Question about Elna Xplore 8600 Computerized Sewing Machine
Hi I just turned my machine on - it worked perfectly when last used, but now there is a knocking noise, then it asks to raise pressure foot and needle bar, then turn back on again. I have tried this but same fault occurs. it says warning #01. Any ideas on what I should do?
2 Suggested Answers
shoresuz
SOURCE: I have star series elna
I have the flatbed version of your machine. It was acting the same way. There is a rubber drive gear in the machine that becomes smoothed out over the years from wear. When it is smooth, it loses friction and that is why you have to move the hand wheel manually. There is not enough friction on the gear for it to drive the operation of the machine by the motor. I had to get down into the machine and rub the smooth surface until it was not so slick and created some friction with the parts it comes in contact with. A factory-trained elna repairman suggested this fix instead of buying the replacement part because the replacement part is not as good as the swiss made original part. My machine runs well now.
Posted on Apr 02, 2014
My fabric keeps puckering.
The first thing I would check is the threading. Remove the upper thread completely. RAISE the presser foot and rethread from the beginning making sure it follows the correct thread pathway. Sometimes thread will "jump" and come out of a thread guide or the takeup lever. Also, raising the presser foot releases the tension disks and allows the thread to seat properly.
Loosen the thread tension. Install a new needle. Also, some machines have a presser foot pressure adjustment that can be set lighter or heavier depending on the fabric weight. The Owner's Manual should have information. On older machines, it is usually a screw or button above the needlebar that adjusts the needlebar's spring tension. Newer machines would have a dial on the side or above the needlebar area.
Seam Puckering Industrial Sewing Thread Tension Coats Industrial
How to Prevent Puckering Sewing Machine
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwjwi5uQrJPLAhUW7WMKHcEQAwkQFggvMAI&url=http%3A%2F%2Fwww.amefird.com%2Fwp-content%2Fuploads%2F2010%2F01%2FMinimizing-Seam-Puckering-2-5-10.pdf&usg=AFQjCNF6q0Pk13ZU4Hb3o3RiAGBbL04l-A
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&cad=rja&uact=8&ved=0ahUKEwjwi5uQrJPLAhUW7WMKHcEQAwkQFgg1MAM&url=http%3A%2F%2Fwww.amann.pl%2Fpobierz%2Fprzemyslowe-nici-szwalnicze.html%3Ftx_abdownloads_pi1%255Baction%255D%3Dgetviewclickeddownload%26tx_abdownloads_pi1%255Buid%255D%3D265%26no_cache%3D1&usg=AFQjCNFeFwt_nN2Mj32Uvv6nCuVY3kM7eQ
Perfect Machine Tension Every Time Threads
http://makeitsew.biz/presser-foot-pressure
Parts of Sewing Machine Pressure Adjustment
Under Pressure Adjusting Presser Foot Pressure
Sewing Machine Pressure Settings for Machine Quilting
Feb 25, 2016 | Sewing Machines
Does anybody know why soon as I turn the machine on it makes a weird noise and the screen says raise needle bar and presser foot. I've tried everything, can anybody help?
Hmm. Raise the foot with the presser foot lever. You have to raise the foot up to get the fabric under the foot in order to see.
May 02, 2015 | Sewing Machines
Elna SU buttonhole- I can't remember the order to set the dials for the automatic button hole function. Anyone know? Thanks
sure, put on the buttonhole foot after putting a button into it and using the screw knob to set the length you want.
Turn stitch length knob and stitch width knobs to zero, (always set them to zero first to avoid wear on the stitch selection mechanisim) then turn the left stitch selector knob to the blue button hole symbol. Now turn middle knob stitch width, to the blue buttonhole symbol. Now turn right knob stitch length to blue 1, sew down the first side of your buttonhole until foot slide in the buttonhole foot reaches end stop. raise needle and turn stitch length to blue 2, and sew three bar tacks across buttonhole. Again, raise needle and then turn stitch length to blue 3 and sew back down otherside of buttonhole until you reach the end stop. Needle up, turn length know to blue 4 and sew three bartacks to end. there is a last blue symbol dot on stitch length knob, this will sew a stitch in place to tie off the ends. Raise pressure foot, remove your work and draw top threads to underside with a needle, and tie off or use a dot of fray stop. Done! if you don't have a manual you could email me and I'll send you a copy of mine, tallygirl98 at yahoo dot com.
Oct 11, 2013 | Elna 2007 Mechanical Sewing Machine
My brand new Janome 12000 has an error message, "raise
try lowering the pressure foot and the needle and then raise them
again and then restart the machine, and if that doen't clear the
error message then it's time to service the machine.
Jan 07, 2013 | Sewing Machines
When I turn on the machine I get a message that says Lower needle, raise pressure foot and power on machine. It is making a noise and the carrige wont move.
it's possible that breaking the needle could have done something to the computer or damaged a part of the machine, having the machine checked
would be a good idea
Apr 15, 2012 | Bernina Bernette Deco 600
When sewing hems and coming across a thick seam, the pressure foot seems to not allow the material to run through, keeping it stalled while the needle continues to pump into the material eventually...
I don't think you can adjust the feed pressure on this machine. I have the same machine and the same problem and my solution is the same as you've already mentioned - raise the foot and move the fabric by hand. I would do it by turning the wheel by hand until the seam is clear of the foot to prevent breaking a needle or sewing my fingers.
Feb 06, 2011 | Brother XL-2610
I have a old Elna machine. The air electronic SU 390 B. I have lost the manual and am trying to do buttonholes on a dress. I have forgotten the sequence of nob adjustments to complete the process.
Is this the duplex model with the base that fits into a sewing cabinet?
My Elna booklet lists a SP "air electronic" duplex (CL.39), if so, then it would be same stitches as the 38, yellow front panel, 7 built in stitches and automatic knob with blue markings for buttonholing.
Here is the SU manual images for buttonholing, should be exactly the same for the SP.
tally_girl_4.jpg Instructions are:
use buttonhole foot. turn the 3 dials to buttonhole marked in blue (stitch selection, width and length).
Mark length of buttonhol on the material. Place work under foot with the mark in the middile fo the foot, the start being directly below the needle. sew the first side, raise the needle. Turn stitch width dial to 2, blue. Sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to 3 blue. sew the second side. stop just short of the first side. Raise the needle.
turn the stitch width dial to 4 blue. sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to "fastening off stitch" blue dot. Sew a few stitches, holding back the material by hand. Raise needle, lift pressure foot and remove work, triming off threads.
Open the buttonhole with your seam ripper (put a pin across the end to avoid any nasties).
Aug 26, 2010 | Elna 2007 Mechanical Sewing Machine
How do I turn corners with the overlock foot for a Janome 2049?
Sew to the end of the fabric, slowing right down to within a stitch or two of the end, manually turn wheel to complete last two stitches, stop, raise needle, raise presser foot, turn fabric so the back edge of the fabric is just under the needle, drop needle, drop presser foot and resume.
Mar 13, 2010 | Janome 2049LX Mechanical Sewing Machine
Says raise pressure foot and needle bar
check youre screen you will see an icon of needle you have got it in the down mode touch it it will raise it next time you sew it will be raised this is an option to have needle in fabric or raised on completion of sewing this is in your manual.
hope this helps mary h
Dec 18, 2008 | Janome Memory Craft 9000 Computerized...
CLICK AND GRIND IN 270D BROTHER SEWNG MACHINE
Make sure you're using the correct foot for the stitch. Is this during sewing or embroidery? Take off the bobbin plate using the screwdriver and remove the bobbin. Make sure everything is clean under and around the shuttle. If you've ever broken a needle the tip might have fallen down into the mechanism and occasionally be jamming it.
Nov 19, 2008 | Brother SE-270D Computerized Sewing...
Elna Xplore 8600 Computerized Sewing Machine Logo
20 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
