The airconditioner is leaking. I can't find a way to open it to see if has a resevoir to empty.
  • 434 Answers
No resevoir. It needs to be leaning slightly back for the water to drain outside
Posted on Jun 24, 2009
Clutch drops to floor
You have a small resevoir under the hood, like the brake fluid resevoir. This holds brake fluid also for your clutch master cylinder. See that it has fluid in it. If empty, you have a leak. If full, have someone work the clutch pedal and watch from under the vehicle to see if the clutch slave cylinder is pushing the rod in and out. (Located on the passenger side transmission bellhousing)
Jul 15, 2012 | 1991 Toyota Pickup
Coolant resevoir of 2002 Suburban is empty. What do I fill it with. Does this indicate a leak in the system?
The resevoir should be filled with a 50/50 solution of water and anti freeze.
The fact that it is empty indicates a leak in the system.
Refill it and watch the overflow tank and other coolent items like hoses and such and note any leakage.
If you smell the sweet smell of antifreeze when driving the truck , you may have a radiator issue.
Sep 28, 2011 | 2002 Chevrolet Suburban
Cant find my manual and I dont recall what descaling means. It is stuck on this and wont do anything. Please advise
According to the owner's manual, you sould empty the water resevoir. Fill the water resevoir with white vinegar (it says 48 oz). Place a ceramic (not paper) cup in the drip tray and run a travel mug cycle with no k-cup in the machine. Throw the vinegar out. Repeat this process until the resevoir is empty. Be sure to open and close the lid so the cup sizes flashes each time. let the brewer sit for 4 hours while still on (the vinegar's still inside). Rinse out the resevoir, fill it with water and run the cycles through until the resevoir is empty again. If there is any residual taste. repeat the rinse. If it still say descale when you're done, the book says to repeat the process.
Nov 28, 2010 | Keurig B60 Coffee Maker
Emergency brake light won't go off. Now leaking fluid underneath. After driving a short distance, front fluid resevoir is almost empty...large back resevoir is low . Leaking out on the ground. Front...
this brake warning light has dual functions,1 it tell you emer brake is on 2 it tells you you have low brake fluid leval,you said you see fluid and your resivoir is low,this means you have a leak in the brake system,and should not drive untill leak is found and problem is repaired
Oct 19, 2010 | Chevrolet 1500 Cars & Trucks
My airconditioner is leaking. I emptied it twice
Is what you have emptied part of the design of the unit? Or is what you emptied something you made to
control the leak?
Some of these units sometimes need to be lifted so far off the ground to get proper airflow around the entire unit. If you have high humidty than either the unit is undersized. Does the unit ever shut off?
Jul 03, 2010 | Amcor A12000E Nanomax Portable Air...
Will not come on after resevoir was emptied
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Apr 07, 2010 | LG LHD65EBL Dehumidifier
I am losing coolant, not from the radiator and not from the resevoir, where else could it be coming from. The resevoir is empty in 1 week after fillup
you could have a blown head gasket and coolant could be leaking into your combustion chamber.
rent a radiator pressure tester and see if the cooling system will stay at constant pressure. If the pressure drops you have a leak, and it could be your gaskets. pretty costly to repair.
make sure you have not blown the seals on the engines water pump. when they go out, the burst disc on the pump open and gush coolant everywhere.
Dec 19, 2009 | 2004 Pontiac Grand Prix
1991 Acura Legend
It might be a leak in the resevoir itself. There is a hose to allow the radiator to "****" new fluid into the radiator - check it first. It should be long enough to "freshen" the connection by cutting off a little bit and using the american style clamp.
Jan 18, 2009 | 2001 Mazda Tribute
Small antifreeze leak after oil change. Took back in said it was just oil spilled dripping. 5 days later antifreeze all over the drive way, none in resevoir. Is it okay to drive back to dealer?
open the reservoir when cold refill with prestone dont drive with empty reservoir it might overheat and cause aditionnel problem hope its a fix fpr our problem and fixya for my rating thank you pierre
Aug 03, 2008 | Chrysler Sebring Cars & Trucks
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
