Question about Electronics - Others
How to check spark trigger on mcculloch fdd210?
Is the led control the ignition coil for spark?
  • 1168 Answers
SOURCE: 1989 ford pick-up,no spark comming from ignition
From a few years experience with these trucks the next most common problem is the ignition module(on the distributor) or the pickup coil. The pickup coil is inside the distributor and it is necessary to remove the distributor and it's shaft to change it.
Posted on Oct 30, 2009
  • 142 Answers
SOURCE: just picked this McCulloch fdd210 up at an auction
It is a gas generator.
Posted on Jun 22, 2010
puertobori
  • 7733 Answers
SOURCE: McCulloch 2000W Inverter Digital Generator #
download a manual at ->link.
Posted on Oct 13, 2010
speedwagen
  • 491 Answers
SOURCE: 1990 Suburban, 5.7, 4x4 will not start. Appears
Could be a bad ignition switch or harness
Posted on Nov 29, 2010
kel1guy2002
  • 3740 Answers
SOURCE: i have a generac ix
You engine has a low oil level sensor. If the oil level is low or..... the sensor is bad it will ground the ignition from the coil with the engine switch on. For troubleshooing only disconnect ONE wire from the sensor AFTER you make sure the engine oil level is properly serviced. Then check for spark.
If this does not correct the problem just respond and I will help you.
Thanks for choosing FixYa,
Kelly
Posted on Mar 29, 2011
Location of ignition control module 2001 cadilac deville
Ignition Coils/Modules
The electronic ignition system uses an individual ignition coil for each cylinder. There are two separate ignition module assemblies located in the camshaft cover of each cylinder bank. Each ignition module assembly contains an ignition control module and four ignition coils. Each ignition coil connects directly to a spark plug using a boot. This arrangement eliminates the need for secondary ignition wires. The ignition module assemblies receive power from a fused ignition feed. Both ignition module assemblies connect to chassis ground. A Reference Low and four ignition control (IC) circuits connect each ignition module assembly to the PCM. The PCM uses the individual IC circuits to control coil sequencing and spark timing for each ignition coil. The IC circuits transmit timing pulses from the PCM to the ignition control module to trigger the ignition coil and fire the spark plug. The PCM controls ignition system sequencing and timing events
Dec 05, 2015 | 2001 Cadillac DeVille
2002 mitsubishi galant 1 and 4 spark plugs no spark ....i need help . . i change the coil and plugs already still no spark..
Look more closely at the 1 and 4 coil, also, check for trigger signal to these coils. I mostly suspect the trigger unit.
Dec 04, 2014 | 2002 Mitsubishi Galant
I have a 98 vw jetta gl ABA and it wont start run.
I would check for spark on the ignition coil and the spark plug. If no spark, check the power and signal to the ignition coil. The ignition coil large wires are 12volts power and the other three is a signal to electronic firing circuit from ECM. Testing the power is easy, for testing for trigger signal, use a 12v LED test light.
12 Volts test:
http://i222.photobucket.com/albums/dd236/pulga1952/VW/Ignitioncoil.jpg
Signal test:
http://i222.photobucket.com/albums/dd236/pulga1952/VW/Ignitioncoilharness.jpg
Jun 04, 2017 | 1998 Volkswagen Jetta
Fr2.0 14'' McCulloch chainsaw has no spark when holding spark plug wire while pulling the cord.
Ignition Coil Test
SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
If you really sure there is no spark turn on the ignition, put your pinky finger in place of the plug, and give a short pull. If you didn't get shocked the coil, switch, or wiring is bad.
You can find an IPL for your saw here:
McCulloch International
http://www.mcculloch.biz/
The model you provided does not cross. A number on your saw will match something. Your coil part number can be found there. HTH
Lou
Oct 15, 2009 | McCulloch Garden
I need to know the timing sequence for a 1998 Mercury Mystique 2 liter
ignition timing or valve timing?
ignition timing not setable.
info:
The ignition system consists of an ignition coil, spark plug wires and spark plugs.
The crankshaft position sensor signal is the basis for ignition timing calculations. The alternating voltage signal from the crankshaft position sensor is digitized by the powertrain control module. This digitized signal is then used to position the closing time of the primary circuit of the ignition coil.
Ignition angle is determined by the powertrain control module in response to engine operating conditions. Once ignition angle has been determined, the powertrain control module interrupts the current to the primary circuit of the ignition coil thus triggering the ignition spark which is supplied to the cylinders through the spark plug wires and spark plugs.
The ignition coils are triggered by the powertrain control module in pairs (cylinders 1 and 4 and cylinders 3 and 2) sending one ignition spark to the firing cylinder and one ignition spark to the corresponding cylinder on the exhaust stroke. This make sures that any unburnt fuel residues remaining in the cylinder on the exhaust stroke are re - ignited to provide cleaner exhaust emissions.
May 06, 2009 | Mercury Mystique Cars & Trucks
Timing the cams and crank with a belt
  1. Note: Electronic Ignition engine timing is entirely controlled by the PCM. Electronic Ignition engine timing is NOT adjustable. Do not attempt to check base timing. You will receive false readings.
The CKP sensor is used to indicate crankshaft position and speed by sensing a missing tooth on a pulse wheel mounted to the crankshaft. The CMP sensor is used by the COP Integrated EI System to identify top dead center of compression of cylinder 1 to synchronize the firing of the individual coils.
  1. The PCM uses the CKP signal to calculate a spark target and then fires the coil pack(s) to that target shown in Figure 51. The PCM uses the CMP sensor not shown in Figure 51 on COP Integrated EI Systems to identify top dead center of compression of cylinder 1 to synchronize the firing of the individual coils.
  1. The coils and coil packs receive their signal from the PCM to fire at a calculated spark target. Each coil within the pack fires two spark plugs at the same time. The plugs are paired so that as one fires during the compression stroke the other fires during the exhaust stroke. The next time the coil is fired the situation is reversed. The COP system fires only one spark plug per coil and only on the compression stroke.
    The PCM acts as an electronic switch to ground in the coil primary circuit. When the switch is closed, battery positive voltage (B+) applied to the coil primary circuit builds a magnetic field around the primary coil. When the switch opens, the power is interrupted and the primary field collapses inducing the high voltage in the secondary coil windings and the spark plug is fired. A kickback voltage spike occurs when the primary field collapses. The PCM uses this voltage spike to generate an Ignition Diagnostic Monitor (IDM) signal. IDM communicates information by pulsewidth modulation in the PCM.
  1. The PCM processes the CKP signal and uses it to drive the tachometer as the Clean Tach Out (CTO) signal.
2.5L V6
The crankshaft position sensor signal is the basis for ignition timing calculations. The alternating voltage signal from the crankshaft position sensor is digitized by a pulse former within the powertrain control module. This digitized signal is then used to position the closing time of the primary circuit of the ignition coil.
Ignition timing is determined by the powertrain control module in response to engine operating conditions based on stored data tables or maps. Once ignition timing has been determined, the powertrain control module interrupts the current to the primary circuit of the ignition coil thus triggering the ignition spark which is supplied to the cylinders through the spark plug wires and spark plugs.
The ignition coils are triggered by the powertrain control module in pairs (cylinders 1 and 5, cylinders 4 and 3 and cylinders 2 and 6) sending one ignition spark to the firing cylinder and one ignition spark to the corresponding cylinder on the exhaust stroke. This ensures that any unburnt fuel residues remaining in the cylinder on the exhaust stroke are re - ignited to provide cleaner exhaust emissions.
2.0L 4 cynder
Integrated Electronic Ignition System The Integrated Electronic Ignition (EI) System consists of a crankshaft position (CKP) sensor, coil pack(s), connecting wiring, and PCM. The Coil On Plug (COP) Integrated EI System uses a separate coil for each spark plug and each coil is mounted directly onto the plug. The COP Integrated EI System eliminates the need for spark plug wires but does require input from the camshaft position (CMP) sensor.
Apr 05, 2009 | 1998 Ford Contour
Electronics - Others Logo
26 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
