Question about Vehicle Parts & Accessories
1999 30 foot camper
Where is the fuse box in my trailer
    Master:
  • 710 Answers
It is under the seat.
Posted on Aug 31, 2014
Where is the fuse box on my 01 forest river salem 26 foot pull behind camper
I've had RV's with fuse/breaker boxes just inside the entry door and my motor home has vehicle fuses under tip up dash, RV fuses (breakers) near floor under fridge.
May 27, 2017 | RVs
Have 2008 nissan frontier when hooking to camper brakes and turn dont work checked back same/ is there fuse in front
There are a number of different methods of wiring a vehicle for towing depending on what is required.
Your vehicle probably uses a CAN-bus system and great care must be used when wiring for towing unless a genuine Nissan wiring harness is used. What fuses used and where they might be is something I am unable to comment about.
Wiring for towing and the wiring and lighting of trailers, campers, caravans are notoriously unreliable and short-lived unless completed to a very high standard and superior materials are used. When there is a fault it could be caused by either and it is important to suspect both and test both independently.
The first step should be to eliminate the camper, trailer or caravan as a possible cause by either plugging it in to another vehicle or using a substitution or testing box or device.
I have such a box that is invaluable to people who tow. It allows me to test the vehicle wiring and the trailer wiring.
Alternatively you could try plugging a known good trailer onto your vehicle for test purposes. It it is decided the vehicle is at fault it usually pays to examine the inside of the socket first to check for corrosion. I recently encountered a socket that was full of water and so badly corroded a couple of feet of the wiring had to be replaced. - and it had happened in only a year...
Apr 22, 2017 | Nissan Cars & Trucks
How much per foot for a 5th wheel camper trailer
There is no set price.
5th wheel campers range from free to 10,000 dollars per foot, depending on who is selling it and whether it be new, used , or junk.
(The 10,000 a foot will be one that is custom made for you.)
If you want a more accurate figure, contact a dealer or look on e-bay.
God bless your efforts.
Feb 24, 2017 | Cars & Trucks
Ive got a question about a 22 ft companion travil trailer
Plug it back in to the house electrics .then search for the inverter on the trailer .
Oct 13, 2016 | Coleman 1997 Fleetwood Sunridge Power...
I have a 2000 f250 diesel just bought a camper and the running lights worked when i left when i got home the no longer worked
I think there is a separate fuse box near the brake master cylinder for the trailer plug.(could be newer models) Fuse #4 maybe? I would get a test light and just check every fuse there is in the fuse box. the owners manual may be more help.
Sep 14, 2011 | Ford F-250 Cars & Trucks
Can't get the lights on camper to work when I turn on a signal light both tail lights on camper flash thats the only lights that work . I drive a 2004 silverado
if they camper was wired for an older/other make of truck it might be different check to see if the yellow(left side turn/brake) wire maybe connected or crossed with the green(right turn/brake) wire,also see if the plug in wiring under the rear bumper is a stock plug in or if some one tried to go cheap and use"scotch-locks" on the tail light wires and crossed something under there,the parts store sells a plug in tester for your truck's particular plug that will tell you if the truck has the issue or if it's the camper,also check the ground,hope this helps,and good luck
Aug 26, 2010 | 2004 Chevrolet Silverado 1500 Crew Cab
I have an early 90's Starcraft pop up camper. I just went to hook it up to the van and the travel lights (running, brakes, directionals) don't work at all. All lights worked when the camper was stored last...
When you say that you have power up to the camper, do you mean power through the pigtail/wiring harness with the tow vehicle connected?
The trailer harness wiring is the only way to power these exterior camper lights, i.e., through your vehicle. There are no fuses within the trailer for the exterior lights. These lights are only fused from the tow vehicle's fuse box. So either the connections in the trailer harness are open, or they're open at the tow vehicle connection.
Do the turn signals work on the tow vehicle? If yes, then the only other thing to check is the turn signal flasher in your tow vehicle. A heavy duty flasher is recommended.
From the trailer, yellow, white, brown, red, green, is connected to your vehicle backup, ground (frame), right turn signal, left turn signal, running lights, respectively.
The trailer's blue wire is for an electric brake connection to your vehicle.
The trailer's small black wire should connect to the vehicle's hot, 12V lead for the interior lights. The large black wire at the trailer hitch is for charging an RV battery on your trailer, if it's supplied with one. Of all of these wires, only the large, 12 gauge, black wire goes to the 25 amp converter, which is fused, for the inside lights of the camper.
I hope this helps.
Apr 25, 2009 | Sport & Outdoor - Others
No running lights on camper trailer
Hey Paul, it's most likely a wiring problem. There is one wire designated for just the running lights. What type of plug does the truck have? Probably 6 or 7 way (6 or 7 wire). You can check the plug-in at the truck with a multi-meter to see if there's power at that point. If there is, then the problem is somewhere from the trailer plug to the lights on the trailer. If you have a 7 way plug, the center plug is for aux. power (back up lights on what you pull, if equipped). One wire is power to the camper battery for a breakaway switch, one for left turn and stop, one for right turn and stop, a ground wire, one for running lights, and one for trailer brakes. To determine what wire does what, 1st with meter check volts of all wires w/ truck and trailer hooked up, truck running, power wire to battery for breakaway should show voltage if equipped w/ a trickle charge, brake wire will show low voltage, approx. 2 volts, apply brakes and should go up to approx. 12 volts, put on L turn signal, meter should go up and down, as power to blinker pulses on and off, do the same to determine which is the R turn signal (put foot on truck brakes will show voltage to brake lights AND brakes, continue w/ process of elimination to determine which is running lights, and exactly where power is not going.
Apr 19, 2009 | 2002 Toyota Tundra
2007 Tacoma Tail light problem.
Check the taillamp fuse on the truck. If it is blown, you either have a short in the wiring of the camper, or the 7 pin inverter box on the camper.
Oct 27, 2008 | 2007 Toyota Tacoma
Isuzu axiom pull camper
As I recall, your Axiom has a Tow Rating of 5000 pounds -- but check your Owner's Manual to be sure. I have several friends who tow with their Isuzus (using 1st and 2nd Gen model Troopers and Rodeos) and pull pop-up campers, high-profile campers, ATV trailers, etc... There's even even one guy who pulls his Trail Rig (another Isusu) to various off-road events on an 18-foot tandem axle steel frame trailer -- All of them do so without any problem whatsoever. The thing is, all of them use a Load Distributing Hitch System, such as this: http://www.truckaddons.com/Catalog/subpages/hidden-hitch-weight-distributing-hitch-systems.htm It makes a HUGE difference. Hope this helps.
May 18, 2008 | 2007 Isuzu Axiom
Vehicle Parts & Accessories Logo
16 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
