, then the card may need to replaced.
Dec 31, 2008 | HP Photosmart R717 Digital Camera
Unable to view pics
Copy the existing photos on to your PC, switch off the camera. Remove the SD card and format the SD-card using a SD-card reader, this will clear all the card contents. Now try using it in your Camera again. Ideally, you should be able to save photos on this SD card. Other way would be to insert another SD card into your camera and click photos and check whether those photos are being saved into the SD card(this can be done using display option in your digicam.)
Dec 17, 2008 | HP Photosmart E327 Digital Camera
Canon EOS 600D Rebel T3i Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
