Question about Jensen JMS2212 AM/FM/USB/iPod w/Weatherband & Sirius Stereo JMS2212
USB error message
How can I get my Jensen marine radio to "read" my IPhone. I continually get a USB error message
4 Suggested Answers
Ajkill
  • 2035 Answers
SOURCE: Jensen MSR4050G Sirius Ready marine radio
Sirius Mode Selection
While in Sirius satellite radio mode, press S-MOD (22a) (also the SHIFT/SCAN button) to select
from four available modes: Normal, Category, Direct Tune and Set Skip Channel. When the
Category or Set Skip Channel modes are selected, the corresponding icon appears in the display.
When the DIrect Tune mode is activated, the alphanumeric display appears.
Click on this link to get the user manual:
http://www.asaelectronics.com/techpdf/MSR4050G%20Owners%20Manual%207-11-05.pdf
good luck...
Posted on May 19, 2008
I had the same problem and there are a couple of reason why you may not be able to get into Sirius Mode.
  1. You have the wrong type of antenna (it must be a Sirius approved antenna)
  2. You may not have installed the tuner (most Sirius ready units need require that you have a tuner hooked up to your unit to get satellite reception. The tuners are specific to your unit, so make sure you but the correct one. This is quite sneaky on Sirius’ part…but good luck).
Posted on Jun 25, 2008
SOURCE: Can I buy the face only to the jensen marine mcd 5110
Do you still need the face plate for a 5110? I have one with case. if so e-mail me @ r.ruditz@att.net
Posted on Jan 01, 2009
Error 1015 in iTunes iphone 3g Model no a1241...
  1. Disconnect the USB cable from your iPhone, but leave the other side connected to your Mac or PC
  2. Launch iTunes
  3. Press and hold down the Home and Sleep/Power button on the top of the iPhone to turn off the iPhone
  4. Press and continue to hold the Home Button while you reconnect the USB cable to your iPhone, this will cause the iPhone to turn on
  5. Continue to hold the Home button until an alert message in iTunes informing you that an iPhone in recovery mode has been detected. Your iPhone is now in recovery mode. If you have not launched iTunes, you will see the familiar screen of the USB cable pointing at the iTunes logo signaling to connect the iPhone to iTunes to start recovery.
    Once you're in recovery mode, you can either restore the iPhone or adjust the firmware as necessary.
    After restoring or upgrading firmware, your iPhone will automatically reboot and exit recovery mode on it's own.
Sep 05, 2015 | Apple Cell Phones
My Jensen MCD 5110 Marine radio acts like the antenna is unplugged. I can't figure out how to remove the radio from it's sleeve to re-plug the antenna jack (if that is the problem)
I don't know much about marine radios. I am a ham radio operator, but they are much the same, if you do not hear any static (with squelch control turned down), then I suspect you are correct about the antenna. It could be the antenna itself, or the coax line to it, or the connection point at the radio or at the antenna. You're stuck without being able to remove it. If you do and find nothing at the radio, you'll need to check the connection at the antenna etc. Good luck.
Nov 21, 2014 | Jensen Mcd5110 Marine Radio /am/ Fm/ Cd...
When I try to use USB port with iphone I get error message
USB cords have a "shelf" life and can break down after a while. If you are using a non-Apple replacement for an original cord, that could also be a problem. The worst case scenario is that the nodes in the female plug that connects your phone to the USB cable is worn. I have had all three of these issues happen to me over the years...but never the same thing twice!
Jul 24, 2014 | Enrock Black Marine Boat Radio USB AUX...
Why wont my iphone play video through my jensen vm9114
you need av input adapter its 3.5mm male to rca etc ... then iphone to video rca etc.... and viola
Aug 03, 2012 | Jensen Brand New Vm9114 7" Touchscreen...
The volume wont go higher than 12 on my Jensen Mcd5110 Marine Radio/am/fm/Cd receiver W/Detachable face, how can I fix it to go all the way up to 26 plus?
take off the bottom cover ,find the volume switch on the outside then find it on the inside.Now get some WD-40 and spray the control on the inside with a very,very light squirt of WD - 40. Let it set for a while then try it.It should work.
Jul 09, 2012 | Jensen Mcd5110 Marine Radio /am/ Fm/ Cd...
I have a jensen uv10 and cant get the radio on the usb plugin to read my ipod so everytimei start my car i have to replug it in the usb any ideas????
connect it to the aux 1 or aux 2 inputs. buy the adapter at walmart in automotive section were the dashkits rca jacks are it should be $5
Mar 03, 2010 | Jensen VM9510 Car DVD Player
When I try to sync my itouch I get an error
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Sep 08, 2009 | Apple iPod touch
Looking for a store in pei canada
TRY A MARINE SUPPLY STORE...THEY USUALLY CARRY JENSEN MARINE RADIOS AND CAN ORDER EVERYTHING ELSE....OTHERWISE BUY ONLINE.
Mar 28, 2009 | Car Audio & Video
The usb connection on my new Tevion 5705 won't read the music from my usb key. the usb key has been re-formatted to a FAT, and then a FAT32, file system and we have then copied the DOS files onto the usb...
Hello I have the same problem but no body do answers . Maby we change radio {panasonic or oder :-). The usb connection on my new Tevion 5705 won't read the music from my usb key. the usb key has been re-formatted to a FAT, and then a FAT32, file system and we have then copied the DOS files onto the usb key along with music files in mp3 & W4ma types though we still can't seem to get the Tevion 5705 car radio to read the music from the usb key when inserted. We keep getting an 'Error 13' message, can someone please help . my email : zadychladislav@hotmail.com Ladi
Aug 13, 2008 | Car Audio & Video
Jensen JMS2212 AM/FM/USB/iPod w/Weatherband & Sirius Stereo JMS2212 Logo
69 people viewed this question
Top Jensen Computers & Internet Experts
David Payne
David Payne
Are you a Jensen Computer and Internet Expert? Answer questions, earn points and help others
