Lxi television manual
My father gave us his big screen tv and we can not program the channels in. He also can't find the books to the TV is there a way to get them? The model number is 626 54552 19, It is an older model and we have done channel scan but we may not be doing it right. I hope you can help.
I have a 52' LXI that was given to me, I am having trouble programming the channels with a cable output. The TV starts at Channel 7 but those channels before it does not come in with my cable output or ANT out put. How do I get those channels to come in
Posted on Jul 15, 2008
We had the same exact problem. If you let the TV sit for a few hours UNPLUGGED, press the power button every once in a while to drain the power out of the capacitors, then plug it back in and HOPEFULLY you end up with a blue screen. If you do, use the buttons (vcr buttons on mine) to get the arow to Auto Preset, click around some of the other buttons until it starts. Out TV works fine now.. Good luck!!
Posted on Jan 16, 2009
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2, stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
I have a LXI series 13''tv,no manual-can't program channels
in menu switch the language to english, then find the channel setup feture under that there should be an auto search option run that and it should setup ypur channels
Sep 10, 2009 | Televison & Video
My 60'' LXI slimview television will only save one chanel.
If you have remote control for the channels on your set, try to push menu then choose "memorize channel" or choose "cable" then do the channel memory.
Aug 16, 2009 | Televison & Video
Add or delete channels on LXI tv
I have a Phillips LXI 46in TV. How do you save channels?
Jun 15, 2009 | Philips TP2784C TV
I just moved and now have Direct TV and have a big
Not all Vizio TVs use the same codes with their Vizio remotes also. That's why this is a problem.
Here's the possible codes from my Directv book.
11756 and 10178
If that doesn't work, you may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
May 11, 2009 | Olevia LT32HVM 32 in. LCD Television
Can't view all my channels on LXI series TV
For anyone with a set with this problem that is older----IT DOES NOT HAVE THAT PART OF THE CABLE BAND BUILT INTO IT--only solution is either to put a cable box to it or buy a new set.
Nov 20, 2008 | Televison & Video
Can you unblock channels if you don't remember the code?
what kind of TV is yours?
tell us brand and model which you will find on the back side, Then your problem will be resolved.
Jun 23, 2008 | GE 32GT740 32" TV
Channel lock
Sounds like the unversal remote isnt programmed for your particular TV. See if the instruction manual gives the details for how to do that. If not, call them to see if they can walk you through it. If that doesnt work, go buy a big screen TV.
Apr 11, 2008 | Haier HTF20R21 20" TV
Have 46ux12b hitachi
2 Questions?
1., Does the unit have sound?
2., Can you hear a click?
Jan 12, 2008 | Hitachi 43FDX01B TV
Lxi television
I am looking for how to change my tv into video mode without the remote and found an answer for your problems....
Aug 30, 2007 | Televison & Video
Televison & Video Logo
1,601 people viewed this question
Top Televison & Video Experts
